e1will Posted July 20, 2009 Share Posted July 20, 2009 Is there a way for the code to detect whether it's being run under an emulator vs. on an actual 2600? I realize this may be either a desirable development feature or an undesirable emulator bug to be squashed depending on how you look at it, but I'm just curious if there is currently a way to tell. --Will Quote Link to comment Share on other sites More sharing options...
DanBoris Posted July 20, 2009 Share Posted July 20, 2009 Is there a way for the code to detect whether it's being run under an emulator vs. on an actual 2600? I realize this may be either a desirable development feature or an undesirable emulator bug to be squashed depending on how you look at it, but I'm just curious if there is currently a way to tell. --Will As you said, the only way would be to find an emulator "bug" something that wasn't emulated properly that the CPU can detect. Even if you found this on one emulator it's unlikely that it would be the same on all emulators. Dan Quote Link to comment Share on other sites More sharing options...
+grafixbmp Posted July 20, 2009 Share Posted July 20, 2009 And even still, not every single model of atari is functionaly identical down to the wire. some of the later ones that have consolidated hardware have a few variations in there performance. Not sure what they are off hand. Quote Link to comment Share on other sites More sharing options...
Richi_S Posted July 20, 2009 Share Posted July 20, 2009 I would use the Colour Switch (PORTB - D3) to enable the user to switch between the emulator version of the game and the VCS version for the real TV. Quote Link to comment Share on other sites More sharing options...
mos6507 Posted July 20, 2009 Share Posted July 20, 2009 If you want copy protection you need to prevent the BIN from being released in the first place. Once you have a BIN all you need to do is find the copy protection routine and hack it out. In theory you could create a new banking scheme that emulators don't support, which would work as long as Stella isn't updated to support it. Chimera native games were going to be hard to emulate just because Stella would have had to add an ARM emulator side by side with the VCS. So just the amount of work that would require would probably prevent it from happening anytime soon. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted July 20, 2009 Share Posted July 20, 2009 What are you trying to achieve by detecting the difference? Quote Link to comment Share on other sites More sharing options...
e1will Posted July 20, 2009 Author Share Posted July 20, 2009 If you want copy protection you need to prevent the BIN from being released in the first place. Nah, I'm not interested in copy protection... I was mainly thinking of it in terms of the "pause" vs "color/BW" switch functionality. Since emulators generally include a pause function already, I thought I could use that switch as a "pause function" on a real 2600 and use it to display an alternate color palette in the emulator. --Will Quote Link to comment Share on other sites More sharing options...
+stephena Posted July 21, 2009 Share Posted July 21, 2009 Is there a way for the code to detect whether it's being run under an emulator vs. on an actual 2600? I realize this may be either a desirable development feature or an undesirable emulator bug to be squashed depending on how you look at it, but I'm just curious if there is currently a way to tell. --Will There was a ROM released some time ago that exploited a bug in emulators. It printed 'EMU' if run on such an emulator, and '2600' if run on the real system. It actually does print '2600' when run in Stella, since the emulation was fixed. The other 2600 emulators still print 'EMU'. I don't know where to get the ROM right now, but it was originally mentioned on the Stella mailing list. In any event, I would suggest not depending on emulator-specific things. Personally, if I ever find such a bug (and I do consider it a bug, since the emulator should be exactly the same as the real thing), I will try to fix it ASAP. I think you should always aim for full compatibility with the real thing, with the emulator helping you to achieve that goal (and being fixed if it doesn't match real hardware). Quote Link to comment Share on other sites More sharing options...
+batari Posted July 21, 2009 Share Posted July 21, 2009 Chimera native games were going to be hard to emulate just because Stella would have had to add an ARM emulator side by side with the VCS. So just the amount of work that would require would probably prevent it from happening anytime soon. That depends. Any scheme that can be defined by a functional description can be emulated without actually running the underlying ARM code. For the Harmony, I plan to provide specifications for any new schemes I create so they can be emulated without necessarily needing a full ARM emulation core. This will work except in cases where a programmer decides to use the user code stub for arbitrary ARM code. Quote Link to comment Share on other sites More sharing options...
+FujiSkunk Posted July 21, 2009 Share Posted July 21, 2009 (edited) I remember a while back they were developing a standard for C-64 emulators that would allow an emulator to identify itself, and distinguish itself both from the real hardware and other emulators, using a certain phrase in memory that was otherwise read-only. Does the Atari 2600 have any spare read-only bits that could be used for that purpose? Somebody would have to create the standard, and the emu devs would then have to adhere to the standard, of course, but it's a thought. Edited July 21, 2009 by skunkworx Quote Link to comment Share on other sites More sharing options...
e1will Posted July 21, 2009 Author Share Posted July 21, 2009 I remember a while back they were developing a standard for C-64 emulators that would allow an emulator to identify itself, and distinguish itself both from the real hardware and other emulators, using a certain phrase in memory that was otherwise read-only. Does the Atari 2600 have any spare read-only bits that could be used for that purpose? Somebody would have to create the standard, and the emu devs would then have to adhere to the standard, of course, but it's a thought. I seem to recall a similar feature with an Apple ][ emulator I was using a few years back... I know there are plenty of unused read-only locations, but that doesn't mean that existing cartridges aren't depending on a certain behavior when reading them (either by design or by accident) that using them for "what environment am I running on" info might break. It's an interesting question what sort of locations COULD theoretically be used for that purpose without breaking anything... any address returning an indeterminate value might already be used by existing programs as a quasi-random number, and any address that always returned the same value might be relied on as well (again, either by design or accidentally). (Then I guess there's the third category of hardware-dependent values... I was reading elsewhere that LDA $07 would return "$x7" on a 2600 but "$x0" on a 7800.) --Will Quote Link to comment Share on other sites More sharing options...
Richi_S Posted July 21, 2009 Share Posted July 21, 2009 What about the initial State of the RAM? Which Initial values, after power on, are stored in the real 2600 RAM, and which initial values are stored in the emulators RAM? Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted July 21, 2009 Share Posted July 21, 2009 The RAM contents of the 2600 are random on power up. The emulators should fill their emulated RIOT RAM with random values before jumping to the ROM image's reset vector. Quote Link to comment Share on other sites More sharing options...
+batari Posted July 21, 2009 Share Posted July 21, 2009 (Then I guess there's the third category of hardware-dependent values... I was reading elsewhere that LDA $07 would return "$x7" on a 2600 but "$x0" on a 7800.) That is not reliable. Different EPROMs and different cartridge hardware (such as CC, CC2, Kroko) may produce different values on undriven bits even on the same console. If you release a binary, you have no way of knowing what sort of hardware the user will try. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 22, 2009 Share Posted July 22, 2009 If you want copy protection you need to prevent the BIN from being released in the first place. Nah, I'm not interested in copy protection... I was mainly thinking of it in terms of the "pause" vs "color/BW" switch functionality. Since emulators generally include a pause function already, I thought I could use that switch as a "pause function" on a real 2600 and use it to display an alternate color palette in the emulator. --Will Have it do both There are ways to increase the number of switch functions. For example, use a difficulty switch to choose between altering the palette in one position, and pause status in the other. Toggling the B&W switch then completes the function. All this would "cost" is one bit to hold each of the modes' flip status, and the B&W switch's flip status. Add an additional bit if you want 7800 console autodetection (so it's switch toggles mode options correctly). That comes to a total of 1 nybble of ram you'd burn. When the B&W switch isn't being messed with, you can keep the difficulty switches assigned as player handicaps (their original intent). This "costs" nothing, because SWCHB holds them. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 22, 2009 Share Posted July 22, 2009 Try this...you can have each of the 4 difficulty switch positions hold a seperate function that can be toggled on and off using the B&W switch (on either console). Never checked it, but it should work. ;7800 autodetection requires a special power-up sequence... ;execute on power-up ONLY. Ram is overwritten, so 7800 detection would fail later CONSOLE7800 = %00000100 ; I just used one of the remaining bits START: cld ;2 Clear decimal mode sei ;2 and set the interrupt status lda #$00 ;2 clear A tay ;2 Console type = 2600 ldx $D0 ;3 Check $D0 cpx #$2C ;2 Does it contain value $2C? bne Not_7800 ;2 If not, branch (keep 2600 mode) ldx $D1 ;3 Check $D1 cpx #$A9 ;2 Does it contain value $A9? bne Not_7800 ;2 If not, branch (keep 2600 mode) ldy #CONSOLE7800 ;2 Otherwise, store the bit Not_7800: ;now, clear out all ram tax ;2 clear the X counter Init_Ram_loop: dex ;2 count down 1 txs ;2 give to the stack pointer pha ;3 ...and push #$00 into ram bne Init_Ram_loop ;2 branch 255 more times ;ram initialization done lda SWCHB ;4 and #$08 ;2 sta console ;3 save current B&W switch status to bit 4 tya ;3 Save the console type... ora console ;3 ...by merging into the same ram sta console ;3 ;During your game, check the status of the B&W switch...optimally on every frame lda SWCHB ;4 load current switches for B&W status tax ;2 keep uncorrupted in an index register eor console ;3 compare against previous value... and #$08 ;2 (mask out all other bits) beq No_Switch_Change ;2 branch if the same (branch to end) lda console ;2 Is it playing on a 7800? and #CONSOLE7800 ;2 beq Atari2600 ;2 Branch if not ;console type is 7800...skip B&W switch bounceback... txa ;2 first, get back current... and #$08 ;2 keep only Color/B&W beq Switch_bounce ;2 Skip if B&W Atari2600: txa ;2 Fetch the difficulty switch positions (all 4) rol ;2 move to bits 0 and 1... rol ;2 rol ;2 and #$03 ;2 ...and mask out all others tax ;2 give to the index register lda Flip_Table,x ;4 load in the bit we want to flip Switch_bounce: eor console ;3 ...in the stored switches sta console ;3 ALL DONE! No_Switch_Change: ;Then throw this data table someplace... Flip_Table: ;example...you can use any bit positions that ;don't conflict with the ones used for console ;type and current B&W flip status .byte %10000000 ; bit to use if both switches are "B" .byte %01000000 ; right switch "A", left switch "B" .byte %00100000 ; right switch "B", left switch "A" .byte %00010000 ; both switches "A" Changes to the variable console are only happening when the B&W switch is flipped. You can read those bits later to decide on what to do for each case Because the difficulties are ignored by the B&W routine otherwise, you can use their status to provide two other off/on functions. Quote Link to comment Share on other sites More sharing options...
e1will Posted July 22, 2009 Author Share Posted July 22, 2009 (edited) Have it do both You're right, of course... To be honest I was just looking for an excuse to play with code that would detect the different environments, and the pause vs "emulator palette" thing seemed like a decent use of that (possibly nonexistent) feature/bug. Speaking of 7800 console detection, I was reading the thread you started about code to handle the 7800 pause vs 2600 TV type switch, and was wondering you could re-post the code for that (if you're willing to share it). (The link you'd posted no longer works.) --Will EDIT: Never mind, I see you just posted it! Edited July 22, 2009 by e1will Quote Link to comment Share on other sites More sharing options...
