eyg2181 Posted April 26, 2009 Share Posted April 26, 2009 Recently, I got my atari light sixer working properly (sort of). I literally had to re-solder the power input and all six switches, however I don't know how to go about fixing the switches. When I got the unit off eBay a few years ago the power was very touchy, if I moved the power cord it would turn off, that's fixed now, but im guessing what detatched the switches from the circuitboard was use. All six switches are very hard to push/switch, any ideas on how to loosen them up so they don't break off the board again? How they got that way to begin with is beyond me, I guess sitting in an attic or basement for 20 years might do it. With my atari four switch and my sears light sixer I can move the switches eaisly, but in the atari light sixer they get stuck half way down, I try to turn it on too quick and it gets stuck, I gotta pull it back down (while trying not to break it) and then try to push it up again. Any ideas much appreciated, thanks. Is this a common issue with the atari light sixer? Quote Link to comment Share on other sites More sharing options...
shadow460 Posted April 26, 2009 Share Posted April 26, 2009 open the unit and clean the switches out with a Q tip and rubbing alcohol. You should be able to get the Q tip in the ends of the switches. To clean one end, you'll have to flip the switch to the opposite position. Quote Link to comment Share on other sites More sharing options...
Benzman66 Posted April 26, 2009 Share Posted April 26, 2009 Do what I do, open the console and give the switches a few shots of WD-40 at the top and up the bottom of each switch. Always has cured the problem for me! Quote Link to comment Share on other sites More sharing options...
eyg2181 Posted April 26, 2009 Author Share Posted April 26, 2009 Thanks for the help. I know what I'm doing when I get home from work Quote Link to comment Share on other sites More sharing options...
mrspring Posted April 26, 2009 Share Posted April 26, 2009 dunno about WD40 - more like servisol.. i think a squirt of switch-cleaner is whats needed, not a caustic lube.. Quote Link to comment Share on other sites More sharing options...
eyg2181 Posted April 26, 2009 Author Share Posted April 26, 2009 I'm gonna try alcohol first before wd40 Quote Link to comment Share on other sites More sharing options...
