paladina Posted December 4, 2009 Share Posted December 4, 2009 What is problem when I change DLIST for GR15 that I become only two row window, the cursor is away,as there was 4 rows... any correction? Thx for help. 1 ? "{125}" 10 REM * DL3 * 20 GRAPHICS 15 70 FOR I=33015 TO 33019:READ D:POKE I,D:NEXT I 90 DATA 240,240,66,96,159 100 POKE 82,0 150 ? "HERE THE TEXT,THAT IS LONG 40 CHARACTERS" DL3.ZIP Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 4, 2009 Share Posted December 4, 2009 You've overwritten the first LMS Mode E that Antic needs to establish where the bitmap is. You'd be better off with something like: 10 GR. 15:DL=PEEK(560)+PEEK(561)*256 20 POKE DL,240:POKE DL+1,240:POKE DL+2,66 30 POKE DL+3,PEEK(660):POKE DL+4,PEEK(661):REM TEXT WINDOW 40 POKE DL+5,84:POKE DL+6,PEEK(88):POKE DL+7,PEEK(89):REM BITMAP AREA 50 FOR A=DL+160 TO DL+170:IF PEEK(A)<>66 THEN NEXT A 60 POP:TXT=PEEK(660)+PEEK(661)*256+40:H=INT(TXT/256):L=TXT-H*256 70 POKE A+1,L:POKE A+2,H:REM change bottom text window to 40 bytes later 80 POKE A+3,2:POKE A+4,2:POKE A+5,65 90 POKE A+6,PEEK(560):POKE A+7,PEEK(561):REM bottom text window only 3 lines The bitmap area in that example won't be 160 pixels high, it'll be a bit shorter. You could keep it 160 high by starting the Display List a couple of bytes earlier in RAM. Quote Link to comment Share on other sites More sharing options...
paladina Posted December 4, 2009 Author Share Posted December 4, 2009 Not bad...but I need only TWO rows down...not One up and three down... you see my DL, where I change it to TWO ROWS...but the cursor and text is problem...it do as it was 4 rows there... but thenks for your example Quote Link to comment Share on other sites More sharing options...
FLY Posted December 4, 2009 Share Posted December 4, 2009 Not bad...but I need only TWO rows down...not One up and three down... you see my DL, where I change it to TWO ROWS...but the cursor and text is problem...it do as it was 4 rows there... but thenks for your example No použij klasicky GR.15+32 a máš to..... Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 5, 2009 Share Posted December 5, 2009 80 POKE A+3,2:POKE A+4,65 90 POKE A+5,PEEK(560):POKE A+6,PEEK(561):REM bottom text window only 3 lines That gives 1 row top, 2 rows bottom of text. The OS still thinks you have a 4-line text window so you'll lose the cursor at times. Nothing you can do there - the OS can only handle 4 or 24 lines of text. A more livable solution for the text window might be to start it 40 bytes further on so that the first line is invisible instead of the last line. Quote Link to comment Share on other sites More sharing options...
FLY Posted December 5, 2009 Share Posted December 5, 2009 80 POKE A+3,2:POKE A+4,65 90 POKE A+5,PEEK(560):POKE A+6,PEEK(561):REM bottom text window only 3 lines That gives 1 row top, 2 rows bottom of text. The OS still thinks you have a 4-line text window so you'll lose the cursor at times. Nothing you can do there - the OS can only handle 4 or 24 lines of text. A more livable solution for the text window might be to start it 40 bytes further on so that the first line is invisible instead of the last line. No a celkově získáš dole to samý jak u příkazu GR.15+32 s tím rozdílem, že uvidíš všechny minimální 4 řádky..... Quote Link to comment Share on other sites More sharing options...
paladina Posted December 5, 2009 Author Share Posted December 5, 2009 Ok and how it correct that I see the last row, now I can put cursor down, whete I dont see him... I need that I see last two text rows...thx. Quote Link to comment Share on other sites More sharing options...
paladina Posted December 5, 2009 Author Share Posted December 5, 2009 Rybags! I found it alone :D Its POKE 703... ok...for may two line row I give only POKE 703,2 Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 6, 2009 Share Posted December 6, 2009 That won't work... the OS is hard-coded to recognise only 4 or 24 lines for it's Editor device. Just use 4 lines for your text - you'll probably end up needing them anyway. Quote Link to comment Share on other sites More sharing options...
mono Posted December 12, 2009 Share Posted December 12, 2009 @Paladina: look at my reply on atarionline.pl: http://atarionline.pl/forum/comments.php?DiscussionID=472 Quote Link to comment Share on other sites More sharing options...
