Zoyx Posted May 20, 2009 Share Posted May 20, 2009 I've been able to load XEX files with APE/SIO2PC. How do I load ROM/BIN files? Thanks. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 20, 2009 Share Posted May 20, 2009 You can't do that directly. They're just dumps of cartridges and in many cases haven't been cracked, so have self-destruct code. Also, banked cartridges like later XE games won't work at all (Fandal has converted a few to work on 130XE). But, you can run older 8K and 16K (?) ROMs from an Atarimax Flashcart. Most older cart games and some new ones are available as XEX or ATR, so it's worth your while to look around for such images. Quote Link to comment Share on other sites More sharing options...
atariksi Posted May 21, 2009 Share Posted May 21, 2009 You can't do that directly. They're just dumps of cartridges and in many cases haven't been cracked, so have self-destruct code. Also, banked cartridges like later XE games won't work at all (Fandal has converted a few to work on 130XE). But, you can run older 8K and 16K (?) ROMs from an Atarimax Flashcart. Most older cart games and some new ones are available as XEX or ATR, so it's worth your while to look around for such images. Self-destruct--- meaning they are checking for read-only condition of the code or some flag that cartridge is inserted? Otherwise, you should be able to upload it to same RAM area as cartridge and run it (for 8K/16K carts). Perhaps, you can also run A2600 cartridge images by emulating them on Atari 8-bit. Quote Link to comment Share on other sites More sharing options...
atariksi Posted May 22, 2009 Share Posted May 22, 2009 You can't do that directly. They're just dumps of cartridges and in many cases haven't been cracked, so have self-destruct code. Also, banked cartridges like later XE games won't work at all (Fandal has converted a few to work on 130XE). But, you can run older 8K and 16K (?) ROMs from an Atarimax Flashcart. Most older cart games and some new ones are available as XEX or ATR, so it's worth your while to look around for such images. If you just add the 6-byte file header to the ROM file and add the footer for loading INIT and START addresses to 0x2E2 and 0x2E0 respectively, you can load ROM files like Popeye, Topper, Millipede, etc. on real Atari. However, River Raid and Gyruss ROM files that I just tried did not load using this method. Quote Link to comment Share on other sites More sharing options...
Zoyx Posted May 22, 2009 Author Share Posted May 22, 2009 You can't do that directly. They're just dumps of cartridges and in many cases haven't been cracked, so have self-destruct code. Also, banked cartridges like later XE games won't work at all (Fandal has converted a few to work on 130XE). But, you can run older 8K and 16K (?) ROMs from an Atarimax Flashcart. Most older cart games and some new ones are available as XEX or ATR, so it's worth your while to look around for such images. If you just add the 6-byte file header to the ROM file and add the footer for loading INIT and START addresses to 0x2E2 and 0x2E0 respectively, you can load ROM files like Popeye, Topper, Millipede, etc. on real Atari. However, River Raid and Gyruss ROM files that I just tried did not load using this method. Never did that before, so I will have to look it up. I think I will invest in a flash cart or two. Just did a vid showing off my new Atari 800... http://vimeo.com/4785372 . Thanks for the help... Quote Link to comment Share on other sites More sharing options...
atariksi Posted May 22, 2009 Share Posted May 22, 2009 You can't do that directly. They're just dumps of cartridges and in many cases haven't been cracked, so have self-destruct code. Also, banked cartridges like later XE games won't work at all (Fandal has converted a few to work on 130XE). But, you can run older 8K and 16K (?) ROMs from an Atarimax Flashcart. Most older cart games and some new ones are available as XEX or ATR, so it's worth your while to look around for such images. If you just add the 6-byte file header to the ROM file and add the footer for loading INIT and START addresses to 0x2E2 and 0x2E0 respectively, you can load ROM files like Popeye, Topper, Millipede, etc. on real Atari. However, River Raid and Gyruss ROM files that I just tried did not load using this method. Never did that before, so I will have to look it up. I think I will invest in a flash cart or two. Just did a vid showing off my new Atari 800... http://vimeo.com/4785372 . Thanks for the help... I only tried up to 16K roms so far using MPDOS. I haven't played around with bigger ones. Quote Link to comment Share on other sites More sharing options...
