danwinslow Posted March 25, 2009 Share Posted March 25, 2009 I am having trouble getting a stable switch of a new dlist and screen memory area. I am setting up the dlist and screen ram, and then writing the new dlist address into 560 and then the new screen address into 88. If I set the two immediately one after the other, I usually get a garbled screen and a crash. If I have a pause between them, such as waiting on a keypress, then it always works. This makes me wonder if something happens during the fast assignment ( like a vblank or something ) and one gets partially activated or the shadows are getting out of sync or something like that. Anyway, I wanted to know what the usual way of doing this is, particularly if there are some other steps I'm missing besides just assigning 560 & 88. The dlist itself is just a copy of the standard gr. 0, with the LMS pointing to the same screen memory area as is getting written into 88. set up screen memory set up dlist to point to screen memory write screen addr into 88 write dlist addr into 560 Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 25, 2009 Share Posted March 25, 2009 Why are you changing SAVMSC (88 and 89) ? You only need to worry about that if you're using the OS to put characters/graphics onscreen. In such cases, you shouldn't do it in the VBlank - if the main program's doing screen I/O and the address suddenly gets changed then you'll get corruption. Also, if you've got graphics + a Text Window, some of the Page Zero graphics variables, including SAVMSC get swapped over with ones in higher up OS RAM on occasions where the text window are accessed. If you "half bake" the Display List pointer, worst thing that happens is you might get a short burst of unwanted garbage. Quote Link to comment Share on other sites More sharing options...
danwinslow Posted March 25, 2009 Author Share Posted March 25, 2009 Yes, I'm planning on writing to the screen. I'm not doing anything during the vblank. The graphics mode is just the usual gr. 0. Quote Link to comment Share on other sites More sharing options...
danwinslow Posted March 25, 2009 Author Share Posted March 25, 2009 (edited) Ok, I think this is happening because I am immediately starting a screen write...if it starts to happen before the vblank loads shadow, then the shadows will get updated to new values in the middle of the screen write code, which is a bad thing. So inserting a wait for vblank is probably called for right after setting the new values, such that teh screen write operation does not commence until after the next vblank. Edited March 25, 2009 by danwinslow Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 25, 2009 Share Posted March 25, 2009 It shouldn't matter. There's not "shadows of shadows" except for the text window like I mentioned. But, there is stuff like the cursor... maybe try turning it off because the S: and E: does save/restore type stuff on the cursor and changing screen memory's location might upset it. Quote Link to comment Share on other sites More sharing options...
