Cebus Capucinis Posted October 25, 2009 Share Posted October 25, 2009 Okay, now that I'm cruising along fine with my 1200XL, I wanted to ask about the flashcart capabilities. I know on the front page of AA there is an 8-bit flashcart from AtariMax and I am very interested in getting it. However, I have absolutely no idea how a flashcart works! I've never used one before. Is it perfectly compatible with my 1200XL? Just a simple USB connection and drag-and-drop files into it, then plug in the cart and use the built-in menu to load the software? Does anyone have one of these? What all would I need to get up and running with an AtariMax 8MB flashcart? Quote Link to comment Share on other sites More sharing options...
classics Posted October 26, 2009 Share Posted October 26, 2009 Okay, now that I'm cruising along fine with my 1200XL, I wanted to ask about the flashcart capabilities. I know on the front page of AA there is an 8-bit flashcart from AtariMax and I am very interested in getting it. However, I have absolutely no idea how a flashcart works! I've never used one before. Is it perfectly compatible with my 1200XL? Just a simple USB connection and drag-and-drop files into it, then plug in the cart and use the built-in menu to load the software? Does anyone have one of these? What all would I need to get up and running with an AtariMax 8MB flashcart? There is a windows application called Maxflash Studio you use to design your multi-cart. You can drag-drop files or add then via the menus, arrange the files, tweak the cart entries, etc, all without messing with actually programming the carts. Once you have the cart set up the way you want, you just plug the cart into the programmer, then the programmer into the USB port on your computer and press the Synchronize button to update the cart. The 1200XL does have a few OS issues but for the most part it will be compatible with XL/XE programs. If not you can always enable the '800 OS' option for a game. You can read more about the software in the documentation section here: http://www.atarimax.com/flashcart/ Steve Quote Link to comment Share on other sites More sharing options...
Fletch Posted October 26, 2009 Share Posted October 26, 2009 (edited) Steve, I saw this in the wild over the weekend at the GameX show near Philly. I had to get a quick pic for you! Edited October 26, 2009 by Fletch Quote Link to comment Share on other sites More sharing options...
+Stephen Posted October 26, 2009 Share Posted October 26, 2009 Steve, I saw this in the wild over the weekend at the GameX show near Philly. I had to get a quick pic for you! Cool to see the Atari font on the Colecovision Stephen Anderson Quote Link to comment Share on other sites More sharing options...
