Thelen Posted September 8, 2002 Share Posted September 8, 2002 I'm learning to program on the atari 800 in assembler. and I want to load a custum character set.but now i have a little problem, i need to load 1024 bytes, how can i do this. with my routine now i can't get passed 256 bytes. who can help ? LDX #$00 KARLOO1 LDA KARAK,X STA $2400,X INX TXA CMP #255 BNE KARLOO1 thanks for your help, Thelen Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 8, 2002 Share Posted September 8, 2002 LDX #$00 KARLOO1 LDA KARAK,X STA $2400,X INX TXA CMP #255 BNE KARLOO1 this does just copy 255 bytes not 256... can be written as ldx #0 loop1 lda karak,x sta $2400,x inx bne loop1 this copies 256 bytes to copy 1024...you can do this loop 4 times...1024/256=4 ldx #0 loop1 lda karak,x sta $2400,x inx bne loop1 loop2 lda karak+256,x sta $2400+256,x inx bne loop2 loop3 lda karak+256+256,x sta $2400+256+256,x inx bne loop3 loop4 lda karak+256+256+256,x sta $2400+256+256+256,x inx bne loop4 ... bne checks the zero flag... so when a,x,y registers contain zero this flag is set...therefore when the x register is going from 255 back to zero the loop is left... what i have written is called unrolled loop... but you can combine x+y register to copy more than 256 bytes ldy #4 ; copy 4x256 bytes=1024 loop1 ldx #0 loop2 lda chardata,x ad sta $2400,x inx bne loop2 ;256 bytes copied? inc loop2+2 ; add #1 to highadress inc ad+2 ;add #1 to destination adress $2400 = $2500 dey bne loop1 this is called selfmodified code...and works just when executed in RAM not from ROM (depends if you code on 5200 f.e.) or you take zero pages: lda #<source ; lo byte of source adress sta $b0 lda #>source ; hi byte of source sta $b1 lda #<destin sta $b2 lda #>destin sta $b3 ldx #4 ;now x register!!! loop1 ldy #0 loop2 lda ($b0),y sta ($b2),y iny bne loop2 inc $b1 inc $b3 dex bne loop1 you see...thouthands of roads lead to rome... hve Quote Link to comment Share on other sites More sharing options...
Thelen Posted September 8, 2002 Author Share Posted September 8, 2002 thanks !! thelen Quote Link to comment Share on other sites More sharing options...
