+DarkLord Posted August 4, 2009 Share Posted August 4, 2009 Well, I'm still trying... I bought this unit from a store on Ebay and tried it. Says it requires 5v input to power it - my universal P/S from Walmart only does 4.5 and 6, I tried both. I tried adjusting the pots, and using the menu switch, the auto scan switch, etc, and I got no output from the Mega ST I was using at all - the 15" AOC monitor I was using flashes green on its LED's when there is a legitimate signal - never got one. So, I don't know - unless someone has some other suggestions as to what to try with it. Perhaps the CGA input signal its looking for is too far from the ST's standard signal. This same setup, (Mega ST and AOC monitor) works ok in ST Low (but not Med - blurry and text drops out) with this Ambery rgb to vga converter: Just thought I'd pass along what some of my experiences are... Quote Link to comment Share on other sites More sharing options...
vitaflo Posted August 6, 2009 Share Posted August 6, 2009 (edited) Is YPbPr a valid output? If so, instead of everyone coming up with s-video solutions, it would be nice to see YPbPr ones, as basically any NTSC TV would then be compatible. Edited August 6, 2009 by vitaflo Quote Link to comment Share on other sites More sharing options...
bandit Posted August 15, 2009 Share Posted August 15, 2009 Well, I'm still trying... I bought this unit from a store on Ebay and tried it. Says it requires 5v input to power it - my universal P/S from Walmart only does 4.5 and 6, I tried both. I tried adjusting the pots, and using the menu switch, the auto scan switch, etc, and I got no output from the Mega ST I was using at all - the 15" AOC monitor I was using flashes green on its LED's when there is a legitimate signal - never got one. So, I don't know - unless someone has some other suggestions as to what to try with it. Perhaps the CGA input signal its looking for is too far from the ST's standard signal. This same setup, (Mega ST and AOC monitor) works ok in ST Low (but not Med - blurry and text drops out) with this Ambery rgb to vga converter: Just thought I'd pass along what some of my experiences are... I know of 2 ST users that bought this, they where unable to get it to work on the ST, However one had an amiga and it works with that. Quote Link to comment Share on other sites More sharing options...
