pacman3211 Posted December 13, 2008 Share Posted December 13, 2008 i changed the car graphics and the colors. this version of the game uses a custom color palette for stella. the background is blue so it looks like daytime. day_driver.bin stella.pal.bin you have to edit the stella.ini file in "my documents" to use the palette. the configuration menus in the emulator won't work. Quote Link to comment Share on other sites More sharing options...
+stephena Posted December 13, 2008 Share Posted December 13, 2008 i changed the car graphics and the colors. this version of the game uses a custom color palette for stella. the background is blue so it looks like daytime. day_driver.bin stella.pal.bin you have to edit the stella.ini file in "my documents" to use the palette. the configuration menus in the emulator won't work. I'm pretty sure the menus will work; I just tried it. The file has to be named 'stella.pal', and it needs to be placed in the same location as the INI file (My Documents\Stella). And then, you have to select 'user' for the palette type. This works perfectly for me in Linux. If it isn't working in Windows, it must be a bug (or you've set the 'palettefile' variable to point elsewhere). Quote Link to comment Share on other sites More sharing options...
pacman3211 Posted December 15, 2008 Author Share Posted December 15, 2008 I'm pretty sure the menus will work; I just tried it. The file has to be named 'stella.pal', and it needs to be placed in the same location as the INI file (My Documents\Stella). And then, you have to select 'user' for the palette type. This works perfectly for me in Linux. If it isn't working in Windows, it must be a bug (or you've set the 'palettefile' variable to point elsewhere). it probably didn't work because it was in a different directory. here's a version that uses standard colors with different car graphics. night_driver.bin Quote Link to comment Share on other sites More sharing options...
