+Zeptari Posted November 14, 2009 Share Posted November 14, 2009 I moved my 5200 from my hdtv to my new Atari corner in the basment... neat little set-up, I'll post pics sometime... anyways, now that it's moved the picture is black and white OR lot's of white noise.. what can i do.... Is it the cable from my 4port 5200 giving me the problems or the RF switch itself? any idea's guys? -rick i really love this system and really want to enjoy it the right way! thanks Quote Link to comment Share on other sites More sharing options...
atariksi Posted November 14, 2009 Share Posted November 14, 2009 I moved my 5200 from my hdtv to my new Atari corner in the basment... neat little set-up, I'll post pics sometime... anyways, now that it's moved the picture is black and white OR lot's of white noise.. what can i do.... Is it the cable from my 4port 5200 giving me the problems or the RF switch itself? any idea's guys? -rick i really love this system and really want to enjoy it the right way! thanks Loose cable somewhere most likely. Perhaps, interference from furnace where you wrapped the wire around before hooking to your TV... Quote Link to comment Share on other sites More sharing options...
+Zeptari Posted November 14, 2009 Author Share Posted November 14, 2009 (edited) ahhhh your funny! I wish it was that simple.... I don't want to have to downgrade to a 2-port to get a decent picture. I hear the 2-port's have better picture quality because the power supply doesn't go thru the video cable. i keep trying to get the cable in the right position so it says clear.... Edited November 14, 2009 by Zeptari1 Quote Link to comment Share on other sites More sharing options...
VectorGamer Posted November 14, 2009 Share Posted November 14, 2009 i keep trying to get the cable in the right position so it says clear.... Sounds like something "loose" When I got my four port I had to bend the connectors on the cable going from the 5200 to the switch box because it was not a taut connection. Also, the coax connector on the switch box was FUBAR'd so I simply cut it off and put a new one on. Quote Link to comment Share on other sites More sharing options...
+Zeptari Posted November 14, 2009 Author Share Posted November 14, 2009 Sounds like something "loose" When I got my four port I had to bend the connectors on the cable going from the 5200 to the switch box because it was not a taut connection. Also, the coax connector on the switch box was FUBAR'd so I simply cut it off and put a new one on. You bent the connectors? Arn't they hidden under the area where you can "hide" and wrap the cable up. That hidden area. I'll have to check this out. I know one thing, if I tried to replace the coax cable I'd make it FUBAR'd! -rick Quote Link to comment Share on other sites More sharing options...
VectorGamer Posted November 15, 2009 Share Posted November 15, 2009 Sounds like something "loose" When I got my four port I had to bend the connectors on the cable going from the 5200 to the switch box because it was not a taut connection. Also, the coax connector on the switch box was FUBAR'd so I simply cut it off and put a new one on. You bent the connectors? Arn't they hidden under the area where you can "hide" and wrap the cable up. That hidden area. I'll have to check this out. I know one thing, if I tried to replace the coax cable I'd make it FUBAR'd! -rick The video cable from the 5200 that gets wound up underneath - there's an RCA type connector at the end of that cable that plugs into the switch box. My connector had the "tabs" flaring outward that I had to bend inward to get a taut connection to the switch box. The coax connector on my was bad so it had to be replaced. I'm guessing that this is not a part that breaks easily and this may not be the case for you. Lastly, have you adjusted the picture color using the knob that is on the motherboard? Quote Link to comment Share on other sites More sharing options...
bohoki Posted November 15, 2009 Share Posted November 15, 2009 Sounds like something "loose" When I got my four port I had to bend the connectors on the cable going from the 5200 to the switch box because it was not a taut connection. Also, the coax connector on the switch box was FUBAR'd so I simply cut it off and put a new one on. You bent the connectors? Arn't they hidden under the area where you can "hide" and wrap the cable up. That hidden area. I'll have to check this out. I know one thing, if I tried to replace the coax cable I'd make it FUBAR'd! -rick The video cable from the 5200 that gets wound up underneath - there's an RCA type connector at the end of that cable that plugs into the switch box. My connector had the "tabs" flaring outward that I had to bend inward to get a taut connection to the switch box. The coax connector on my was bad so it had to be replaced. I'm guessing that this is not a part that breaks easily and this may not be the case for you. Lastly, have you adjusted the picture color using the knob that is on the motherboard? on mine when i turn it on it works fine but when i turn it off it goes to the "FUZZ" till i tap the switchbox with a screwdriver handle guess my internal relay is sticky Quote Link to comment Share on other sites More sharing options...
+Zeptari Posted November 16, 2009 Author Share Posted November 16, 2009 Lastly, have you adjusted the picture color using the knob that is on the motherboard? Color knob on the motherboard? I didn't know the 5200 had knob's inside the unit. -rick Quote Link to comment Share on other sites More sharing options...
VectorGamer Posted November 16, 2009 Share Posted November 16, 2009 (edited) Lastly, have you adjusted the picture color using the knob that is on the motherboard? Color knob on the motherboard? I didn't know the 5200 had knob's inside the unit. -rick Yeah - it's pretty dumb. I guess potentiometer may be the correct term. There's two of them - one sets the color and the other calibrates the controller. On the front right hand side. Edited November 16, 2009 by rmaerz Quote Link to comment Share on other sites More sharing options...
atariksi Posted November 17, 2009 Share Posted November 17, 2009 Lastly, have you adjusted the picture color using the knob that is on the motherboard? Color knob on the motherboard? I didn't know the 5200 had knob's inside the unit. -rick Yeah - it's pretty dumb. I guess potentiometer may be the correct term. There's two of them - one sets the color and the other calibrates the controller. On the front right hand side. I didn't think that had anything to do with a fuzzy picture. I thought that POT adjusted the colors for GTIA. He may be screwing up other things if he fools around with that. Quote Link to comment Share on other sites More sharing options...
VectorGamer Posted November 17, 2009 Share Posted November 17, 2009 I didn't think that had anything to do with a fuzzy picture. I thought that POT adjusted the colors for GTIA. He may be screwing up other things if he fools around with that. It doesn't but one of the problems he listed was b/w picture. Quote Link to comment Share on other sites More sharing options...
atariksi Posted November 20, 2009 Share Posted November 20, 2009 ahhhh your funny! I wish it was that simple.... I don't want to have to downgrade to a 2-port to get a decent picture. I hear the 2-port's have better picture quality because the power supply doesn't go thru the video cable. i keep trying to get the cable in the right position so it says clear.... Haven't heard back from you. Did you get it working? I have a couple of RF switch boxes for 4-port A5200 if you want to get one quickly w/o waiting for some Ebay auction. Quote Link to comment Share on other sites More sharing options...
VectorGamer Posted November 20, 2009 Share Posted November 20, 2009 He PM'd me that he got it working. "BTW pinching the end of the RF cable that goes into the switchbox and changing the channel to "2" on the bottom of the 5200 fixed my video problem!" I'm not sure what "pinching the end of the RF cable" means but on mine I had to bend the tabs inward to get a taut connection to the switch box. Quote Link to comment Share on other sites More sharing options...
