Gunstar Posted February 2, 2010 Share Posted February 2, 2010 Ta-DA! The Atari 2600XL! Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 2, 2010 Share Posted February 2, 2010 Ta-DA! The Atari 2600XL! I think you would have to have links between the two machines via SIO/joystick/etc. running distributive software to qualify as a single computer of 2600XL = 600XL+800XL+1200XL. I recall at some science fairs people had machines with labels like "256KXL" depending on what gadgets/expansions they put into them. Perhaps, you do have some WiFi links there that I don't see. Quote Link to comment Share on other sites More sharing options...
AB Positive Posted February 2, 2010 Share Posted February 2, 2010 Booo, I was hoping to see a weird XL-in-a-VCS type contraption. Of course, how'd you work without the keyboard... or perhaps a mod to have a ps/2 keyboard spot on it... Someone get to work on this! 2 Quote Link to comment Share on other sites More sharing options...
Marc Oberhäuser Posted February 2, 2010 Share Posted February 2, 2010 Booo, I was hoping to see a weird XL-in-a-VCS type contraption. Of course, how'd you work without the keyboard... or perhaps a mod to have a ps/2 keyboard spot on it... Someone get to work on this! I would like to see this the other way around. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted February 2, 2010 Share Posted February 2, 2010 I think you would have to have links between the two machines They're linked when powered-up. They share the same power outlet :-) Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 3, 2010 Share Posted February 3, 2010 I think you would have to have links between the two machines They're linked when powered-up. They share the same power outlet :-) I have seen some devices use the power lines for sending data signals. However, I don't see any power lines in the picture either-- perhaps there's lithium ion rechargeable batteries inside. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted February 3, 2010 Share Posted February 3, 2010 I have seen some devices use the power lines for sending data signals. However, I don't see any power lines in the picture either-- perhaps there's lithium ion rechargeable batteries inside. Nah, batteries are too outdated. Must be a wireless energy transfer system. http://en.wikipedia.org/wiki/Wireless_energy_transfer Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 6, 2010 Share Posted February 6, 2010 I have seen some devices use the power lines for sending data signals. However, I don't see any power lines in the picture either-- perhaps there's lithium ion rechargeable batteries inside. Nah, batteries are too outdated. Must be a wireless energy transfer system. http://en.wikipedia.org/wiki/Wireless_energy_transfer I have yet to see that in some pratical use. But here's an article using a 2nd Atari for printer spool: http://www.atarimagazines.com/v7n7/8BitToolhouse.html They also have a two-button mouse article there, but so far it seems Atari ST mice on 8-bit only allow using one-button. Anyone do a hack to use the 2nd button on Atari 8-bit? Quote Link to comment Share on other sites More sharing options...
R4ngerM4n Posted February 6, 2010 Share Posted February 6, 2010 Booo, I was hoping to see a weird XL-in-a-VCS type contraption. Same here... Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 9, 2010 Share Posted February 9, 2010 I have seen some devices use the power lines for sending data signals. However, I don't see any power lines in the picture either-- perhaps there's lithium ion rechargeable batteries inside. Nah, batteries are too outdated. Must be a wireless energy transfer system. http://en.wikipedia.org/wiki/Wireless_energy_transfer I have yet to see that in some pratical use. But here's an article using a 2nd Atari for printer spool: http://www.atarimagazines.com/v7n7/8BitToolhouse.html They also have a two-button mouse article there, but so far it seems Atari ST mice on 8-bit only allow using one-button. Anyone do a hack to use the 2nd button on Atari 8-bit? Well, here's the A1001 Mouse-- hack I just did few minutes ago. This is an Amiga mouse which works on Atari 8-bit and both buttons can be read and it still works on Amiga. Didn't want to screw with my ST mouse as I only have one of those whereas I have about 5 Amiga mice. So just attach 4K resistor from pin 9 (second button line) to pin 7 (+5V) line. I did use soldering, the scotch tape in the picture is to prevent the resistor legs from touching the ground. If the colors of the wires are consistent for these Amiga mice, they are the following: pin 1 wire is brown pin 2 wire is red pin 3 wire is orange pin 4 wire is yellow pin 5 is n.c. pin 6 wire is blue pin 7 wire is purple pin 8 wire is thick black pin 9 wire is thin black So you do PEEK(53264) to read the trigger (first button) like usual and PADDLE(0) to read the second button. It will read < 4 for button NOT pressed and 228 for button pressed. I guess fast pot scan can help speed up the second mouse button reads. Quote Link to comment Share on other sites More sharing options...
