José Pereira Posted February 21, 2010 Author Share Posted February 21, 2010 I have a screen from char0 to47 Pf2Char at 18 and Pf3 at 19. When they scroll one pixel to left. Pf3 will enter in PF2 char. From my mind I must have 1Char at the middle. This way they never enter in conflict. Am I thinking right? Thanks. josé Pereira. Quote Link to comment Share on other sites More sharing options...
PeteD Posted February 21, 2010 Share Posted February 21, 2010 (edited) How does one char scroll left into another one?! I think I understand what you're thinking and no you're not thinking right The data doesn't scroll through the chars, the chars themselves move so you don't have to worry about the thing you're worried about *edit* Just to clarify.. 0000000011111111 AAAAAAAABBBBBBBB 0 and 1 are the screen positions of 2 chars, A and B is the data in them. What you're expecting to happen is this.. 0000000011111111 AAAAAABBBBBBBBCC When what actually happens (when using hardware scrolling at least) is this.. 0000001111111122 AAAAAABBBBBBBBCC Pete Edited February 21, 2010 by PeteD Quote Link to comment Share on other sites More sharing options...
José Pereira Posted February 21, 2010 Author Share Posted February 21, 2010 O.k. So it must be in your way. If it wasn't you could not scroll C64 in Colour Map. The 3 colours from one char will scroll over the other char 3colours. Let's say that PF2/3 are pseudo colour Map in A8 Off course C64 colours use screen pixels adress and also graphic Mode (that's why C64 can mix Graphic Modes) and A8 is by char code (<127 and >0128). So, no problem. And no problem even in a game with 4scrolling directions, like PACMANIA, right? Thanks. José Pereira. Quote Link to comment Share on other sites More sharing options...
PeteD Posted February 21, 2010 Share Posted February 21, 2010 No problem with any direction scrolling. As long as you're utilising the hardware scroll then it's the characters themselves that move, taking their definitions (the image) with them so the character number stays the same and it's definition looks the same, they're just shifted on the screen. If you took an example like the stationary panel next to a scrolling screen and the one method I mentioned where you'd copy data into the chars to offset the Y scroll of the entire screen (or have multiple definitions of them) then that could cause problems if you were using PF2/3 one above the other because you're no longer relying on the hardware scroll to handle the graphic moving. That's a pretty non-standard thing to do though and you'd easily design the panel around the problem. Pete Quote Link to comment Share on other sites More sharing options...
José Pereira Posted February 23, 2010 Author Share Posted February 23, 2010 I've always think of gettsome colours in Hi-Resol. games. This proves that it's possible in Isometric Games. All the traditional ones (MoleculeMan, Amaroute, Head over Heels,...) didn't use any PMGs., so, it is now possible if someone wants to, just adding this Sprites Routine. I started with HEAD OVER HEELS. In this one is only possible to colour the two guys. O.k. you'trer start to think: "this guy is stupid or what, Head and Heels will be seen when they are behind the walls. No they will not. The idea is: PM1 for the Guy that is on Bottom (priority when is next the other one) PM3 for the Guy at the Top. Now PM0 Mask of Top Guy and PM2 Mask of bottom guy. I creat the mask for the walls with the same shape as the real Head/Heels shapes. This is what you need in the walls. For Books, Doors,... you'll need another shapes(the Backr. graphics shape). And how this work: the PMs. Masks. use the PF2colour, and so, you don't see them but they are there... You will move there according to the real PMs. movement of the guys (Isometric guys up, it goes up on the Walls, and so on...) The Players will have different shapes and so will have the Masks. This is just some try I've made. This is not for someone saying I want that someone will start put PMs. on this games, but if someone wants to... GREAT! This could also be some thinking/possibility in some Hi-Resol. game ports (XXL, do you think it can be this way, even just our Player and/or an Enemy?). Greetings. José Pereira. Quote Link to comment Share on other sites More sharing options...
analmux Posted February 23, 2010 Share Posted February 23, 2010 Hmmmm, looks quite nice, these PM overlays + HiRes. Quote Link to comment Share on other sites More sharing options...
emkay Posted February 23, 2010 Share Posted February 23, 2010 Hmmmm, looks quite nice, these PM overlays + HiRes. Yes, and it is easier than in colour mode. You simply need a fitting "shade" of the softwaresprite and get 2 colours for it. Hires also is a good solution for overlays, because the overlays look bigger. But for a better view, the main background needs to be black and white, which would be no problem then. Quote Link to comment Share on other sites More sharing options...
emkay Posted February 23, 2010 Share Posted February 23, 2010 (edited) José , give it a try: Invert the graphics, make the background black, the walls put to brightness 6 and give the "Sprites" brightness a with the given colours. Edited February 23, 2010 by emkay Quote Link to comment Share on other sites More sharing options...
PeteD Posted February 23, 2010 Share Posted February 23, 2010 Looks pretty good. I agree with making it black/white. Don't worry too much about masks again, it's something the coder can handle. Pete Quote Link to comment Share on other sites More sharing options...
Tezz Posted February 23, 2010 Share Posted February 23, 2010 José , Invert the graphics, make the background black, the walls put to brightness 6 and give the "Sprites" brightness a with the given colours.Yes that's best way Jose, like I mentioned to you in PM a while back. Quote Link to comment Share on other sites More sharing options...
Tezz Posted February 23, 2010 Share Posted February 23, 2010 This could also be some thinking/possibility in some Hi-Resol. game portsYes absolutely, as you know, I've been working on a Spectrum game the past few months. Quote Link to comment Share on other sites More sharing options...
José Pereira Posted February 23, 2010 Author Share Posted February 23, 2010 José , give it a try: Invert the graphics, make the background black, the walls put to brightness 6 and give the "Sprites" brightness a with the given colours. I'm on the Streets and with a MAC near me. Could any of you quickly change, so that I can also see:anexos.zip Thanks. José Pereira. Quote Link to comment Share on other sites More sharing options...
José Pereira Posted February 25, 2010 Author Share Posted February 25, 2010 José , give it a try: Invert the graphics, make the background black, the walls put to brightness 6 and give the "Sprites" brightness a with the given colours. Sorry, but some things to be done yesterday(s). Here it is, although 6 seems to me a little bit dark. I changed PF and PMs. to A: (but I still think that we good choosen colour you could have the different Game Levels a different colour) Greetings. José Pereira. Quote Link to comment Share on other sites More sharing options...
Tezz Posted February 25, 2010 Share Posted February 25, 2010 Hi Jose, that's the way! if you're now working inversed so color1 is black and color2 is white the PM overlay will now have an independent brightness giving you more options. Regards, Tezz. P.S. I commonly also use the foreground brightness at A when I'm working with hi-res Quote Link to comment Share on other sites More sharing options...
José Pereira Posted February 25, 2010 Author Share Posted February 25, 2010 Hi Jose, that's the way! if you're now working inversed so color1 is black and color2 is white the PM overlay will now have an independent brightness giving you more options. Regards, Tezz. P.S. I commonly also use the foreground brightness at A when I'm working with hi-res That's what I did (and normally I use): PF1-Black. PF2-Gray(0A). Greetings. José Pereira. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 25, 2010 Share Posted February 25, 2010 José , give it a try: Invert the graphics, make the background black, the walls put to brightness 6 and give the "Sprites" brightness a with the given colours. Sorry, but some things to be done yesterday(s). Here it is, although 6 seems to me a little bit dark. I changed PF and PMs. to A: (but I still think that we good choosen colour you could have the different Game Levels a different colour) Greetings. José Pereira. As usual José, looks very nice. We need more hi-res stuff on the machine, especially with color. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
José Pereira Posted March 3, 2010 Author Share Posted March 3, 2010 Hello. What about Xenon and Bitmap Brothers Productions on A8: Can work. More later. José Pereira. Quote Link to comment Share on other sites More sharing options...
PeteD Posted March 3, 2010 Share Posted March 3, 2010 Xenon, at least the C64 version, was pretty dire and I doubt anyone would want it Pete Quote Link to comment Share on other sites More sharing options...
José Pereira Posted March 3, 2010 Author Share Posted March 3, 2010 Xenon, at least the C64 version, was pretty dire and I doubt anyone would want it Pete Yes, C64 is anwfull (Side Panel,...): But in A8 and me ( probably they would want... Greetings. José Pereira. Quote Link to comment Share on other sites More sharing options...
PeteD Posted March 3, 2010 Share Posted March 3, 2010 craaaaaazy José It's not just the way the C64 version looks, it plays really badly. Pete Quote Link to comment Share on other sites More sharing options...
José Pereira Posted March 3, 2010 Author Share Posted March 3, 2010 craaaaaazy José It's not just the way the C64 version looks, it plays really badly. Pete But like on the other Thread. "The things are going on.............." and I think they would PLAY this one on A8! Status Panel begin to look better: Expect to have all Sprites to show you tomorrow and you to understand what's in my mind. By, the way, if you change the colours (other Level) on screen than see what you'll get: (Now you're begining to see what's in my mind: have some Grays that change in all of the Game. The PMs. are on my mind for Enemys, Fired,...) Greetings. José Pereira. Quote Link to comment Share on other sites More sharing options...
José Pereira Posted March 3, 2010 Author Share Posted March 3, 2010 Sorry just this last one: Panel lines to the Grays that don't change in all Game/Levels. Not more screens today (I promise!). Bye... José Pereira. Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 4, 2010 Share Posted March 4, 2010 Xenon and even Xenon 2 would be great on a VBXE equipped system. But I doubt it's on many people's "to do" list. Quote Link to comment Share on other sites More sharing options...
emkay Posted March 4, 2010 Share Posted March 4, 2010 (edited) Isn't it interesting? Some games you find very "original" by the look of the scoreboard. But the scoreboard itself is nothing but the try of using a lesser game-screensize for compensating the missing hardware features of the machine where it was created for first. I'd bet this game was done for the Atari ST first, as "The Last Ninja" series was done for the C64 first. On the A8 it was always better to use non. Or at least no vertical scoreboard. If you don't find a good solution for a horizontal splitting of the scrollregisters (well, I never tried it), games like this might be impossible to reach ( if you want to have a reliable framerate) . Actually, if people really tried, games like the last ninja could be there easily, after removing some "C64 features" and adding some "A800" features. Others do screen size reducing, let's do it "atariwise" It's as simple: Using hires means to use the half of "bytes" to move around, compared to the colour mode. Single players get the double width, compared to the colour mode. Just using PMs for "underlay" in Hires and to use the colour mixing for adding transitions is the correct way to go in hires. On the other hand, in a small sized screenrange of 8x16 pixel, you could show all 128 colours "free" in the colour mode. And well, have a look at this one Just put the window to the left and get a hires screen inside a "G2F picture. Run a Demo or run a game with up to "5" (?) moving objects, just like in The Last Ninja.... Edited March 4, 2010 by emkay 1 Quote Link to comment Share on other sites More sharing options...
José Pereira Posted March 4, 2010 Author Share Posted March 4, 2010 Hello. Here again. Is it possible to Multiplexing (just 1Pm) that no. ships as same P1: Greetings. José Pereira. Quote Link to comment Share on other sites More sharing options...
