Sdw Posted January 12, 2009 Share Posted January 12, 2009 (edited) I'm a newbie when it comes to 2600-coding, but I've got some 6502 experience from C64 coding and after spending a few hours glancing through the Andrew Davie tutorials (very good btw!), I have a general grasp of things and have got some code up and running. However, I was wondering - is there no way to be able to run segments of code that you don't have cycle-exact predictions for? During the drawing of the screen I guess you need to be in cycle-exact mode, however in the overscan and VBL areas, I'd like to be able to do something like start a timer or set an IRQ (but the 2600 doesn't have any IRQs...?), then run some code that I know will take less than 30 rasterlines (but not EXACTLY how much) and then somehow use the timer/IRQ to get back in sync for the three lines of vertical vertical synchro or start of screen, depending on if you are in VBL or overscan. Can this be somehow done? Or is the only solution to split your code into segments that are less one scanline of cycles and use a series of STA WSYNC and keep the line-count intact? -edit- Well, what do you know, I might have been onto something after all. I found this quote in the "main" 2600 programming forum: But for the most part, the timer is usually only used to time the overscan and vertical blank periods. Set a timer, do a whole lot of stuff involving branches, then eat up the remaining time...each frame will reach the end of the loop at exactly the same time. That is pretty much exactly how I wanted it to work. Now I need to learn how to set up the timer, what values are appropriate for a full VBL/full overscan (I'm programming for PAL)? Edited January 12, 2009 by Sdw Quote Link to comment Share on other sites More sharing options...
supercat Posted January 13, 2009 Share Posted January 13, 2009 That is pretty much exactly how I wanted it to work. Now I need to learn how to set up the timer, what values are appropriate for a full VBL/full overscan (I'm programming for PAL)? I would suggest using TIM64 and experimenting with values. To make it easy to detect upcoming or entry, I would suggest that instead of having INTIM count down to zero, you have it count to a value like 125 (tripping at 124). Thus, the code would be something like: lda #125+40 ; Experiment with this value sta TIM64T ... lda #125 ; Next three lines are optional sta WSYNC cmp INTIM bcc INTIM_Wait ; Set 'oops' flag if desired INTIM_Wait: sta WSYNC cmp INTIM bcc INTIM_Wait Rather than calculating the TIM64T values to use, it's often easier in the age of emulation to simply experiment. Make a guess and then adjust up or down as needed. To see if INTIM is 127 or less, you may use the instruction BIT INTIM without disturbing other registers. If the N flag is clear, that means that you have 256 or fewer cycles remaining before you should be at your VBLANK routine (180 or fewer with optional code included). Using such an approach makes it practical to have loops that run at variable speeds and which will take multiple frames to complete (Strat-O-Gems uses that technique heavily, btw). Quote Link to comment Share on other sites More sharing options...
Sdw Posted January 16, 2009 Author Share Posted January 16, 2009 I think I got things working: frameloop: // Start of vertical blank processing lda #0 sta VBLANK lda #2 sta VSYNC // 3 scanlines of VSYNCH signal... sta WSYNC sta WSYNC sta WSYNC lda #0 sta VSYNC // 37 scanlines of vertical blank... lda #127+44 sta TIM64T // DO VARIABLE TIME STUFF HERE!!! !wait: lda INTIM and #$80 bne !wait- sta WSYNC // 242 scanlines of picture here (not included)... // end of screen - enter blanking lda #%01000010 sta VBLANK // 30 scanlines of overscan... lda #127+35 sta TIM64T // DO VARIABLE TIME STUFF HERE!!! !wait: lda INTIM and #$80 bne !wait- sta WSYNC jmp frameloop At least in STELLA it seems to display a stable 23712 cycles/frame, which I guess means things should be OK. Quote Link to comment Share on other sites More sharing options...
