NoahsMyBro Posted October 12, 2002 Share Posted October 12, 2002 In late-August I got a dead 4-port 5200. Joe Kollar traded it to me, in a deal that went perfectly. He's a great guy to trade with, btw. Well, Joe told me that the 5200 was dead when he got it, and came to him with an Atari 800 power supply. It seems likely to me that somebody plugged the Atari 800 P/S into the 5200, sending 30 volts into a land where only 14 volts is welcome. I obtained the system looking for a challenge. Ya know what? I found one! It took me 2 months, and an unbelievable amount of quality help from sci.electronics.repair denizens, but as of late tonight the system is working again!!!! To be brief, I had to replace 2 transistors and an IC. I still need one small part, though, and I'm hoping someone here with a hopelessly broken 5200 of any variety might be able to help. The top-half of the power switch on the board (underneath the power button on the case) is missing. Consequently, the power button on the case doesn't make contact with the actual switch. I could probably rig something up, but I'd like to repair/replace the power switch. If any of you could find a broken 5200 and remove the power switch and send it to me (or at least the top half of the plastic square around the foil contacts), that would be terrifc. Naturally I'd pay the postage, and if you want I could throw in a common or two. I don't suppose Koffi might support 4 players, Cafeman? Anybody up for making a 5200 Gauntlet? I've got a 4-port! 8-) Quote Link to comment Share on other sites More sharing options...
kevjon1 Posted October 12, 2002 Share Posted October 12, 2002 good work...Im trying to get mine going not nearly as sorry as you started from just need mine to recognize the start command...grounding pin 4 & 7 together momentarily didnt help. consule just puts up game screen running demos..but will keep an eye out for power switch..any idea about my situation?? Quote Link to comment Share on other sites More sharing options...
Voltman3 Posted October 12, 2002 Share Posted October 12, 2002 NMB Hey call Brad @ Best Electronics a new Main Console on/off sw is $1.00 .50c for the spring. KJ1 Sorry the 4&7 didnt work. I'd open her up and look for a loose solder joint at the db15 connector on the MB, if they're good follow out the traces on both pins you might have an open somewhere ? Since you have eliminated the CX52 cable as a poss prob. I would think you would be having probs with a group of buttons other than just the Start. Are you having trouble with any other KP functions? Pin 4 > is common to S,P&R Pin 7 > is common to 1,2,3&S If you are having trouble with other functions in either group of buttons look at that specific pin/trace. Later Quote Link to comment Share on other sites More sharing options...
Voltman3 Posted October 12, 2002 Share Posted October 12, 2002 KJ1 A last minute thought. Put in Defender, it uses all 6 of those KP functions. If you can change the play difficulty via 1,2 or 3 Pin 4 is the culprit If it doesnt work, well then you know ! lol Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted October 12, 2002 Share Posted October 12, 2002 I don't suppose Koffi might support 4 players, Cafeman? (FALLS OVER DEAD FROM EXHAUSTION) Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 13, 2002 Share Posted October 13, 2002 If you cant get a power switch from best for whatever reason, I'm sure I have one in my attic, I'd be happy to send to you. No payment required. Send me and e-mail of interested. chazbeenhad@hotmail.com Charlie Quote Link to comment Share on other sites More sharing options...
NoahsMyBro Posted October 13, 2002 Author Share Posted October 13, 2002 I don't suppose Koffi might support 4 players, Cafeman? (FALLS OVER DEAD FROM EXHAUSTION) Today was very blah, in a dreary sort of way. But I've got to thank you, your post made me laugh out loud. Looking forward to any game you bring out, whether it be 1-player, 4-player, or pi^2-players, Steve Quote Link to comment Share on other sites More sharing options...
kevjon1 Posted October 13, 2002 Share Posted October 13, 2002 good idea w defender cart ohm meter showed all keypad funtion including pots working fine.....at least I got a working cx52..will reopen machine and probe around with meter..thx Quote Link to comment Share on other sites More sharing options...
joeybastard Posted October 14, 2002 Share Posted October 14, 2002 Well I am glad to hear you got that 4 port working and thank you for the good feedback on trading. Let me say it was a pleasure to trade with you too. The 2 port you sent me works perfectly and I've been playing the hell out of it. In fact because of this new 5200 obsession, I'm working on a joystick modification for the 5200 sticks based on the spring system that PC analog sticks use. I will definetely let AA forum know if I get it to work right and it's practical. So far it works for a while and then I have springs popping out all over the place. It's actually pretty comical. -Joe Kollar AKA Joeybastard Quote Link to comment Share on other sites More sharing options...
KAZ Posted October 14, 2002 Share Posted October 14, 2002 And it will be funny when someone sends you their "hopelessly" broken Atari 5200, to provide you the necessary part you require to repair the first, only to see you fix THAT one also. Quote Link to comment Share on other sites More sharing options...
