EricDeLee Posted October 12, 2009 Share Posted October 12, 2009 Hello. Looking for a bit of help with the J3 and J9 jumper issue for my FB2 mod. I'm not really sure how to wire that part up to a switch to get this to work with the cart mod and then with the on board games. As of right now, I have the cart mod complete. I really can't tell if it works or not though. When I turn on the screen the Adventure logo pops up. I know I have to do something with this J3 and J9 thing. Yet...being that I'm not an electronics expert... I have no clue what to do when it says to open J3 or to close J9. Can someone draw up a schematic of the switch... label each wire and where I need to put it? Perhaps cartoon bubbles with words of encouragement as well? LOL I believe this is the revision c FB2 board. But I'm not really sure. It is smaller.. and there is not a black wire going from an IC chip or anything like that. Any advice on getting this up and running would be great! Quote Link to comment Share on other sites More sharing options...
awace Posted October 13, 2009 Share Posted October 13, 2009 Hello. Looking for a bit of help with the J3 and J9 jumper issue for my FB2 mod. I'm not really sure how to wire that part up to a switch to get this to work with the cart mod and then with the on board games. As of right now, I have the cart mod complete. I really can't tell if it works or not though. When I turn on the screen the Adventure logo pops up. I know I have to do something with this J3 and J9 thing. Yet...being that I'm not an electronics expert... I have no clue what to do when it says to open J3 or to close J9. Can someone draw up a schematic of the switch... label each wire and where I need to put it? Perhaps cartoon bubbles with words of encouragement as well? LOL I believe this is the revision c FB2 board. But I'm not really sure. It is smaller.. and there is not a black wire going from an IC chip or anything like that. Any advice on getting this up and running would be great! Whell i tried that mod once and ended up never getting it to work then i got a nother fb II and it worked cause it was differnt model.. as far as open j3 means unhook j3 and close j9 means hook up so on a switch example a button says normaly open means its off untill closed so when you close a circut you complete it and when you open a circut you unhook it so i think it means when j3 is open then j9 shorts to gnd and vise versa so i would just hook up j9 \ look here http://www.atarimuseum.com/fb2hacks/page2.htm thats why i used the other version FB II for my mod cause i couldnt figure out j3 or j9. good luck. I suggest you put pictures here then for shure someone would know. Quote Link to comment Share on other sites More sharing options...
