maguman Posted January 27, 2010 Share Posted January 27, 2010 I've used the old APX Insomnia sound editor program on real hardware. I was just looking for a version to use in an emulator, but I am having trouble getting it working. Specifically, the file "INSOMNIA.INS" designed to incorporate sound effects into BASIC is giving me trouble. It just hangs, even when trying the basic tests from the manual. The only version I have been able to find online was on atariarchives.org. This is the version that doesn't seem to work. Does anyone have an ATR with a copy that does work? Quote Link to comment Share on other sites More sharing options...
olavese@online.no Posted January 27, 2010 Share Posted January 27, 2010 I've used the old APX Insomnia sound editor program on real hardware. I was just looking for a version to use in an emulator, but I am having trouble getting it working. Specifically, the file "INSOMNIA.INS" designed to incorporate sound effects into BASIC is giving me trouble. It just hangs, even when trying the basic tests from the manual. The only version I have been able to find online was on atariarchives.org. This is the version that doesn't seem to work. Does anyone have an ATR with a copy that does work? This might work, hopefully : http://www.atariarchives.org/APX/showinfo.php?cat=20073 Quote Link to comment Share on other sites More sharing options...
maguman Posted January 27, 2010 Author Share Posted January 27, 2010 This might work, hopefully : http://www.atariarchives.org/APX/showinfo.php?cat=20073 Thanks, but that is the version I tried that doesn't work. I can't seem to find any other copies anywhere. Does anyone have a different copy? Quote Link to comment Share on other sites More sharing options...
olavese@online.no Posted February 5, 2010 Share Posted February 5, 2010 This might work, hopefully : http://www.atariarchives.org/APX/showinfo.php?cat=20073 Thanks, but that is the version I tried that doesn't work. I can't seem to find any other copies anywhere. Does anyone have a different copy? Do you start with Basic enabled? RUN "D:INSOMNIA.ED" It started fine for me, but I can not use it ... Just pressed some keys and saw something change Anyone have the manual? Quote Link to comment Share on other sites More sharing options...
maguman Posted February 5, 2010 Author Share Posted February 5, 2010 This might work, hopefully : http://www.atariarchives.org/APX/showinfo.php?cat=20073 Thanks, but that is the version I tried that doesn't work. I can't seem to find any other copies anywhere. Does anyone have a different copy? Do you start with Basic enabled? RUN "D:INSOMNIA.ED" It started fine for me, but I can not use it ... Just pressed some keys and saw something change Anyone have the manual? Gave up on it for a while and only just came back to it. After some trial and error I think I have found the problem - the supplied example doesn't work. Once I figured this out, and generated a new sound file, I managed to edit/save/load/play in a BASIC program etc without problems. I've got a copy of the manual - I can PDF it if you are interested. It is only a few pages long. Quote Link to comment Share on other sites More sharing options...
olavese@online.no Posted February 11, 2010 Share Posted February 11, 2010 This might work, hopefully : http://www.atariarchives.org/APX/showinfo.php?cat=20073 Thanks, but that is the version I tried that doesn't work. I can't seem to find any other copies anywhere. Does anyone have a different copy? Do you start with Basic enabled? RUN "D:INSOMNIA.ED" It started fine for me, but I can not use it ... Just pressed some keys and saw something change Anyone have the manual? Gave up on it for a while and only just came back to it. After some trial and error I think I have found the problem - the supplied example doesn't work. Once I figured this out, and generated a new sound file, I managed to edit/save/load/play in a BASIC program etc without problems. I've got a copy of the manual - I can PDF it if you are interested. It is only a few pages long. Would be great :-) Quote Link to comment Share on other sites More sharing options...
Syfo-Dyas Posted February 11, 2010 Share Posted February 11, 2010 I've not ran anything in basic for years. How exactly do I go about this again? I'd be interested in a manual too for when I get it running. The more musick programs the better. Quote Link to comment Share on other sites More sharing options...
