flashjazzcat Posted April 15, 2009 Share Posted April 15, 2009 (edited) What's the best way to establish whether a MyDOS disk is single or double density? The SIO Status command? I need something which will work with RAMdisks, too; I'm basically taking the sector count from an Atari DOS 2.5/MyDOS directory listing, turning it into a double-byte hex value, then multiplying it by 128 or 256 to give the actual length of a file. SDX has a disk info command which you can issue from CIO: I'm sure we can assume a DOS 2.5 disk has 128 bytes (actually 125 of data) per sector, but MyDOS could be either, and I'm not aware of it having a "get disk info" command. Edited April 15, 2009 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Mathy Posted April 15, 2009 Share Posted April 15, 2009 Hello flashjazzcat You can use the Get Percom block command. But you have to do an actual read before you can be sure the data sent back is right. greetings Mathy Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 15, 2009 Author Share Posted April 15, 2009 You can use the Get Percom block command. But you have to do an actual read before you can be sure the data sent back is right. Thanks! The Percom block is what I was trying to remember... it's been a long, long time since I did any SIO programming. Quote Link to comment Share on other sites More sharing options...
