Primordial Ooze Posted January 6, 2009 Share Posted January 6, 2009 (edited) I am creating a DDR style game and need to draw the arrows using the playfield pixels like the DiscoTec demo. How do i draw animated arrows using the playfield pixels? 26002600 Revolution Edited January 6, 2009 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
MausGames Posted January 6, 2009 Share Posted January 6, 2009 I'm not sure what your question is? Are you asking what would be the best way? It completely depends on what else will be going on with the playfeild. If you'll only be used the playfield for the arrows then I'd say you should use the PFHEIGHTS option and squash all 11 pfrows into the top third of the screen. Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted January 6, 2009 Author Share Posted January 6, 2009 (edited) Actually the arrows will go horizontal towards the left on the bottom. Could you please provide some sample code? Also could you explain how i would move the "arrows" using many pfpixils and the x,y coordinates? Edited January 6, 2009 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
jrok Posted January 6, 2009 Share Posted January 6, 2009 Actually the arrows will go horizontal towards the left on the bottom. Could you please provide some sample code? Also could you explain how i would move the "arrows" using many pfpixils and the x,y coordinates? Well, I've been doing a little work with animating Playfield pixels lately. You might want to look at some of the code I posted here for ideas. It's sort of commented Basically, I think you are going to attach a variable to the pfpixel command to mark the "tip" of your arrow, then use a series of pfpixel commands (or pfhline/pfvline) to form the shape, size and direction of your arrow. If you look at my code and have any questions, feel free to ask. Cheers! Jarod. Quote Link to comment Share on other sites More sharing options...
MausGames Posted January 6, 2009 Share Posted January 6, 2009 Do you have a mockup of what this is supposed to look like? Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted January 6, 2009 Author Share Posted January 6, 2009 (edited) Yes: rem 2600 Dance rem a beat game for the 2600 rem Updated: October 11, 2008 rem Website: http://26002600revolution.110mb.com rem includes rem 6 lives kernal include 6lives.asm rem setup all the game variables rem variable to hold if new note direction should be randomly generated dim generaterandomarrow = a rem variable to hold note direction dim arrow1direction = b rem arrow 1's x position dim arrow1x = c rem arrow 1's x position dim arrow1y = d rem variable to hold the players combo dim combo = e rem variable to hold how many more combos before the player earns an extra life dim extralifecombo = f rem set the rom size set romsize 2k rem set the tv format to NTSC set tv ntsc rem turn on smartbranching set smartbranching on rem kernel options rem enable no blank lines set kernel_options no_blank_lines rem set the color of the background to black COLUBK = 0 rem set the playfield color to red COLUPF = 66 rem set the color of the score to light purple scorecolor = 116 rem set the life color to red lifecolor = 64 rem set the life bar to compact dim lives_compact=1 rem enable the "High Definition" playfield hack rem pfscroll upup : pfscroll upup rem define the bar sprite player0: %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 end rem color table for the lives bar data colortable 0,64,66,20,22,200,202 end rem start a new game startNewGame rem start the player with 4 bars lives = 128 rem define the miss counter lives: %00000000 %00000000 %00000000 %11111111 %11111111 %00000000 %00000000 %00000000 end rem reset player's score to 0 score = 0 rem set the players combo to 0 combo = 0 rem set first note's inital x position off screen player0x = 21 rem set first note's inital y position off screen player0y = 80 rem set generate randomdirection to ture since we just rem started a new game generaterandomarrow = 1 rem set the note's initial direction to 0 (none) arrow1direction = 0 rem set arrow 1's initial position arrow1x = 31 arrow1y = 9 gameLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem if generaterandomarrow is true rem generate a random number to generate rem an arrow randomly and set arrowdirection rem to that random number and set generaterandomarrow rem to flase if generaterandomarrow = 1 then r = (rand & 3) + 1:arrow1direction = r:generaterandomarrow = 0 continue rem set note's color to yellow COLUP0 = 30 rem clear the playfield pfclear rem draw arrow 1 pfpixel arrow1x arrow1y on:pfpixel arrow1x arrow1y+1 on:pfpixel arrow1x arrow1y+2 on rem draw the screen drawscreen rem move the arrow if arrow1x = 0 then arrow1x = 30 else arrow1x = arrow1x - 1 rem if the player has earned an extra life then give rem him the extra life and set extralifecombo to 0 if extralifecombo = 50 && lives < 228 then lives = lives + 32:extralifecombo = 0 rem determine how many lives the player has temp1 = lives / 32 rem set the life bars color based on how well the player is doing lifecolor=colortable[temp1] rem if the player misses 3 times it's game over if lives < 31 then gameOver goto gameLoop rem Game Over Screen gameOver gameOverLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem if the joystick fire button is pressed start a new game if joy0fire then startNewGame rem set note's color to orange COLUP0 = 62 rem draw the screen drawscreen goto gameOverLoop Unfortinately this line is giving me problems: pfpixel arrow1x arrow1y on:pfpixel arrow1x arrow1y+1 on:pfpixel arrow1x arrow1y+2 on If i add this after the last one: pfpixel arrow1x-1 arrow1y on It produces the error ---------- Capture Output ----------> "C:\Atari2600\bB\2600bas.bat" C:\Projects\Atari2600\2600DDR\2600DDR.bas 2600 Basic compilation complete. C:\Projects\Atari2600\2600DDR\2600DDR.bas.asm (1981): error: Syntax Error ''. bytes of ROM space left Unrecoverable error(s) in pass, aborting assembly! > Terminated with exit code 0. Any ideas? 26002600Revolution Edited January 6, 2009 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 6, 2009 Share Posted January 6, 2009 If I remember correctly, you can't have too many pfpixels on the same line. And I could be mistaken, but I thought you weren't supposed to do math using pfpixel, pfhline, and pfvline. Shouldn't it be done using something like a temporary variable? So instead of this: pfpixel arrow1x-1 arrow1y on you'd use this: temp5=arrow1x-1 : pfpixel temp5 arrow1y on Quote Link to comment Share on other sites More sharing options...
jrok Posted January 6, 2009 Share Posted January 6, 2009 If I remember correctly, you can't have too many pfpixels on the same line. And I could be mistaken, but I thought you weren't supposed to do math using pfpixel, pfhline, and pfvline. Shouldn't it be done using something like a temporary variable? So instead of this: pfpixel arrow1x-1 arrow1y on you'd use this: temp5=arrow1x-1 : pfpixel temp5 arrow1y on Yep. You can't do operations inside of a pfpixel/hline/vline. They just want a value (either static or variable). Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted January 6, 2009 Author Share Posted January 6, 2009 Still having problems as it seems i can't get the darn thing to draw a proper arrow. I have attached the code for you to. 26002600 Revolution 2600DDR.bas Quote Link to comment Share on other sites More sharing options...
