phaeron Posted May 13, 2009 Share Posted May 13, 2009 I've been trying to tune the cycle timing in my Atari emulator to be exact compared to a real Atari, and have come up with some results that don't quite match what I've seen discussed in this forum... so I figured I'd ask to see if anyone could spot where I may have gone wrong. Here are my WIP charts: http://www.virtualdub.org/other/antic-timings.pdf I made these with the help of a little 6502 test program that uses the RANDOM register to count cycles. One thing that I'm unsure about is the timing of player/missile DMA. I have an elaborate text chart by Bennet that shows missile DMA starting 11 cycles prior to character name DMA on wide mode 2 scan line, with three idle cycles after LMS address fetch. My profiling results on a real Atari seem to indicate that P/M and display list DMA occurs one cycle later, however, so that if missile DMA starts on cycle 0, character name DMA starts at cycle 10. Most everything else appears to agree, including WSYNC and refresh timing. The charts are numbered so that the CPU restarts execution after STA WSYNC at cycle 105, with one cycle of the next instruction already having been executed before the CPU was halted. The other thing I need verification on is exactly when VCOUNT steps. It seems to happen on cycle 112, but I haven't found that documented anywhere. Can any ANTIC experts comment? Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 13, 2009 Share Posted May 13, 2009 Nice charts (accuracy check pending of course). Missile DMA always occurs on cycle 113. Then you have DList Instruction if needed on cycle 0. IIRC, if PMG DMA isn't enabled, it fetches the operands if needed on the following 2 cycles. Otherwise it uses the 4 cycles (1-4) for Player DMA. Remember of course that many documentation is wrong re PMGs - the DMA occurs each line regardless of if they're in 1 or 2 line mode (otherwise, VDELAY just plain wouldn't work). If PMG DMA is active, then cycles 5,6 are DList operand if needed. How are you utilizing RANDOM to determine cycle counts? Are you loading it then comparing to some pre-calculated table? VCOUNT - not sure here, but cycle 112 sounds feasible. It would be easy enough to test... just have a program issue WSYNC, then try different delays to skew a subsequent LDA VCOUNT instruction. Best to do it with DMACTL=00 so nothing gets in the way. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 13, 2009 Share Posted May 13, 2009 I should add - GTIA behaviour, re PMG DMA. GTIA actually "thinks" that Missile DMA is happening the first time a HALT comes from Antic after a HBlank command is issued on AN0-AN2. As such, if Antic doesn't have PMG DMA enabled, it can mistakenly think the DList instruction is the missiles (and think subsequent bus data is the Players). Of course, if no HALT occurs during HBlank, GTIA doesn't bother trying to reload the GRAF registers. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 13, 2009 Author Share Posted May 13, 2009 I can't take credit for the chart designs, as they're inspired by Bennet's text charts. I don't see the display list address timing you're describing -- AFAICT, any LMS/jump address is always fetched five cycles after the instruction byte, whether or not P/M graphics is enabled. I've attached a screenshot of my test application running on an NTSC 800XL. The three lines are mode 2 row 2 with P/M off, mode 7 row 0 with P/M off, and mode 7 row 0 with P/M on. The first five cycles are prior to LDA RANDOM right after STA WSYNC, followed by missile DMA, display list DMA, player DMA, and address DMA. Notice that the display list DMA doesn't appear to move. To count cycles, I set AUDCTL bit 7 to 1, and then repeat the test until the LDA RANDOM right after STA WSYNC returns $00. Because the noise generator is running in 9-bit mode, and the POKEY noise generators are XOR-based LFSRs, if the 8 bits sampled by RANDOM are 0 then the ninth bit must be a 1. This establishes a predictable pattern from which my test code can count cycles based on subsequent RANDOM values. It's a bit annoying since it can take over a minute for the noise LFSR to hit just the right phase, but it's far more reliable than the method I was using before, which was to time sprite collisions. Missile DMA always occurs on cycle 113. Then you have DList Instruction if needed on cycle 0.IIRC, if PMG DMA isn't enabled, it fetches the operands if needed on the following 2 cycles. Crap, just "fixed" that. Maybe I'll have to unfix it. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 13, 2009 Share Posted May 13, 2009 Sorry about that... yeah, the info was a little out... I'd forgotten some of it. The DList Instructions are fetched on the same cycles regardless of if PMGs are active. Quote Link to comment Share on other sites More sharing options...
