highinfidelity Posted January 15, 2009 Share Posted January 15, 2009 'morning, folks. I have recently read that the main line voltage on the C64C motherboard was dropped to 9V from the previous higher 12V used on the classic Commodore 64. I then wonder if the two models can share their power supply "brick". The aesthetics are similar if not identical, but the drop of required voltage makes me wonder. Anyone knows? Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 15, 2009 Share Posted January 15, 2009 I'd say no. I think it's because the later SID variants required less voltage. Quote Link to comment Share on other sites More sharing options...
Ze_ro Posted January 16, 2009 Share Posted January 16, 2009 This is the first I've heard of it, and in all likelihood, I've often used the "wrong" power supply for a C64C... for whatever that's worth. Keep in mind that no electronic device can ever rely on a perfectly level voltage from a wall socket, so they usually (always?) have power supplies that exceed their required voltages, and then use internal circuitry to step-down the voltage to the system's needs. If you happen to have the correct power supply, then use it... but I'd say you're probably safe to use whatever power supply will fit. --Zero Quote Link to comment Share on other sites More sharing options...
