+remowilliams Posted October 6, 2009 Share Posted October 6, 2009 I know, I was waiting for that but no sign of it yet. However, here's what I did to get it working (using TOS 2.06) Yes, I used that same IDE driver/BigDOS solution for some time without issue before getting HDDRIVER. As long as folks keep the TOS version limitations in mind, it makes for a cheap and easy FAT PC/ST card setup. Quote Link to comment Share on other sites More sharing options...
Awol Posted October 6, 2009 Share Posted October 6, 2009 (edited) UltraSatan TOS/DOS compatible image files Edited October 6, 2009 by Grey_and_Purple Quote Link to comment Share on other sites More sharing options...
Fletch Posted October 7, 2009 Share Posted October 7, 2009 My unit still has not arrived. Quote Link to comment Share on other sites More sharing options...
Goochman Posted October 7, 2009 Author Share Posted October 7, 2009 Can someone point me to where I can get BigDOS? Also - I img'd a 32mb SD card from the other site and WinXP asks if I want to format the card - is it only readable after the ST writes data to these images? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted October 8, 2009 Share Posted October 8, 2009 Can someone point me to where I can get BigDOS? Also - I img'd a 32mb SD card from the other site and WinXP asks if I want to format the card - is it only readable after the ST writes data to these images? Hmm, I just used MugUK's guide and I had no problem at all setting up 1 gig SD cards, winding up with 512megs and 1 partition for swapping between my ST and Windows machines. Works great for me. Quote Link to comment Share on other sites More sharing options...
Goochman Posted October 8, 2009 Author Share Posted October 8, 2009 Can someone point me to where I can get BigDOS? Also - I img'd a 32mb SD card from the other site and WinXP asks if I want to format the card - is it only readable after the ST writes data to these images? Hmm, I just used MugUK's guide and I had no problem at all setting up 1 gig SD cards, winding up with 512megs and 1 partition for swapping between my ST and Windows machines. Works great for me. This is with HDDRIVER correct? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted October 8, 2009 Share Posted October 8, 2009 Can someone point me to where I can get BigDOS? Also - I img'd a 32mb SD card from the other site and WinXP asks if I want to format the card - is it only readable after the ST writes data to these images? Hmm, I just used MugUK's guide and I had no problem at all setting up 1 gig SD cards, winding up with 512megs and 1 partition for swapping between my ST and Windows machines. Works great for me. This is with HDDRIVER correct? Yep, sorry - forgot to mention that. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted October 8, 2009 Share Posted October 8, 2009 Can someone point me to where I can get BigDOS? It's linked in post #35 in this thread. Quote Link to comment Share on other sites More sharing options...
Goochman Posted October 9, 2009 Author Share Posted October 9, 2009 Can someone point me to where I can get BigDOS? It's linked in post #35 in this thread. Ok thanks - I see it now. Just to be 100% clear. To get the SD card to work with TOS/DOS you need to use HDDRIVER - ICD PRO wont work moving the SD card between PC and ST correct? Quote Link to comment Share on other sites More sharing options...
StickHead Posted October 11, 2009 Share Posted October 11, 2009 Just to be 100% clear. To get the SD card to work with TOS/DOS you need to use HDDRIVER - ICD PRO wont work moving the SD card between PC and ST correct? That is correct, at least for the moment. Some folks are working on creating an image file of a card formatted and partitioned with HDDriver's TOD/DOS mode that can be read by the ICD driver. In the mean-time, if you want a PC and Atari compatible card, you can use Ppera's method here (scroll down for info on how to get XP to recognise partitions, the under that is the link to the driver). Pros: Windows can read all the partitions on the card. Cons: Limited to <1gb, Driver only recognises first card. Quote Link to comment Share on other sites More sharing options...
Goochman Posted October 12, 2009 Author Share Posted October 12, 2009 Does anyone know if an ICD Pro formatted card can be read under STeem? If so, can you mount a Windows HD under STeem to copy data between the 2? Quote Link to comment Share on other sites More sharing options...
Fletch Posted October 20, 2009 Share Posted October 20, 2009 My UltraSatan has finally arrived! I was starting to get worried. I set it up with my ancient copy of ICD Pro and all seems a-ok! I haven't had a hard disk on the ST for a very long time so it is very very cool. Quote Link to comment Share on other sites More sharing options...
