Atari8guy Posted February 8, 2009 Share Posted February 8, 2009 Hi All, Has anyone had any luck getting either Visicalc or Swift Spreadsheet to run under Spartados....I'd like to put on or the other on my main HD partition, but I can't seem to figure out how to get them to run. Thanks, Quote Link to comment Share on other sites More sharing options...
Marius Posted February 9, 2009 Share Posted February 9, 2009 Did you know the Spreadsheet of Mini Office is able to run with SpartaDos 3.3 You can start several Mini Office parts, by typing the filename, including the MO2 extention. Give it a try! I'll check the other spreadsheets if you like. Marius Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted February 9, 2009 Share Posted February 9, 2009 Did you know the Spreadsheet of Mini Office is able to run with SpartaDos 3.3 You can start several Mini Office parts, by typing the filename, including the MO2 extention. Give it a try! I'll check the other spreadsheets if you like. Marius Where can I find mini-office? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted February 10, 2009 Share Posted February 10, 2009 (edited) Where can I find mini-office? Here it is: Mini_Office_II.zip I found it on XL Search. It appears to work with SDX 4.42; haven't tried it with Sparta 3.2. Edited February 10, 2009 by flashjazzcat 1 Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted February 10, 2009 Author Share Posted February 10, 2009 That sounds great, I hope its a good one (for an 8 bit) I will try it out later.... Any other spreadsheets that can be loaded by Spartados? Quote Link to comment Share on other sites More sharing options...
dwhyte Posted February 16, 2009 Share Posted February 16, 2009 I have SynCalc working fine under SpartaDOS... Now if I can only get SynFile working... SynCalc.zip Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted February 16, 2009 Author Share Posted February 16, 2009 Very cool, thank you muchly!!!! Works great under disk based sparta...I couldn't get it to load under Sparta X though....(only tried the emulator). Any thoughts...or just not gonna work? Quote Link to comment Share on other sites More sharing options...
dwhyte Posted February 16, 2009 Share Posted February 16, 2009 Very cool, thank you muchly!!!! Works great under disk based sparta...I couldn't get it to load under Sparta X though....(only tried the emulator). Any thoughts...or just not gonna work? You need to use the X command under SDX to get it to work Quote Link to comment Share on other sites More sharing options...
