RSS Bot Posted December 2, 2008 Share Posted December 2, 2008 just a few pics... still in progress. // First attempt... trying to correct a few things // Scrapped the first and restarted on a new 2600 board. (I've got 15 or so 2600 boards I can go through if I need to LOL // Close up of the bottom right-hand side of the board. (connected to pins 2, 5, 7, // This is the left hand side of the board (bottom) Close up again... // This is the top left hand side of the board. (Eventually the place where I tie-in the Select and Reset wires) // If cutting too close to the edge of the cart connector is a problem, this is the area I am concerned with. Someone check out the otherside of the board. there are two things (res caps... ) that concern me. It is possible my problem is right here. Not really sure though. If you notice, I have only connected the wires that require audio/video out... and then connected the wires that are needed to get the 4X4 to work. I haven't connected the controls, as I'm not concerned with those. they tend to be the easiest part of all of this. I'll get that AFTER I can fix this part. I also have a Casio Model EV-660B that I will be using. Ready to go on that as well... just waiting to get past this hurdle and I'm about to restart again on a new board. LOL Got any tips, advice, see any issues, please let me know. http://www.atariage.com/forums/index.php?a...;showentry=5538 Link to comment Share on other sites More sharing options...
