Gorf Posted November 3, 2008 Share Posted November 3, 2008 ...sorry for the long-winded post but.....her goes... Im driving poor ol' PacManPlus insane trying to get him to explain to me exactly what is goin on with the DLL/DL...its not at all his fault....Im just rather thick at first when I deal with unfamiliar hardware. So maybe with a chorus of you pounding it into my noggin, I'll finally get it so I can write a higly efficient 32 sprite full screen character map kernal(is it actually called a Kernal with the 7800?) I need this many sprites to do more robust Warbirds. Bob's DLL template example is not a static disply that you simply update...he does tell me that the example can be VERY optimized by only updating th necessary fields of the DLL that can remain. Gorf would have serious trouble using the current example code from Bob( though I am beyond greatful for him sharing it as its been very helpful in underatnding most everything else so far concerning the 7800.) His example was simple enough to add the other sprites but its showing its inefficiency(as Bob said it would) when I get more than 24 sprites on the screen at once. I need a static field updatable 'kernal' instead of a dynamic list. Anyway.... in a DLL, .byte $4F,<DL,>DL this is holey DMA mode, H16 at 16 rasters.....represents 16 rasters on the screen, correct? If I want 192 vertical lines I need 13 such entries in my DLL, yes? Now, here is where Im having some trouble understanding. Above we have the DLL pointing to all the same DL's... Im having trouble with two things. The 'software'ish nature of the Y postion: I know that for sprites, you take your Y position and shift it right 4 to get your zone of interest and add that to the sprites hi byte address field.....Im still not sure what you do with the lower four bits because these are obviously the offset into the zone. I think I gather from what Bob was trying to explain to me ( most gracious man that he is) that you need to stuff them in to the display list list zone that the sprite will be in, in the offset field of that DLL? If this is the case, how does one handle two different sprites in the same zone? I know Im looking at this wrong somehow....can anyone help ol' Bob get my head around this? The DLL/DL relationship: My trouble here is clearly the relationship between the DL's and the DLL. I need 32 sprites and I intend to use a full screen of characters for the back ground stars and such. What is wrong or not wrong with the DLL/DL below? DL: ; one char map: .byte MAPLO, WM|IND, MAPHI, PAL|WIDTH, HPOS ;32 sprites .byte SPR00LO, PAL|WIDTH, SPR00HI, HPOS ;0 .byte SPR01LO, PAL|WIDTH, SPR01HI, HPOS ;1 .byte SPR02LO, PAL|WIDTH, SPR02HI, HPOS ;2 .byte SPR03LO, PAL|WIDTH, SPR03HI, HPOS ;3 ...... ...... ...... .byte SPR31LO, PAL|WIDTH, SPR31HI, HPOS ;31 .byte 00,00,00 ;end DLL: .byte $02, 0, 0 ; no holey DMA, 3 blank lines .byte $09, 0, 0 ; no holey DMA, 10 blank lines .byte $4F, <DL, >DL ; 1st 16 rasters of visible display and can show all sprites of DL1 in this zone0 .byte $4F, <DL, >DL ; 2nd 16 rasters of visible display and can show all sprites of DL1 in this zone1 .byte $4F, <DL, >DL ; 3rd 16 rasters of visible display and can show all sprites of DL1 in this zone2 .byte $4F, <DL, >DL ; 4th 16 rasters of visible display and can show all sprites of DL1 in this zone3 .byte $4F, <DL, >DL ; 5th 16 rasters of visible display and can show all sprites of DL1 in this zone4 .byte $4F, <DL, >DL ; 6th 16 rasters of visible display and can show all sprites of DL1 in this zone5 .byte $4F, <DL, >DL ; 7th 16 rasters of visible display and can show all sprites of DL1 in this zone6 .byte $4F, <DL, >DL ; 8th 16 rasters of visible display and can show all sprites of DL1 in this zone7 .byte $4F, <DL, >DL ; 9th 16 rasters of visible display and can show all sprites of DL1 in this zone8 .byte $4F, <DL, >DL ; 10th 16 rasters of visible display and can show all sprites of DL1 in this zone9 .byte $4F, <DL, >DL ; 11th 16 rasters of visible display and can show all sprites of DL1 in this zone10 .byte $4F, <DL, >DL ; 12th 16 rasters of visible display and can show all sprites of DL1 in this zone11 .byte $4F, <DL, >DL ; 13th 16 rasters of visible display and can show all sprites of DL1 in this zone12 .byte $0F, 0, 0 ; no holey DMA 16 blank lines .byte $0E, 0, 0 ; no holey DMA 15 blank lines .byte $00,$00,$00,$00 ; end What is missing? What do I have too much of? Does this belong in my recycle bin its so not there? I appreciate any indulgence from anyone who might dare try chiseling through my think skull this complex graphics chip. Thanks Gorf Quote Link to comment Share on other sites More sharing options...
Crazyace Posted November 3, 2008 Share Posted November 3, 2008 Hi, A couple of differences. 1: You set the blank DLL's to point to a DL at address 0. They should be pointing to an empty DL ( ie: 2 bytes of 0,0 ) 2: All of your display DLL's point to the same DL - they should be pointing to 13 different DL's If you have 32 sprites active in all zones you'll need nearly 2k for all the DL's and the DLL. For sprites that aren't present just set their high address to the holey area and they wont display. For the Y address of the sprite - /16 gives the starting DL to modify.. you take the &15 and add to the high address - but this only gives you the starting part of the sprite - you then set the next DL's equiv entry to the (&15)-16 value. ( I could have mucked that up.. typing from memory here ) Quote Link to comment Share on other sites More sharing options...
DanBoris Posted November 3, 2008 Share Posted November 3, 2008 Gorf, First, let me appologize if I say some things that are obvious, I am not sure which parts of the Maria you understnad and which you don't. Once of the things you might be missing is that the DL is a list of entires, not a single entry. So if you have 4 sprites in the same zone you will have a list of 4 entries in the DL, one right after the other. You mention that you are going to do a character mapped background. In this case you would probably want to put your character DL entries in the list first since they won't change, then put the sprite DL entries after them. Memory management can be a little tricky, you will need to have enough memory for each DL entry to hold the largest number of sprites that can appear in each zone. Another thing to remember is that each sprite will probably have entries in two different DLs. If the DL falls on a even increment of 16 it will appear in only one zone, but in all other cases it will overlap two zones so you will have have a DL entry in the first zone to display the top of the sprite, then a second entry in the next zone to display the bottom. Dan 1 Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 4, 2008 Author Share Posted November 4, 2008 (edited) Hi, Hey Crazy Ace and thanks for the reply, 1: You set the blank DLL's to point to a DL at address 0. They should be pointing to an empty DL ( ie: 2 bytes of 0,0 ) Oops my bad! Those are like you said supposed to be nulled....I do know that much. 2: All of your display DLL's point to the same DL - they should be pointing to 13 different DL'sIf you have 32 sprites active in all zones you'll need nearly 2k for all the DL's and the DLL. For sprites that aren't present just set their high address to the holey area and they wont display. Right, Bob pointed this out and I think I understood it and now I think so even more.... ...what you are saying is I need a Display list( a list of 1 char and 32 sprite entries) for every zone and in each DL I need all 32 sprites and the Char map as well? Like this? DLL: .byte $02, <NULL, >NULL ; no holey DMA, 3 blank lines .byte $09, <NULL, >NULL ; no holey DMA, 10 blank lines .byte $4F, <DL00, >DL00 ; 1st 16 rasters of visible display .byte $4F, <DL01, >DL01; 1st 16 rasters of visible display ....... .byte $4F, <DL31, >DL31 ; 13th 16 rasters of visible display .byte $0F, <NULL, >NULL ; no holey DMA 16 blank lines .byte $0E, <NULL, >NULL ; no holey DMA 15 blank lines .byte $00,$00,$00,$00; end DL00: ; one char map: .byte MAPLO, WM|IND, MAPHI, PAL|WIDTH, HPOS ;32 sprites .byte SPR00LO, PAL|WIDTH, SPR00HI, HPOS;0 ...... .byte SPR31LO, PAL|WIDTH, SPR31HI, HPOS;31 .byte 00,00,00 ;end DL01: ; one char map: .byte MAPLO, WM|IND, MAPHI, PAL|WIDTH, HPOS ;32 sprites .byte SPR00LO, PAL|WIDTH, SPR00HI, HPOS;0 ...... .byte SPR31LO, PAL|WIDTH, SPR31HI, HPOS;31 .byte 00,00,00 ;end ...... DL31: ; one char map: .byte MAPLO, WM|IND, MAPHI, PAL|WIDTH, HPOS ;32 sprites .byte SPR00LO, PAL|WIDTH, SPR00HI, HPOS;0 ...... .byte SPR31LO, PAL|WIDTH, SPR31HI, HPOS;31 .byte 00,00,00 ;end If so I see why it would take so much RAM. Dag nabbit! It also explians why Im getting overwrites to some variables. I am definitely over extending myself here. If only the emulators recognized some form of external ram. Does the DL/DLL need to be on the system RAM or can it indeed be on a cart RAM? For the Y address of the sprite - /16 gives the starting DL to modify.. you take the &15 and add to the high address - but this only gives you the starting part of the sprite - you then set the next DL's equiv entry to the (&15)-16 value.( I could have mucked that up.. typing from memory here ) So if a sprites y>>4 falls in to zone 8, I alter the DL in the list that represents DLL zone8? If it falls inbetween 8 and 9 I have to update those DL's in DLL zone8 and DLL zone9? Am I getting this? Edited November 4, 2008 by Gorf Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 4, 2008 Author Share Posted November 4, 2008 Gorf, First, let me appologize if I say some things that are obvious, I am not sure which parts of the Maria you understnad and which you don't. Oh please don't appologize! I appreciate any help I can get with this even if its repeat info. Helps get it through my thick skull better. Once of the things you might be missing is that the DL is a list of entires, not a single entry. So if you have 4 sprites in the same zone you will have a list of 4 entries in the DL, one right after the other. Yes, this much I can grasp now. If I want these four sprites in any of the 13 zones, I'd need to repeat these 4 sprite lists 13 times. You mention that you are going to do a character mapped background. In this case you would probably want to put your character DL entries in the list first since they won't change, then put the sprite DL entries after them. It makes sense as its probably easier to index. Memory management can be a little tricky, you will need to have enough memory for each DL entry to hold the largest number of sprites that can appear in each zone. I think I just might. Astro battles is probably the most heavy in sprite use at one time only contending with Glaxian stage. Astro battles alone would be 1 background charmap, 24 invader sprites, one player sprite, one missile sprite and 6 invader bombs. Also one bonus ship sprite(Gorf, saucer or hover craft) but that one only needs to be in the top playfield zone. that is 5(char) + (32 x 4) + 3(end) bytes or 136bytes per zone. DOH! That comes to 13 x 136 bytes = 1768 bytes...yikes....Hey...I think I can fit that still! 1800 - 2000 is 2k and is where my current DL resides so thats still doable! NICE! Another thing to remember is that each sprite will probably have entries in two different DLs. If the DL falls on a even increment of 16 it will appear in only one zone, but in all other cases it will overlap two zones so you will have have a DL entry in the first zone to display the top of the sprite, then a second entry in the next zone to display the bottom. Dan I got that too but its good to have confirmation. I appreciate your help Dan! Thanks, Gorf Quote Link to comment Share on other sites More sharing options...
Mord Posted November 4, 2008 Share Posted November 4, 2008 Does the DL/DLL need to be on the system RAM or can it indeed be on a cart RAM? According to documentation I've read, DLs and DLLs need to be in system RAM due to time requirements and any DL can only cross at most 1 page boundary. (So a max size of 512 bytes) As to if any homebrewer ahead of us has found this is not the case, I dunno. If they contradict me, believe them. Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 4, 2008 Author Share Posted November 4, 2008 Does the DL/DLL need to be on the system RAM or can it indeed be on a cart RAM? According to documentation I've read, DLs and DLLs need to be in system RAM due to time requirements and any DL can only cross at most 1 page boundary. (So a max size of 512 bytes) As to if any homebrewer ahead of us has found this is not the case, I dunno. If they contradict me, believe them. I believe that means that EACH list can only be two pages in length. Otherwise I assume you can use the entire range of RAM in there. My other guess is that external RAM should be fine if it is fast enough. That also depends on the rate of the cart slot. I imagine it is not any diferent than the rest of the system, but the Jaguar ROM slot is definitely slower than the rest of the bus. The 7800 was developed in a time where bus rate was consistant throughout in most designs. Quote Link to comment Share on other sites More sharing options...
Mord Posted November 5, 2008 Share Posted November 5, 2008 I believe that means that EACH list can only be two pages in length.Otherwise I assume you can use the entire range of RAM in there. My other guess is that external RAM should be fine if it is fast enough. That also depends on the rate of the cart slot. I imagine it is not any diferent than the rest of the system, but the Jaguar ROM slot is definitely slower than the rest of the bus. The 7800 was developed in a time where bus rate was consistant throughout in most designs. It might be that the cart slot itself might not be fast enough, but the only way to really test that I guess would be to get one put together to test. :/ With the way the 7800 changes speed based on what it's using and which processor is in use, it could be a lot more trouble than it looks. And yeah, any particular DL/DLL can't exceed 512 bytes, not 512 for all of them. I really have to get down with seriously attempting to put something together on this console. All the reading and planning I'm doing won't mean a thing otherwise. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 5, 2008 Share Posted November 5, 2008 It's also worth noting that the two Atari cart boards that support RAM seem to have slightly different timing. Mitch Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 6, 2008 Author Share Posted November 6, 2008 External RAM either way would be fine. Then I could use the cart ram forvariables and such and the internal RAM for lists. Quote Link to comment Share on other sites More sharing options...
Crazyace Posted November 6, 2008 Share Posted November 6, 2008 It's way more fun if you write for the base system... ( although the use of ram for some 2600 projects like BDash is really cool ) Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 7, 2008 Author Share Posted November 7, 2008 It's way more fun if you write for the base system... ( although the use of ram for some 2600 projects like BDash is really cool ) I'd want the extra ram so I can use the external for variables and the DLL's and use the total 4k internally for a VIC-20 like frame buffer. Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 10, 2008 Author Share Posted November 10, 2008 Well good news! I finally got my static display list to work and now pretty much fully understand the display list format. I'll now have write some code and put it to use. Its amazing just how many sprites can be displayed with no slow down using a static list. Now to get some code working for updating the lists for animation. Thanks to everyone who helped out! Gorf Quote Link to comment Share on other sites More sharing options...
