doctorclu Posted July 23, 2009 Share Posted July 23, 2009 Lynxflash: Can the flashcart be flashed while in the cartridge slot? I want to try to connect a small usb cable from the flashcart that runs to the side of the Lynx where I could add a USB port. That way I don't have unplug the flashcart, and more importantly, don't have to plug and unplug the usb cable time and time again and risk damaging the usb slot on the flashcart. But could I write to the the flashcart (while the lynx is off), and do all I need to do while it is still sitting the Lynx cartridge slot? In other words, though the Lynx is powered off, would there be residual power left in the Lynx to effect the flashcart while plugged in potentially damage the flash cart if you also tried to write to it? I know Atari on some cartridge slots had power leads (like on the Atari 800). As for the Lynx...(checks Best Electronics catalog) has pin 1 as ground and pin 31 as "PWR 4069" whatever that means. So there is power going through the cartridge, but would it be DEAD DEAD while the Lynx is "off" to allow you do what you need to do on the Lynx Flashcart without harm? Quote Link to comment Share on other sites More sharing options...
Lynxman Posted July 23, 2009 Share Posted July 23, 2009 Lynxflash: Can the flashcart be flashed while in the cartridge slot? I want to try to connect a small usb cable from the flashcart that runs to the side of the Lynx where I could add a USB port. That way I don't have unplug the flashcart, and more importantly, don't have to plug and unplug the usb cable time and time again and risk damaging the usb slot on the flashcart. But could I write to the the flashcart (while the lynx is off), and do all I need to do while it is still sitting the Lynx cartridge slot? In other words, though the Lynx is powered off, would there be residual power left in the Lynx to effect the flashcart while plugged in potentially damage the flash cart if you also tried to write to it? I know Atari on some cartridge slots had power leads (like on the Atari 800). As for the Lynx...(checks Best Electronics catalog) has pin 1 as ground and pin 31 as "PWR 4069" whatever that means. So there is power going through the cartridge, but would it be DEAD DEAD while the Lynx is "off" to allow you do what you need to do on the Lynx Flashcart without harm? No, it is not possible, if you try it, the FlashCard or the Lynx will be damaged. Quote Link to comment Share on other sites More sharing options...
CGQuarterly Posted August 5, 2009 Share Posted August 5, 2009 (edited) Sorry, accidentally posted in the wrong thread. Chris Edited August 5, 2009 by Jibbajaba Quote Link to comment Share on other sites More sharing options...
johannesmutlu Posted June 7, 2015 Share Posted June 7, 2015 Nope,the usb would overpower the lynx due high voltage and thus damage the lynx,that's why the usb plug has been put on the side of it to prevent people doing this. Quote Link to comment Share on other sites More sharing options...
