lykewyse Posted February 14, 2010 Share Posted February 14, 2010 (edited) A bit of rambling: Has anyone had any luck running a newer (non-serial) SIO2PC setup through a wireless USB hub? I read about this idea at the Atarimax forums but it looks like no one has actually tried it. The only apparent concerns in my mind are: a) slower transfer time than a direct connection (though an idea for sio2ethernet has been thrown around) b) compatibility with APE (though it seems like this should be a moot point; would APE not read it like any other USB hub?) c) a low end netbook would run about the same price as a good wireless hub Another fun thought... Most new mobile phones have a micro USB port. Many savvy geeks are buying phones with Android OS to develop new software. Wouldn't it be theoretically possible to port APE to Android and run an sio2mobile through Micro USB? Edited February 14, 2010 by lykewyse Quote Link to comment Share on other sites More sharing options...
candle Posted February 15, 2010 Share Posted February 15, 2010 if that is USB on the go port then it would be doable consider BlueTooth as a transport medium Quote Link to comment Share on other sites More sharing options...
falcon_ Posted February 15, 2010 Share Posted February 15, 2010 A bit of rambling: Has anyone had any luck running a newer (non-serial) SIO2PC setup through a wireless USB hub? I read about this idea at the Atarimax forums but it looks like no one has actually tried it. ... http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=428-1946-ND Looks like this will do it, as long as you don't mind a small bit of wiring and some driver making. ~$35 USD gives you the radio link for up to 50 meters. =peace= Falcon_ Quote Link to comment Share on other sites More sharing options...
Stephen J. Carden Posted February 16, 2010 Share Posted February 16, 2010 A bit of rambling: Has anyone had any luck running a newer (non-serial) SIO2PC setup through a wireless USB hub? I read about this idea at the Atarimax forums but it looks like no one has actually tried it. The only apparent concerns in my mind are: a) slower transfer time than a direct connection (though an idea for sio2ethernet has been thrown around) b) compatibility with APE (though it seems like this should be a moot point; would APE not read it like any other USB hub?) c) a low end netbook would run about the same price as a good wireless hub Another fun thought... Most new mobile phones have a micro USB port. Many savvy geeks are buying phones with Android OS to develop new software. Wouldn't it be theoretically possible to port APE to Android and run an sio2mobile through Micro USB? I use 3 of my USB Ape interfaces in wireless mode. www.lantronix.com sells a usb to ethernet server. I connected you usb ape devices to the lantronix usb device server. On my wireless laptop I configured the lantrnix USB device driver. I then connected to the remote device then started up Ape software. The ape software detected the APE usb device and then everythin worked great. Steve Quote Link to comment Share on other sites More sharing options...
