Cupcakus Posted September 20, 2002 Share Posted September 20, 2002 I know it has been discussed many times before, but the only step by step solution given is in this thread http://www.atariage.com/forums/viewtopic.php?t=3214 I'm not sure what you are getting at here Thomas... Here is where I'm at, can anyone help me along? Just for laughs I chose the Frogger2 bin to attempt this. I split the file into two 4k bits, no problem. I discovered the correct ORG address for the first file and dissasembelled it... no problem. Now I have another 4k file, I found the ORG address for this file and dissasembelled it. Now I have two disassembelled files that seem fine. No strange code, no BRK opcodes. In File #1 I replaced the ORG line with an RORG line, then directly above it I put a ORG $0000 line. In File #2 I replaced the ORG line with an RORG line, then directly above it I put a ORG $1000 line. I deleted everything above the ORG line in file #2 (I left that data in-tact for file #1) and then copied everything from from file #2 to the end of file #1. When I compile I get several errors: Mostly "Label Mismatch" and "Branch out of Range" What am I missing? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 20, 2002 Share Posted September 20, 2002 You will probably have two START labels (one in each bank). You should rename one of them. And a lot of definitions at the top of file #2 will have been defined in file #1 already. You should delete all defintions that are lower than $1000 and add include "vcs.h" (if you have that file!) instead. BTW: I would start my ORGs at $1000 to avoid confusing with TIA register addresses and to force the assembler to use non ZP-adresses when accessing the ROM. Quote Link to comment Share on other sites More sharing options...
Cupcakus Posted September 20, 2002 Author Share Posted September 20, 2002 It's worse than that. DiStella names it's labels after the address of the line of code. So the instruction at $F55E is labeled LF55E, the problem is that there are about 30 or so labels in both files with the same address, thus the same label in each file. When I put the two together I get mismatch errors. How can I configure DiStella to give each file a different kind of label? DiStella(ing) an 8k+ file doesn't seem feasable. If anyone has accomplished this, shoot me the source file you ended up with that compiled. I will most likely be able to compare it to my source and correct the issues. Thanks! Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted September 20, 2002 Share Posted September 20, 2002 It's worse than that. DiStella names it's labels after the address of the line of code. So the instruction at $F55E is labeled LF55E, the problem is that there are about 30 or so labels in both files with the same address, thus the same label in each file. When I put the two together I get mismatch errors. How can I configure DiStella to give each file a different kind of label? Maybe that's too easy a solution, but how about Search & Replace "LF" with "LD" in one of the files for example? Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Cupcakus Posted September 20, 2002 Author Share Posted September 20, 2002 OK.. (shrug) I came to the conclusion that DiStella can't do Frogger2. If someone can prove me wrong here, I would love it! I successfully disassembelled, assembelled and ran Joust, Raiders of the Lost Ark, and DK Jr. So I know my methods were right, it just seems I can't get Frogger2 to give a valid output on the first file, no matter what ORG i give it. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 20, 2002 Share Posted September 20, 2002 It's worse than that. DiStella names it's labels after the address of the line of code. So the instruction at $F55E is labeled LF55E, the problem is that there are about 30 or so labels in both files with the same address, thus the same label in each file. When I put the two together I get mismatch errors. How can I configure DiStella to give each file a different kind of label? You must use two configuration files for DiStella that use different ORG adresses. Hope that helps. DiStella(ing) an 8k+ file doesn't seem feasable. No, it is possible with DiStella. I had to do this for my 8 and 16K PAL to NTSC conversions. It wasn't fun, but it worked. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 20, 2002 Share Posted September 20, 2002 Update: I just did some disassembling with Frogger II myself. The ORG for the first part is definitely $d000. I think the main problem is the a bit more complicated bankswitching method (four 1K slices) that Parker uses. Therefore you have access to the last, fixed 1K ($fc00-$ffff) slice in both parts. Here is my .cfg-file for the 1st part: ORG d000 CODE d000 d08c CODE d09d d102 CODE d10b d14f CODE d158 d19f CODE d1b0 d200 CODE d203 d319 CODE d31c d328 CODE d32b d33b CODE d33e d3c3 CODE d3c6 d3d1 CODE d3d6 d47a CODE d481 d58d CODE d590 d66f CODE d672 da3f CODE da42 dab4 CODE dab7 dbff CODE dc72 dcf9 CODE dd02 dd72 CODE dd7b dfde After disassembling you can remove all output before ORG (those addresses pointing at $dxxx are really missing labels inside other slices) and include vcs.h. BTW: The BRK instructions are a very clever way for jumping into a subroutine using the break vector ($fd82) Quote Link to comment Share on other sites More sharing options...
Cupcakus Posted September 20, 2002 Author Share Posted September 20, 2002 Thanks a lot Thomas. A couple more things though. #1. I used $D000 myself however there are several JMP's to $BXXX range that surface, this could just be my inexperience talking but why isn't it $B000? #2. How did you come about getting every little segment for the CFG file. I tried that and could not figure it out. Your help has been greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 20, 2002 Share Posted September 20, 2002 #1. I used $D000 myself however there are several JMP's to $BXXX range that surface, this could just be my inexperience talking but why isn't it $B000? I'm not sure, maybe there are slices that are 'orged' at $b000. You should check, if there is a certain range in those addresses or if they are all valid adresses inside a part with different ORGs. In the end there should be a clear and perfect pattern, but finding that requires some try and error. And there is a good chance that those $bxxx addresses are just lazy coded $dxxx addresses. #2. How did you come about getting every little segment for the CFG file. I tried that and could not figure it out. Mainly by looking a the code and some try and error. Start with defining the whole file as CODE. If you get code that doesn't make sense or includes a lot of 'illegal' opcodes, it's most likely part of a table. Then you have to find the start and end of that table and redefine your CODE ranges. With some experience non-code will become very obvious and the whole process will become much faster. BTW: Using the trace mode of z26 helps finding the last details too. Quote Link to comment Share on other sites More sharing options...
