sku_u Posted October 16, 2002 Share Posted October 16, 2002 Does anyone out there have any idea how to control the ship in Asteriods for the 5200? I can't get it to stay in the center of the screen and it is nearly impossible to stop the ship from spinning. Quote Link to comment Share on other sites More sharing options...
NE146 Posted October 16, 2002 Share Posted October 16, 2002 Just like the 2600 version: Left/right for rotating left/right, up for thrust and down for shields. Your 5200 joystick potentiometers might be a little off causing you the difficulty, but quite honestly it's still a little difficult even w/ working 5200 controllers. I play the emu'd version via the dreamcast emulator since the pad makes it somewhat easier to control. Or even better, the Atari 8-bit version (which is pretty much exactly the same) Quote Link to comment Share on other sites More sharing options...
Voltman3 Posted October 16, 2002 Share Posted October 16, 2002 Hi Sometime ago I posted (see post - Asteroids Controller) the proper way to control Asteroids. After playing on & off for months & months, and not giving up- I discovered the following: Step 1 - push UP (Thrust), until the Ship barely moves. Step 2 - pull DOWN (Shield) until the Shield appears, you will no longer thrust out of control. Step 3 - turn Left or Right (doesn't matter which way you go - real quick) Step 4 - then back the opposite way R or L, your Ship will then stay centered. It only takes those 4 quick motions to make Asteroids playable. Do them as fast as you can- it works ! I have tried other combinations and this is the only 1 that works- that I've found. NOTE: You only need to do each motion long enough for it to take effect. - ie.... Thrust: as soon as ship moves - go to next step. It will take a little practice to get it right, but once you figure it out Asteroids is fun ! It's definitely a playable proto ! So far, I have hit 70,000 using this method. Later, Quote Link to comment Share on other sites More sharing options...
sku_u Posted October 16, 2002 Author Share Posted October 16, 2002 Thanks for the tips. I haven't gotten past 10,000 yet. Quote Link to comment Share on other sites More sharing options...
