DtY Posted January 1, 2009 Share Posted January 1, 2009 My program should start by clearing all the ram, then display a black screen, and every twenty frames increment the colour counter, the code was based on the 2600 for newbies tutorials, the one that changed the background colour every scanline, and the one that showed the play field and changed it every twenty frames. What it does do: I start the game up, and it goes to a blank screen, I go into stella's debugger, and it shows that none of the memory was cleared, and y is not counting the time until the next frame. y is used to count how many frames have gone by since the last change, $80 in memory is used to store the current colour, a and x are used for various other tasks throughout the program. Attached are the original assembler source code, and what I got when I compiled it (both were given a .txt extension as the forum would not let me upload them without) Also, people seem to just include vcs.h and macro.h and not think anything about it? When I try that I get an error that the file doesn't exist and have to copy them into the same directory, is there a global include path for dasm somewhere I can put them? (I am on fedora core linux, btw) background.asm.txt Background.a26.txt Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted January 1, 2009 Share Posted January 1, 2009 You forgot to set your interrupt vectors at the end of the program like this: org $FFFA .word Reset .word Reset .word Reset also you made a few simple mistakes in your code. For example: VerticalBlank ldx #0 inx cpx #37 bne VerticalBlank this is an infinate loop because the 'ldx #0' should be out of the VerticalBlank Loop and at the top when you start the frame I changed lda #0 sta VBLANK lda #2 sta WSYNC sta WSYNC sta WSYNC lda #0 sta VSYNC to lda #2 sta VBLANK sta VSYNC sta WSYNC sta WSYNC sta WSYNC lda #0 sta VSYNC Hope this helps! Here is a fixed source and binary. BTW, if you want to post source code, you should zip it so you dont have to change the extension. background.zip Quote Link to comment Share on other sites More sharing options...
DtY Posted January 1, 2009 Author Share Posted January 1, 2009 (edited) Okay, great, thank you. Just, now there are black bars flickering all over, and when I replace that block with the code you gave me, it shows nothing, I checked, and the memory is changing properly, but the background is staying black. When I ran the example you sent me, it worked fine. Also, what exactly do the interrupt vectors do? All I can gather is they insert $F000 three times at $FFFA, I'm guessing that's to insert nulls for the rest of the cartridge, but why three? [edit] Forgot to upload what I had background_changer.zip Edited January 1, 2009 by DtY Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted January 1, 2009 Share Posted January 1, 2009 Also, what exactly do the interrupt vectors do? All I can gather is they insert $F000 three times at $FFFA, I'm guessing that's to insert nulls for the rest of the cartridge, but why three? They point to a certain ROM location that the processor will jump to if it gets interrupted. Also, the second vector points to where you want the processor to start the program (it does not have to be at $F000, many games start elsewhere). Im not sure why your program has black bars on the top left, I will analyze your source further later on. Welcome to AA by the way! Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted January 1, 2009 Share Posted January 1, 2009 I forgot to tell you, add this: ldx #0 stx VBLANK ;Add this line. you must store a 0 to VBLANK to enable display Picture and to get rid of the black lines at the top left, do this: ldx #0 VerticalBlank sta WSYNC inx cpx #36 ; change from 37 to 36 bne VerticalBlank then at label 'NotYet' NotYet lda $80 sta COLUBK sta WSYNC ;add this line Hope it works for you! background2.zip Quote Link to comment Share on other sites More sharing options...
DtY Posted January 1, 2009 Author Share Posted January 1, 2009 (edited) Before I replaced the block of code you gave me, the one right after StartOfFrame, I had black bars that flickered all over horizontally, then I replaced the block with what you gave me, it showed nothing at all, however the one you gave me worked. (I'll go through line by line and see if I can find the problem though) And thanks [edit] I'll try that stuff you jsut posted Edited January 1, 2009 by DtY Quote Link to comment Share on other sites More sharing options...
DtY Posted January 1, 2009 Author Share Posted January 1, 2009 Okay, it works, thank you very much Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted January 1, 2009 Share Posted January 1, 2009 Okay, it works, thank you very much No problem Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted January 1, 2009 Share Posted January 1, 2009 AFAIK, the NMI vector (at $xFFA-B) is not used by the 2600. You can use these 2 bytes for whatever you want (or keep them unused along with the previous 2 bytes to provide unmodded Supercharger-compatability). If BRK interrupts are not used by the program, the interrupt vector ($xFFE-F) can also be used for something else if you wish (or kept unused for the SC-compatability). All a general program needs is the cold start vector ($xFFC-D) to lead it to the ram clear routine. Common practice among early programs was to fill unused vectors with the cold start address, but there is no need to follow it. You can also save a good deal of space if you set an often-called subroutine as the interrupt (as described by Thomas at the top of The Dig's programming guide). Quote Link to comment Share on other sites More sharing options...
