MausGames Posted February 1, 2009 Share Posted February 1, 2009 When I include a vblank routine in my games, I sometimes get the error: --> vblk2 f674 Any idea what this means? Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted February 2, 2009 Share Posted February 2, 2009 When I include a vblank routine in my games, I sometimes get the error: --> vblk2 f674 Any idea what this means? If it doesn't prevent DASM from creating a working BIN, then it isn't an error. Here's an example: rem * test vblank a = 0 b = $00 loop drawscreen goto loop vblank a = a + 1 if a = 30 then a = 0 : b = b + 1 COLUBK = b return This simple little program is just a display loop, but it uses a vblank routine to increment the background color. This is the output I get when I compile it with version 1.01 of batari Basic: ---------- Capture Output ---------- > "C:\Atari2600\bB\2600bas.bat" "C:\Atari2600\bB\Projects\test_vblank.bas" batari Basic v1.01 (C)2005-2007 User-defined default.inc found in the current directory 2600 Basic compilation complete. User-defined 2600basicheader.asm found in current directory User-defined std_kernel.asm found in current directory User-defined startup.asm found in current directory User-defined pf_drawing.asm found in current directory User-defined pf_scrolling.asm found in current directory User-defined std_routines.asm found in current directory User-defined std_overscan.asm found in current directory User-defined score_graphics.asm found in current directory User-defined 2600basicfooter.asm found in current directory DASM V2.20.07, Macro Assembler (C)1988-2003 bytes of ROM space left --> vblk2 f468 2793 bytes of ROM space left 2793 bytes of ROM space left Complete. > Terminated with exit code 0. Notice the line that says "--> vblk2 f468," which is very similar to what you posted (just a different address). Despite the presence of this line in the output, the BIN is successfully created and it runs as expected. Then again, I'm using Crimson Editor rather than Visual bB, and I don't know if Visual bB might interpret that line as some kind of error. Michael Quote Link to comment Share on other sites More sharing options...
MausGames Posted February 2, 2009 Author Share Posted February 2, 2009 It does still compile just fine, I was just wondering if this error meant that the main loop and vblank were clashing in some way that would cause issues on real hardware. If it's something to ignore, that's good, but it's still annoying because with vbB it garbles the "ROM space left" section so I can't tell how much space I have left in some of the banks. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted February 3, 2009 Share Posted February 3, 2009 It does still compile just fine, I was just wondering if this error meant that the main loop and vblank were clashing in some way that would cause issues on real hardware. If it's something to ignore, that's good, but it's still annoying because with vbB it garbles the "ROM space left" section so I can't tell how much space I have left in some of the banks. I did try compiling the code for my little example with Visual bB, but I couldn't figure out how to capture the output. Michael Quote Link to comment Share on other sites More sharing options...
MausGames Posted February 3, 2009 Author Share Posted February 3, 2009 Doesn't all the info you need appear under the "messages" tab? Or am I misunderstanding what you mean by output? Quote Link to comment Share on other sites More sharing options...
jwierer Posted February 3, 2009 Share Posted February 3, 2009 It does still compile just fine, I was just wondering if this error meant that the main loop and vblank were clashing in some way that would cause issues on real hardware. If it's something to ignore, that's good, but it's still annoying because with vbB it garbles the "ROM space left" section so I can't tell how much space I have left in some of the banks. I did try compiling the code for my little example with Visual bB, but I couldn't figure out how to capture the output. Michael Right-click copy doesn't work for you? -Jeff Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted February 3, 2009 Share Posted February 3, 2009 Doesn't all the info you need appear under the "messages" tab? Or am I misunderstanding what you mean by output? You say "the 'messages' tab" as if it's something I have on my screen. But I don't have any such tab. Oh wait. You mean the button at the bottom of the screen. Duh, it's already selected, but I didn't have the bottom pane raised high enough to see any messages. Never mind! Thanks fur helpin me git ejykated. Michael Quote Link to comment Share on other sites More sharing options...
CurtisP Posted February 4, 2009 Share Posted February 4, 2009 When I include a vblank routine in my games, I sometimes get the error: --> vblk2 f674 Any idea what this means? I'm pretty sure it's just reporting what memory location that label resolved to, most likely because it changed between passes. Quote Link to comment Share on other sites More sharing options...
MausGames Posted February 4, 2009 Author Share Posted February 4, 2009 Thanks Quote Link to comment Share on other sites More sharing options...
MausGames Posted February 21, 2009 Author Share Posted February 21, 2009 Without vblank: 2600 Basic compilation completed. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 3878 bytes of ROM space left in bank 1 3921 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 2331 bytes of ROM space left in bank 4 Compilation completed at 2/21/2009 1:49:57 PM view output file:///C:/Atari2600/bB/bin Post compilation files deleted With vblank: 2600 Basic compilation completed. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 3878 bytes of ROM space left in bank 1 3921 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 --> vblk2 f52c Compilation completed at 2/21/2009 1:49:07 PM view output file:///C:/Atari2600/bB/bin Post compilation files deleted You can see why this is bad... Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted February 21, 2009 Share Posted February 21, 2009 (edited) Without vblank:2600 Basic compilation completed. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 3878 bytes of ROM space left in bank 1 3921 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 2331 bytes of ROM space left in bank 4 Compilation completed at 2/21/2009 1:49:57 PM view output file:///C:/Atari2600/bB/bin Post compilation files deleted With vblank: 2600 Basic compilation completed. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 3878 bytes of ROM space left in bank 1 3921 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 --> vblk2 f52c Compilation completed at 2/21/2009 1:49:07 PM view output file:///C:/Atari2600/bB/bin Post compilation files deleted You can see why this is bad... Fred, if you're reading this, I was looking in the source where it prints the bytes free, and saw this in 2600bas.c: printf(" echo \" \",[(scoretable - *)]d , \"bytes of ROM space left"); if (bs == 8) printf(" in bank 2"); if (bs == 16) printf(" in bank 4"); if (bs == 32) printf(" in bank 8"); printf("\")\n"); printf(" \n"); printf(" \n"); printf(" \n"); I'm no C programmer, but that first printf after the third if definitely looks bad to me-- there are three quotation marks in it. I'm not looking at the latest, greatest source code, so you may have corrected this already; but I think I've got the latest source you posted. Michael Edit: Actually, I just realized that the first printf has five quotation marks in it. Does C let you use an odd number of quotation marks? In every other language that I'm familiar with, quotation marks must occur in pairs. Anyway, I don't have the latest source, and I don't want to try my hand at tinkering with the source and recompiling it. Edited February 21, 2009 by SeaGtGruff Quote Link to comment Share on other sites More sharing options...
kenfused Posted February 21, 2009 Share Posted February 21, 2009 printf("\")\n"); I'm no C programmer, but that first printf after the third if definitely looks bad to me-- there are three quotation marks in it. I'm not looking at the latest, greatest source code, so you may have corrected this already; but I think I've got the latest source you posted. Michael Edit: Actually, I just realized that the first printf has five quotation marks in it. Does C let you use an odd number of quotation marks? In every other language that I'm familiar with, quotation marks must occur in pairs. Anyway, I don't have the latest source, and I don't want to try my hand at tinkering with the source and recompiling it. The second quote has a backslash in front of it so that quote is an escaped quote (one way to actually print out a quote). So the one print statement above prints a quote, a right parenthesis, and a new line. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted February 22, 2009 Share Posted February 22, 2009 The second quote has a backslash in front of it so that quote is an escaped quote (one way to actually print out a quote).So the one print statement above prints a quote, a right parenthesis, and a new line. Thanks, kenfused. I Googled "printf c quotation" after I posted, and saw what it said about /", so I went over the lines again carefully, and I see what they're doing-- cobbling together an echo statement with quotation marks in it. But there *is* an extra character in one of the printf statements-- an extraneous right parenthesis-- although it has no negative effect as far as I know, it just causes an unnecessary ) to appear at the end of the echo statement. Mausgames, I've modified the 2600bas.bat file to "sed out" the vblk2 message, along with a few other messages that came up in my test program after I took out the vblk2 message. Save or rename your existing 2600bas.bat file so you don't lose it (just in case), then unzip this one and try it. Michael 2600bas.zip Quote Link to comment Share on other sites More sharing options...
MausGames Posted February 23, 2009 Author Share Posted February 23, 2009 (edited) That gets me: 2600 Basic compilation completed. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 1006 bytes of ROM space left in bank 1 3923 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 Possible duplicate label: L079 f553 2242 bytes of ROM space left in bank 4 1006 bytes of ROM space left in bank 1 3923 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 2242 bytes of ROM space left in bank 4 Compilation completed at 2/22/2009 6:31:39 PM view output file:///C:/Atari2600/bB/bin Post compilation files deleted Thanks, now I can tell how many bytes are left in every bank, with or without vblank routine. It still seems like it would be able to put out something in a nicer format, this would do: DASM V2.20.07, Macro Assembler ©1988-2003 1006 bytes of ROM space left in bank 1 3923 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 2242 bytes of ROM space left in bank 4 Possible duplicate label: L079 f553 Compilation completed at 2/22/2009 6:31:39 PM Edited February 23, 2009 by MausGames Quote Link to comment Share on other sites More sharing options...
MausGames Posted February 25, 2009 Author Share Posted February 25, 2009 When I switch it to a 32k bin, I get: 2600 Basic compilation completed. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 bytes of ROM space left in bank 5 bytes of ROM space left in bank 6 bytes of ROM space left in bank 7 bytes of ROM space left in bank 8 3973 bytes of ROM space left in bank 1 3923 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 4052 bytes of ROM space left in bank 4 4052 bytes of ROM space left in bank 5 4052 bytes of ROM space left in bank 6 1006 bytes of ROM space left in bank 7 Possible duplicate label: L084 f4dd Compilation completed at 2/24/2009 9:30:36 PM view output file:///C:/Atari2600/bB/bin Post compilation files deleted Quote Link to comment Share on other sites More sharing options...
+batari Posted February 25, 2009 Share Posted February 25, 2009 (edited) When I switch it to a 32k bin, I get: 2600 Basic compilation completed. DASM V2.20.07, Macro Assembler ©1988-2003 bytes of ROM space left in bank 1 bytes of ROM space left in bank 2 bytes of ROM space left in bank 3 bytes of ROM space left in bank 4 bytes of ROM space left in bank 5 bytes of ROM space left in bank 6 bytes of ROM space left in bank 7 bytes of ROM space left in bank 8 3973 bytes of ROM space left in bank 1 3923 bytes of ROM space left in bank 2 4052 bytes of ROM space left in bank 3 4052 bytes of ROM space left in bank 4 4052 bytes of ROM space left in bank 5 4052 bytes of ROM space left in bank 6 1006 bytes of ROM space left in bank 7 Possible duplicate label: L084 f4dd Compilation completed at 2/24/2009 9:30:36 PM view output file:///C:/Atari2600/bB/bin Post compilation files deleted Can you post the generated asm file? There's a possibility you're running into the DASM branch bug, and I've fixed this with a private build and can try out the asm file here with the old and new versions. EDIT: Is the binary building properly? If so, disregard some of what I said - If you encounter the branch bug, DASM will not produce a valid binary. I thought I'd mention that my DASM build does address what you mentioned above about a nicer output format. I don't know if I've ever posted the new DASM build, so I might as well do it here. I think this is the new build, anyway. bBdasm.zip Edited February 25, 2009 by batari Quote Link to comment Share on other sites More sharing options...
