JonnyBritish Posted June 11, 2009 Share Posted June 11, 2009 Can someone recommend a source to get my Atari 130XE displaying on an LCD using either S-Video or composite etc? I see a seller on Ebay but would like your thoughts on best cables etc. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 11, 2009 Share Posted June 11, 2009 12 bucks or so isn't so bad if it's a professionally made cable with molded plugs etc. To build your own you're probably looking at 7 bucks or so worth of parts, and some fiddly soldering work. Quote Link to comment Share on other sites More sharing options...
sl0re Posted June 11, 2009 Share Posted June 11, 2009 Can someone recommend a source to get my Atari 130XE displaying on an LCD using either S-Video or composite etc? I see a seller on Ebay but would like your thoughts on best cables etc. I bought an s-video one from the ebay guy. It works fine. Quote Link to comment Share on other sites More sharing options...
mrnukem Posted June 14, 2009 Share Posted June 14, 2009 I have a TV Tuner Card with Composite Input that I use with TVR software to get my Atari Display on my LCD. (I have it hooked to a switch box so I can switch between my LCD monitor and an old Green Screen Monochrome Monitor for use in 80 column mode). TV tuner cards and TV USB interfaces can be found for as low as $10 now. Quote Link to comment Share on other sites More sharing options...
joeventura Posted June 14, 2009 Share Posted June 14, 2009 I have a TV Tuner Card with Composite Input that I use with TVR software to get my Atari Display on my LCD. (I have it hooked to a switch box so I can switch between my LCD monitor and an old Green Screen Monochrome Monitor for use in 80 column mode). TV tuner cards and TV USB interfaces can be found for as low as $10 now. That is what I need a good monochrome green screen!! Quote Link to comment Share on other sites More sharing options...
