Tempest Posted February 6, 2009 Share Posted February 6, 2009 Where do halogen lights fit into this? Do they give off more UV than a black light? Tempest Quote Link to comment Share on other sites More sharing options...
mimo Posted February 6, 2009 Author Share Posted February 6, 2009 @Selgus- I have posted a link to the exact bulb I have bought elsewhere in this thread @MG66- Sorry if I misunderstood you, but my question "maybe the amount of UV light is not greatly important, as long as there is some?" was a genuine one By fluorescent light, do you mean the tube lights? would a standard low energy bulb be of any use? @Merlin-There is no missing picture. The XE keyboard is difficult to get a good photograph of the yellowing with my current camera, it is there though. Quote Link to comment Share on other sites More sharing options...
+selgus Posted February 6, 2009 Share Posted February 6, 2009 @Selgus- I have posted a link to the exact bulb I have bought elsewhere in this thread I'm going to be trying to use one of these on a few Ataris and will report back how it works. --Selgus Quote Link to comment Share on other sites More sharing options...
+poobah Posted February 6, 2009 Share Posted February 6, 2009 (edited) As fate would have it, I do happen to have a UV light sensor floating about here somewhere (the sort that tanning places use to check their bulb output). I'll check a couple regular tubes and the black light i am using. BTW, walmart has a 24" black light tube for $10. Edited February 6, 2009 by poobah Quote Link to comment Share on other sites More sharing options...
Tempest Posted February 6, 2009 Share Posted February 6, 2009 Made up 300ml of 12% Hydrogen Peroxide (40 vol) from Sally Can you post a picture of that bottle? Tempest Quote Link to comment Share on other sites More sharing options...
mimo Posted February 6, 2009 Author Share Posted February 6, 2009 Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted February 6, 2009 Share Posted February 6, 2009 I'm unfamiliar with Oxy Laundry Boost. A web search shows lots of different brands. Can someone post a specific brand name that is known to be effective, and is commonly available from a supermarket chain, or a CVS-pharmacy-type of store, in the U.S.? Thanks! Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted February 7, 2009 Share Posted February 7, 2009 (edited) Where do halogen lights fit into this? Do they give off more UV than a black light? Tempest From everything Ive read, the majority of the output of halogen lamps is shifted towards the lower end of the visible spectrum. However, mercury vapor is shifted toward the high end.. and does produce a quite significant percentage of UV.. In fact, if you break the outer glass off of the bulb, only leaving the actual mercury vapor tube in the center, it becomes a pretty good UV lamp.. In fact, it produces "dangerous levels" of UV.. I think it will eventually burn out if you run it like that though.. And mercury vapor is not exactly cheap.. a 175watt bulb runs about $16.00.. A fixture that includes a suitable balast to run it is at least $50.00 for a REALLY cheap one.. But if you happen to have a mercury vapor light laying around, I'd try it. Edited February 7, 2009 by MEtalGuy66 Quote Link to comment Share on other sites More sharing options...
Tempest Posted February 7, 2009 Share Posted February 7, 2009 I was able to find the hydrogen peroxide today. It's not pure as I think it also has some acid in it, but it's the best I could do, hopefully it will work. The thing I can't find anywhere is Xanthan Gum. Is there something else I can use as a thickener? Someone said earlier that Corn Starch doesn't work well? Once I make the mixture how do I store it? How long can I store it? Were there step by step instructions somewhere in this thread? Tempest Quote Link to comment Share on other sites More sharing options...
Merlin Posted February 7, 2009 Share Posted February 7, 2009 (edited) Can you get Arrowroot? Otherwise, try wallpaper paste, that will work, most food tyoe thickeners like casein may work too. Take a look in the supermarket (mall) and see what's out there. The mixture WITHOUT Oxy added will store indefinitely. Once you add the Oxy to use it, you get 48 hours maximum before the peroxide is used up. The steps are earlier in the thread. Feel free at ask questions if required. Edited February 7, 2009 by Merlin Quote Link to comment Share on other sites More sharing options...
iwan-iwanowitsch-goratschin Posted February 7, 2009 Share Posted February 7, 2009 Can you get Arrowroot? Otherwise, try wallpaper paste, that will work, most food tyoe thickeners like casein may work too. Take a look in the supermarket (mall) and see what's out there. The mixture WITHOUT Oxy added will store indefinitely. Once you add the Oxy to use it, you get 48 hours maximum before the peroxide is used up. The steps are earlier in the thread. Feel free at ask questions if required. You have chosen the right name, Merlin! Your input on this subject is awesome! :thumbsup: Quote Link to comment Share on other sites More sharing options...
Merlin Posted February 7, 2009 Share Posted February 7, 2009 (edited) I'm unfamiliar with Oxy Laundry Boost. A web search shows lots of different brands. Can someone post a specific brand name that is known to be effective, and is commonly available from a supermarket chain, or a CVS-pharmacy-type of store, in the U.S.? Thanks! @ Unixcoffee928 Here's a few examples: You will find these in the laundry powder aisle at the mall. Anything that looks like these pots and says "active oxygen" contains TAED and will work. I'm just pleased that people finally believe that this works; the trolling we've had while we were working on this was really bad, but now on most sites we have contacted, someone says "This is the best thread ever!!!" That is the coolect part of all... Edited February 7, 2009 by Merlin Quote Link to comment Share on other sites More sharing options...
JamesD Posted February 7, 2009 Share Posted February 7, 2009 I just can't believe someone has never seen that Billy "I shout all the time" Mayes commercial for Oxy Clean. Talk about annoying. Quote Link to comment Share on other sites More sharing options...
Tempest Posted February 7, 2009 Share Posted February 7, 2009 Can you get Arrowroot? Otherwise, try wallpaper paste, that will work, most food tyoe thickeners like casein may work too. Take a look in the supermarket (mall) and see what's out there. I've only seen corn starch in the grocery store, I assume stuff like arrowroot would be in the same area? I might have to try a 'natural foods' type store. The mixture WITHOUT Oxy added will store indefinitely. Once you add the Oxy to use it, you get 48 hours maximum before the peroxide is used up. So I can just make the base mixture and store it in a jar or something until I need it? Good to know. I assume I should keep it out of sunlight and away from heat and all that. You should have seen the look on the face of the person at the store when I was buying all of this stuff. I'm sure she thought I was either making Crystal Meth, a bomb, or something like that. Tempest Quote Link to comment Share on other sites More sharing options...
Merlin Posted February 7, 2009 Share Posted February 7, 2009 (edited) @ James D It can't be as bad as the 'Cillit Bang' adverts in the UK.....the remixes are good though http://www.youtube.com/results?search_type...t+Bang&aq=f Edited February 7, 2009 by Merlin Quote Link to comment Share on other sites More sharing options...
Merlin Posted February 7, 2009 Share Posted February 7, 2009 (edited) You should have seen the look on the face of the person at the store when I was buying all of this stuff. I'm sure she thought I was either making Crystal Meth, a bomb, or something like that. Tempest Buahahahaha!!!! Classic!!!!! You aren't the first to have said that, mate.....I'm surprised that the SAS haven't kicked my front door in.. yet "But honestly officer, I was just going home to clean my computer...." LOLZ Edited February 7, 2009 by Merlin Quote Link to comment Share on other sites More sharing options...
+poobah Posted February 7, 2009 Share Posted February 7, 2009 I wound up ordering some Xanthan gum on Amazon. It's about $5 for a 6oz jar. Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted February 7, 2009 Share Posted February 7, 2009 Thanks for the info! Should be a fun project! & no, I only turn it on for the History Channel specials, & to catch Richard Lloyd's "Alchemical Guitarist" program, once a month TV is an escapist's drug. Most TV is downtime. Most TV will give you BRAINROT, poor memory, & a short attention span. TV is the modern Opiate For the Masses. TV Drug Ads will turn you into a psychosomatic hypochondriac. TV is a propagandist's dream. TV tells millions of viewers what is funny and what is serious, what is right, & what is wrong, & what is 'important'. Those same millions of viewers share the same exact hallucination simultaneously, no matter where they are on the planet. TV is not for me. Thanks anyway. Quote Link to comment Share on other sites More sharing options...
Merlin Posted February 7, 2009 Share Posted February 7, 2009 @ All If anyone tries this, I would like you to pictures please, before and after, and also record what you used to make the mixture; it all helps with the proof that this is reproduceable and helps me to advise people worldwide as to what to use, as brand names vary from country to country. (And I do like my hardware pr0n ) Quote Link to comment Share on other sites More sharing options...
JamesD Posted February 7, 2009 Share Posted February 7, 2009 @ James D It can't be as bad as the 'Cillit Bang' adverts in the UK.....the remixes are good though http://www.youtube.com/results?search_type...t+Bang&aq=f Billy Mays Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted February 8, 2009 Share Posted February 8, 2009 Well, I'm ready to go!! Going to try a 1200XL case tomorrow. I'll post pictures. Quote Link to comment Share on other sites More sharing options...
Ransom Posted February 8, 2009 Share Posted February 8, 2009 Careful, Guitarman! That peroxide has "maximum lift." Your 1200XL might float away! Quote Link to comment Share on other sites More sharing options...
Longhorn Engineer Posted February 8, 2009 Share Posted February 8, 2009 Your 1200XL might float away! Fizzy Lifting Drinks Sorry don't have time to try it on the SNES. Homework is killing me. Quote Link to comment Share on other sites More sharing options...
JamesD Posted February 8, 2009 Share Posted February 8, 2009 I've only seen corn starch in the grocery store, I assume stuff like arrowroot would be in the same area? I might have to try a 'natural foods' type store. Arrowroot is normally with the spices. Quote Link to comment Share on other sites More sharing options...
Merlin Posted February 8, 2009 Share Posted February 8, 2009 (edited) @ Moderators Would it be possible for this thread to be made a "Sticky"? Thanks Edited February 8, 2009 by Merlin Quote Link to comment Share on other sites More sharing options...
