Chainclaw Posted December 9, 2008 Share Posted December 9, 2008 I've been getting build errors (in the ASM build process, after the Basic build process completes successfully), and it seems to be tied to the number of constants I have. I add a new one, I get the build error, I pull out any constant, the build error goes away. Is there a maximum number of constants I can define? If so, is there a build option I can turn on to have the Batari compiler treat them kind of like #defines when converting to ASM? I imagine this would get around any limitation. Quote Link to comment Share on other sites More sharing options...
+batari Posted December 9, 2008 Share Posted December 9, 2008 I've been getting build errors (in the ASM build process, after the Basic build process completes successfully), and it seems to be tied to the number of constants I have. I add a new one, I get the build error, I pull out any constant, the build error goes away. Is there a maximum number of constants I can define? If so, is there a build option I can turn on to have the Batari compiler treat them kind of like #defines when converting to ASM? I imagine this would get around any limitation. The limit is 50 constants, I believe. I increased this number to 500 in the latest .exe build, which you can get here. Quote Link to comment Share on other sites More sharing options...
Chainclaw Posted December 13, 2008 Author Share Posted December 13, 2008 Thanks, that worked. Quote Link to comment Share on other sites More sharing options...
