jrok Posted February 20, 2009 Share Posted February 20, 2009 (edited) I've been having some trouble getting fixed point math to work with bankswitched games. I've tried to troubleshoot the fixed-point module, but I feel like my head is screwed on backwards looking at it. compilation fails. In the version of fixed_point_math.asm that I have, it assigns for bankswitched games with: ifconst bankswitch Assign88to44bs: ; A(4.4) = A,X(8.8) stx temp1 rol temp1 asl rol temp1 asl rol temp1 asl rol temp1 asl RETURN ;assignment from 4.4 to 8.8 ; Assign44to88bs: ; A,X(8.8) = A(4.4) sta temp1 lda #0 asl temp1 sbc #0; eor #$ff; do sign extend rol asl temp1 rol asl temp1 rol asl temp1 rol ldx temp1 RETURN endif If the program contains no operations, then it compiles fine. But compilation fails on any operation, additive or subtractive. Is this a portion of the module that just wasn't completed? If anyone has found a workaround, I gladly will send you chocolates and a case of beer. I am using the latest-greatest 2600basic.exe and DASM V2.20.07. Thanks in advance! fixed_point_math.zip bankswitch.zip EDT: I just attached a sample program (courtesy of Michael Rideout) that illustrates the problem. Compile fails on this operation: if c{1} then p0_y = p0_y - momentum jumping.bas Edited February 20, 2009 by jrok Quote Link to comment Share on other sites More sharing options...
+batari Posted February 20, 2009 Share Posted February 20, 2009 I'm not sure why compilation fails - by my limited analysis, it should compile but not work correctly unless all calculations are in the first bank. I had long forgotten about this issue. It arises because programmers typically include the fixed point math routines at the beginning of the code and they go in the first bank, so it didn't work with the framework that put certain graphics routines in the last bank, and I never fixed it. If compilation is failing, can you show us the error generated? You are including the fixed point math module, right? Quote Link to comment Share on other sites More sharing options...
jrok Posted February 20, 2009 Author Share Posted February 20, 2009 Hi Fred. Thanks for the help! I'm not sure why compilation fails - by my limited analysis, it should compile but not work correctly unless all calculations are in the first bank. I had long forgotten about this issue. It arises because programmers typically include the fixed point math routines at the beginning of the code and they go in the first bank, so it didn't work with the framework that put certain graphics routines in the last bank, and I never fixed it. Yep, one of the first things I tried wsa including the routines in the last bank, but that didn't work. If compilation is failing, can you show us the error generated? You are including the fixed point math module, right? If it's an addition operation it fails on: Add44to88 0000 ???? (R ) If subtraction: Sub44from88 0000 ???? (R ) I added an example BAS file to my original post above if that's any help. The program compiles and functions without bankswitching routines, but fails with them. Thanks again! Jarod. Quote Link to comment Share on other sites More sharing options...
+batari Posted February 20, 2009 Share Posted February 20, 2009 (edited) That helps. First, the compiler generates a warning on line 3, telling us the include is ignored because it was placed after the "includesfile" command. Moving it before the includesfile does not allow it to compile, however - the includesfile alone is not enough to fully specify bankswitching - you also need to set the ROM size. It's not necessary to specify the includesfile at all, actually, unless you're using a customized one with a different name. So to fix, place your include fixed_point_math first, then set romsize to whatever your size is. And... I'll see if I can fix the issue with fixed point math routines (and other math routines for that matter) working only in the first bank. Edited February 20, 2009 by batari Quote Link to comment Share on other sites More sharing options...
jrok Posted February 21, 2009 Author Share Posted February 21, 2009 That helps. First, the compiler generates a warning on line 3, telling us the include is ignored because it was placed after the "includesfile" command. Moving it before the includesfile does not allow it to compile, however - the includesfile alone is not enough to fully specify bankswitching - you also need to set the ROM size. It's not necessary to specify the includesfile at all, actually, unless you're using a customized one with a different name. So to fix, place your include fixed_point_math first, then set romsize to whatever your size is. And... I'll see if I can fix the issue with fixed point math routines (and other math routines for that matter) working only in the first bank. Thanks Fred! Compiles fine now. Where do I send the chocolate and beer? Cheers, Jarod Quote Link to comment Share on other sites More sharing options...
