+MrFish Posted July 14, 2014 Share Posted July 14, 2014 Yeah I did. Just turned it off now. OK; I just wanted to be sure that they weren't attributable to some new parts of the GUI you were working on. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 14, 2014 Author Share Posted July 14, 2014 OK; I just wanted to be sure that they weren't attributable to some new parts of the GUI you were working on. No - it's OK. Everything hasn't gone to s**t yet. 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted July 14, 2014 Share Posted July 14, 2014 No - it's OK. Everything hasn't gone to s**t yet. Great! And with that sentiment, we press forward... Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted July 15, 2014 Share Posted July 15, 2014 If you are still looking for a name, have you considered CentronOS ? (Sorry!) 3 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 15, 2014 Author Share Posted July 15, 2014 (edited) Nah... it would suggest too brief a development time-scale. Edited July 15, 2014 by flashjazzcat 4 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted July 15, 2014 Share Posted July 15, 2014 Nah... it would suggest too brief a development time-scale. It'll be done in two weeks. If you cnuts apologize Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 15, 2014 Share Posted July 15, 2014 oh man, for the love of god, let's not let the goofiness of certain threads bleed over. (the irony? I'm an athiest) -Thom 2 Quote Link to comment Share on other sites More sharing options...
Prodatron Posted July 15, 2014 Share Posted July 15, 2014 Because everything is IPC based, and supervisor calls (since they're interrupts) can't be pre-empted. So only one process can be in the kernel context at any one time, and everything else is just message passing. SymbOS's kernel calling mechanism is a bit different, but Prodatron said that the need for re-entrant code was rare. I've identified a couple of frequently used routines (such as inter-bank jumps) which could be made re-entrant, but for now they're non-pre-emptable and that will work. All the complex functionality is done in separate processes, which means, that it is IPC based. So re-entrant code is not needed here. The few remaining functions, which can be called directly from an application, have to be re-entrant. Here we have three possibilities: - make the function really re-entrant able. Not a problem for small and simple functions. - lock the interrupts during execution. This only make sense for very small and short code parts, otherwise it will disarrange the system timing etc. Not a good solution. - for more complex stuff: Add a "park" mechanism in front of the function for additional calls. With a special flag the function first checks, if it's already in use. If yes, it will perform one idle cycle and then check the flag again. E.g. this is done in the kernels' memory copy routine, which can also handle interbank-copies, but only has one copy buffer. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 16, 2014 Author Share Posted July 16, 2014 (edited) I'll be quite interested to see what - if any - impact the software interrupt kernel calls have on interrupt latency in general on the Atari. It's only other IRQs which will feel the squeeze (i.e. the scheduler and the mouse sampler, the latter running at 800Hz). Worst case scenario is that the mouse starts stuttering, but most kernel calls are short enough that I don't think this will happen. Having the shorter kernel functions running entirely in the IRQ makes things appealingly uncomplicated (and thanks to Andy Mucho for suggesting the idea). For block moves and memory allocation, of course, we need to implement a "park" mechanism along the lines you have described. The system clock and mouse pointer run in the NMI, so short atomic sections should not cause unsightly disruption. Does SymbOS handle drag-and-drop of objects, BTW? I was coding up the desktop manager event messages (including mouse click, double-click, etc), and added a "drag" event which will tell the application that a drag has been instigated on a given object. The application will then track the mouse until it gets a drop event on another object. Edited July 16, 2014 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Prodatron Posted July 16, 2014 Share Posted July 16, 2014 Does SymbOS handle drag-and-drop of objects, BTW? I was coding up the desktop manager event messages (including mouse click, double-click, etc), and added a "drag" event which will tell the application that a drag has been instigated on a given object. The application will then track the mouse until it gets a drop event on another object. Only rearrangement of icons is supported right now. With the same subroutines I am planning to implement drag'n'drop for the next major version as well. This should be done for icons and list elements, if a special flag is set for such objects. Don't know if it would make sense for more control types, too? My plan was, to send a message from the desktop manager to the source process. This message contains the source object, destination process, destination position/object. Then it's the turn of the source process to communicate with the destination process. This communication should be standardized of course. Now the question is how to handle such drag'n'drops. Is it usually (only) a list of one or more files (+path) which is drag and dropped? Or could it also be real data directly? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 16, 2014 Author Share Posted July 16, 2014 (edited) Sounds good. Initiating drag and drop is straightforward enough (and a "draggable" object flag makes sense), but I have only a vague concept of how it would be handled at the other end. File browser windows (where I reckon most of the drag and drop will be happening) are all owned by the same process anyway, but it would be nice if the same communication protocol could be applied in both situations (dragging objects between windows of a single process, and between windows of different processes). So: object is dropped, desktop manager sends a message to the source process asking for the package of information, and specifying the target process. Source process builds the package (complete path and filename of icon, for example), and sends a message to the target process saying "here's everything you need to handle the dropped object"? Anyway: I'm a ways off implementing this, but it's probably worth thinking about now. Quite interesting to see the IPC implemented in 6502. It's pretty economical, since of course applications spend most of their time communicating with the desktop manager, so the message passing routine becomes quite generic: ; ---------------------------------------------------------------------------- ; Worker routine to open a window at a,x in bank y and wait for a response ; ---------------------------------------------------------------------------- .local OpenWindow sty MessageBuffer+1 ; bank stax MessageBuffer+2 ; address mva #Desk.WindOpen MessageBuffer ; function jsr SendMsgDeskMgr ; send message jsr SleepMsgDeskMgr ; sleep till we get a response lda MessageBuffer+4 ; get window ID (only valid if status is OK) ldy MessageBuffer ; get status (bit 7 set if there was an error) rts .endl ; ---------------------------------------------------------------------------- ; Send message to the desktop manager ; ---------------------------------------------------------------------------- .local SendMsgDeskMgr lda #ProcessID.DesktopManager ; receiver ID ldxy #MessageBuffer SysCall Kernel.MessageSend ; send message rts .endl ; ---------------------------------------------------------------------------- ; Sleep on message from desktop manager ; ---------------------------------------------------------------------------- .local SleepMsgDeskMgr lda #ProcessID.DesktopManager ; sender ID ldxy #MessageBuffer SysCall Kernel.MessageSleepReceive ; sleep on response from desktop manager only rts .endl SysCall is a macro which just writes a BRK instruction with the function code inline behind it. This frees us the 6502's registers for args. There are only three registers, so we have to be quite creative. Kernel functions which require more than three 8-bit arguments can have them inline after the SysCall. "#ProcessID.DesktopManager" and similar are enumerated values; a nice feature of the MADS assembler which means hard-coded numeric values can be completely avoided. Of course you can do this in any assembler, but the syntax here is highly readable. Slowly getting there... Edited July 16, 2014 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted July 16, 2014 Share Posted July 16, 2014 Will all this lead to NeXT style applications where you can stitch together pre-made components to make an "app"? Or, am I huffing too much glue? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 16, 2014 Author Share Posted July 16, 2014 It shouldn't take long to customise the application skeleton code. As for modularisation: with some kind of resource editor on the PC, and a bunch of library code, a bit of cut and paste will go a long way. I already discovered this when writing applications which use the text mode UI (see: FDISK and UFlash). Without the need to write a UI for every new project, things get a lot easier. Not quite in the same league as application bundles, though. 1 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted July 17, 2014 Share Posted July 17, 2014 (edited) Your should replace .LOCAL/ENDL by .PROC/ENDP for things that are considered subroutine/procedures. As opposed to LOCALs, PROCs are exclusive in the same scope. Opposed to that LOCALs are cummulative, so this code below is no compile time error! But something you really don't want... believe me,it took days to find it :-).local testlda #1rts.endl.local testlda #2rts.endl Edited July 17, 2014 by JAC! 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 17, 2014 Author Share Posted July 17, 2014 Your should replace .LOCAL/ENDL by .PROC/ENDP for things that are considered subroutine/procedures. As opposed to LOCALs, PROCs are exclusive in the same scope. Opposed to that LOCALs are cummulative, so this code below is no compile time error! But something you really don't want... believe me,it took days to find it :-) .local test lda #1 rts .endl .local test lda #2 rts .endl Another nice compiler feature. Thanks for the warning. Unfortunately I already converted all my PROCs to LOCALs some time ago: PROCs don't work with SDX relocatables, and someone told me LOCALs were a lot faster for the compiler and/or WUDSN to process. I'll just have to be careful, then. Quote Link to comment Share on other sites More sharing options...
+JAC! Posted July 18, 2014 Share Posted July 18, 2014 For WUDSN is does not make any difference and for MADS is actually should also not make a difference (have no reasonably large code example for testing that - maybe you have :-) ), as long as you don't use formal parameters with PROC. The formal parameters are probably also the only reason why I'd think relocating won't work. When calling the procedure, MADS generates stub code with absolute adresses to pass the values. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 18, 2014 Author Share Posted July 18, 2014 For WUDSN is does not make any difference and for MADS is actually should also not make a difference (have no reasonably large code example for testing that - maybe you have :-) ), as long as you don't use formal parameters with PROC. The formal parameters are probably also the only reason why I'd think relocating won't work. When calling the procedure, MADS generates stub code with absolute adresses to pass the values. Not sure if it was you who explained the problem with PROC and SDX relocatables, but they simply didn't work for me regardless of whether there were any formal parameters. Since I don't (currently) pass parameters via PROC I simply abandoned procedure blocks in every project and replaced them with LOCALs. It's relevant here because it looks like I'll have to write a loader to handle SDX relocatables in the GUI (MADS' native relocatable files being unsuitable for various reasons), so unless the PROC problem is fixed, LOCAL it shall be. Of course in the ROM-based (non-relocatable) code, we're talking about nothing more than an extensive search and replace operation to substitute one for another. But if the bug only arises because of cumulative definitions in the same scope, I can probably live with it. I noticed the issue before, IIRC, and posted in the MADS thread some time ago. I can remember being told at the time that the LOCAL behaviour was "as intended". Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 19, 2014 Author Share Posted July 19, 2014 @Prodatron: Curious to know how or if you avoid linear searching of the message queue to find the desired addressee: http://atariage.com/forums/topic/227822-bitmap-allocation/?do=findComment&comment=3034655 Quote Link to comment Share on other sites More sharing options...
Prodatron Posted July 19, 2014 Share Posted July 19, 2014 @Prodatron: Curious to know how or if you avoid linear searching of the message queue to find the desired addressee: http://atariage.com/forums/topic/227822-bitmap-allocation/?do=findComment&comment=3034655 For sending messages I just do a linear search through the message queue to find a free entry. The core loop takes 9 microseconds for each entry. So in worst case, when the queue is nearly full, it will take 9*64 microseconds to find the (last) free entry. Receiving messages is always done at the same quick speed: There is a pointer for each process which is either NULL or points to the first message in the queue. Each queue entry itself contains a pointer to the next message. This is NULL, if there is no next message. So you only need to check the pointer, grab the message and update the "first" pointer and the "next" pointer and the empty flag. I choosed the way with the linear search for empty entries, as it's very quick as long as there are not too much entries in the queue. Even if there are already 10 entries, it only takes 90 microseconds, which is probably still faster compared to a more complex algorythm, which is also able to search quickly in a full queue. But in most cases the message queue isn't that full (in general that only happens if something "hangs" a little bit - in this case the system is currently slow in any case, so who cares about the message queue ), so that was the reason for choosing the simple way which is faster then. 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 19, 2014 Author Share Posted July 19, 2014 (edited) For sending messages I just do a linear search through the message queue to find a free entry. The core loop takes 9 microseconds for each entry. So in worst case, when the queue is nearly full, it will take 9*64 microseconds to find the (last) free entry. Yeah: seems reasonable in all but extreme cases, as you say. It's about ten machine cycles per loop iteration on the Atari, so 640 cycles for a full list. As it happens, there's a much faster way, which I'll write about in the other thread. Receiving messages is always done at the same quick speed: There is a pointer for each process which is either NULL or points to the first message in the queue. Each queue entry itself contains a pointer to the next message. This is NULL, if there is no next message. So you only need to check the pointer, grab the message and update the "first" pointer and the "next" pointer and the empty flag. I'm still slightly unclear on a couple of points, although I may have misunderstood your original emailed description of the queue. The same queue stores messages between all different processes, so (in FIFO order), you might have: [0] Message for process 1 [1] Message for process 2 [2] Message for process 3 [3] Message for process 2 [4] Message for process 3 So even if process 3's pointer points to [2], there'll still be a linear search, or some list walking, to get to process 3's next message at [4]? Unless the queue is maintained so that messages for a given process are kept together in the queue? I'm also interested in a mechanism to handle messages intended for all processes. Such a message would have to be kept in the queue until all addressees have received it. Edited July 19, 2014 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Prodatron Posted July 19, 2014 Share Posted July 19, 2014 Sorry I am currently out but will answer tomorrow! The cool thing is now, that you brought me to an idea how to make searching for an empty entry fast and constant (so MessageSend will also have always the same constant speed like MessageReceive) It is just another linked list in one direction. There is a base pointer, which points into a list of free entries where each entry points to the next free one. Reserving and releasing an entry both is quite easy. Really cool! 1 Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted July 19, 2014 Share Posted July 19, 2014 You could try what the Amiga does - all the messages don't go in one queue, every task makes one or more ports that serve as the queue for messages for the task. You allocate one or more signals for each port, so the system knows when signals occurs which ports to process. Quote Link to comment Share on other sites More sharing options...
Prodatron Posted July 20, 2014 Share Posted July 20, 2014 This is the way how it works in SymbOS: - each process has one origin pointer to its first message in the queue. If this pointer is NULL there is no message available - each message within the queue has a pointer to the next message within the queue, which is available for the process as well. If this is NULL there is no other message available for the process. - so if a process looks for a new message, it first checks its origin pointer. If it's not NULL it grabs the message. Then it updates the origin pointer with the pointer of the grabbed message. The new linked list for free entries is done in the following way. - there are 64 pointers for each message queue entry placed in the same order like the messages in the queue - each points to a next free entry (so at the beginning, entry 1 points to 2, entry 2 points to 3 etc...) - an origin pointer outside this list points to the first empty entry. - if you allocate a new entry, you will take the one, where the origin pointer links to. The origin pointer then links to the entry, where the occupied one pointed before. - if you free an entry, the origin pointer will now link to the new free one. The new free one then will point to the entry, where the origin pointer was linked before. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 20, 2014 Author Share Posted July 20, 2014 Thanks for the explanation. So it seems to me that as long as the messages for a given process are consecutive in the main queue, everything will work perfectly using a head, tail and pending message counter in each process's pointer table. I wrote (yet) more linked list code last night which inserts a new node after node N (i.e. a process's "last message" pointer). So - when sending a message: * If there are currently no pending messages for the target process, place the message at the end of the queue and point the process's "first" and "last" message pointers at the new message. Set pending message count to 1. * If there are already pending messages for the target process, place the message immediately after the node pointed to by the process's "last message" pointer, update the pointer, and bump the pending message count. When pulling a message off the queue: * Get the process's "first message" pointer, grab the message, point "first message" at the "next" pointer, and decrement the pending message count. This way keeps things nice and simple with just a couple of extra pointers in the process descriptions. I suppose messages intended for more than one recipient will have to be instanced multiple times, because messages without a specific addressee just don't fit this scheme at all. Still don't know what SymbOS does with those. Anyway: we've banished linear searching from almost every area now. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 20, 2014 Author Share Posted July 20, 2014 (edited) Here's the revised "Send Message" routine, using the free node list and the per-process head and tail pointers: ; ---------------------------------------------------------------------------- ; SendMessage ; XY = message buffer ; A = Receiver ID (-1 = send to any process) ; Returns: Y = 1 = success, 2 = receiver doesn't exist, 0 = queue full ; ---------------------------------------------------------------------------- .local MessageSend sty KernelPtr1+1 ; save message address MSB pla ; get X (buffer LSB) sta KernelPtr1 pla ; get receiver ID (A) sta KernelTmp1 lda QueueEntries cmp #MaxQueueEntries bcs QueueFull ldy KernelTmp1 ; we know we have space for the message, so see if addressee exists lda Process.State,y bpl @+ ldy #KernelStatus.NonexistentProcess ; if receiver doesn't exist bne Fail @ ldx QueueFreeNodeHead ; get a free message node lda QueueFreeNodeNext-1,x sta QueueFreeNodeHead ; free node is in X lda Process.PendingMessages,y ; does process already have pending messages? beq NonePending ; if not, just add message to end of queue and initialise process head and tail pointers lda Process.MsgQueueTail,y ; get process's last queued message bne AddMsg NonePending ; addressee has no pending messages, so add message at end of queue lda QueueTailNode beq IsEmpty AddMsg tay sta QueuePrev-1,x ; our prev pointer lda QueueNext-1,y sta QueueNext-1,x ; our next pointer txa ; new node pointer sta QueueNext-1,y ; prev node's next pointer ldy QueueNext-1,x beq AtEnd txa sta QueuePrev-1,y ; next node's prev pointer ldy KernelTmp1 ; get IPID bne UpdateTail IsEmpty ; come here if we're starting with a completely empty message queue stx QueueHeadNode ; our newly allocated node lda #0 sta QueuePrev-1,x ;init prev and next pointers sta QueueNext-1,x txa ldy KernelTmp1 ; get IPID sta Process.MsgQueueHead,y ; point head at this, the process's only pending message AtEnd stx QueueTailNode ; update tail pointer if we're at end of list UpdateTail txa sta Process.MsgQueueTail,y ; point process's tail pointer at the newly added message CopyMessage inc QueueEntries ; say we added a message inc Process.PendingMessages,y ; bump process's pending message count lda ActiveTask ; KernelSenderID sta QueueSenderID-1,x lda KernelTmp1 ; KernelReceiverID sta QueueReceiverID-1,x lda QueueNodeLo-1,x ; now make pointer to the new node sta KernelPtr2 lda QueueNodeHi-1,x sta KernelPtr2+1 ldy #MessageSize-1 @ lda (KernelPtr1),y sta (KernelPtr2),y dey bpl @- ldy KernelTmp1 ; get IPID lda Process.State,y ; is receiving process sleeping unitl it gets a message? bne NotSleeping ; if process is ready or already waking up, just leave message in queue lda Process.WakeOnSender,y ; is process sleeping on message from this sender? ; cmp #ProcessID.Any ; beq StartWakeUp ; if receiver is waiting on message from any process, wake it up cmp ActiveTask ; otherwise, see if it's waiting on a message from us bne NotSleeping ; if not, leave it sleeping StartWakeUp lda #ProcessState.WakingUp ; say process has incoming message and should be woken up by the scheduler sta Process.State,y NotSleeping ldy #KernelStatus.OK ; say OK jmp ReturnWithContextSwitch QueueFull ldy #KernelStatus.QueueFull Fail jmp KernelReturn .endl Note "cmp #ProcessID.Any" is currently commented out, since we have no way to deal with messages for multiple recipients yet using this data structure. The receive message code is now getting the same treatment. The only loop is now the message buffer copy code, so we've made lots of great cycle savings here. Edited July 20, 2014 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
