bohoki Posted December 31, 2009 Share Posted December 31, 2009 (edited) a while ago i told of how i got out all my pc joysticks and how 2 of them were horrible with jitter well i looked them both over again today and noticed that both jutter in missile command the exact same way back and forth at a constant rate about 3-5 times per second then it hit me could it be the autofire interfering ? yep inside both culprits rests a 555 chip i cut the trace leading to pin one and blammo the jitter stopped i guess it drew too much current from the "pot common" and both of these joysticks had the 555 active all the time and it was just in there astablyvibrating so the joystick i thought was the worst my suncom fx2000 suddenly became my second favorite(after the gravis of course) funny the quickshots have autofire but i dont notice the jitter maybe they have a diffferent autofire method just a heads up incase anybody has this problem in the future Edited December 31, 2009 by bohoki Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted December 31, 2009 Share Posted December 31, 2009 I never tried it... I guess this means you can use a PC joystick on a 5200 with a female-female DB15? Quote Link to comment Share on other sites More sharing options...
bohoki Posted December 31, 2009 Author Share Posted December 31, 2009 (edited) I never tried it... I guess this means you can use a PC joystick on a 5200 with a female-female DB15? it takes a little more than that first off you need to have a way to press start so that takes having a working controller like with the "wico" so its kind of a y adapter just like the wico another little thing is that you need 2 capacitors also you need to modify a 15 pin female plug to fit in the console so the parts list consist of 2 female 15 pin 1 male 15 pin 2 capacitors (marked 204 or 224 or .22ufd) length of 6 conductor wire soldering skill and equip also a 15 pin pc joystick that is not driver based (should have a max of 4 buttons and centering trimmers for the pots other than that its a cakewalk Edited December 31, 2009 by bohoki Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted January 1, 2010 Share Posted January 1, 2010 Thanks for the details. Quote Link to comment Share on other sites More sharing options...
bohoki Posted January 1, 2010 Author Share Posted January 1, 2010 Thanks for the details. just copied it from here http://www.atarihq.com/5200/5200faq/06_04.html Quote Link to comment Share on other sites More sharing options...
