Champions_2002 Posted February 27, 2010 Share Posted February 27, 2010 Can anybody tell me what are the abbrevations for Atari Basic ie Position and and others Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 27, 2010 Share Posted February 27, 2010 From memory... BYE B. CL. CLOSE C. COLOR CS. CSAVE D. DATA DR. DRAWTO E. ENTER F. FOR G. GOTO GOS. GOSUB GR. GRAPHICS I. INPUT L. LIST LO. LOAD LOC. LOCATE LP. LPRINT N. NEXT NO. NOTE O. OPEN P. POINT PL. PLOT POS. POSITION . or R. REM RES. RESTORE RET. RETURN S. SAVE SE. SETCOLOR SO. SOUND ST. STATUS TR. TRAP X. XIO There are others but they aren't really useful because they don't save keystrokes, e.g. CLOA. FOR CLOAD Quote Link to comment Share on other sites More sharing options...
Champions_2002 Posted February 27, 2010 Author Share Posted February 27, 2010 From memory... BYE B. CL. CLOSE C. COLOR CS. CSAVE D. DATA DR. DRAWTO E. ENTER F. FOR G. GOTO GOS. GOSUB GR. GRAPHICS I. INPUT L. LIST LO. LOAD LOC. LOCATE LP. LPRINT N. NEXT NO. NOTE O. OPEN P. POINT PL. PLOT POS. POSITION . or R. REM RES. RESTORE RET. RETURN S. SAVE SE. SETCOLOR SO. SOUND ST. STATUS TR. TRAP X. XIO There are others but they aren't really useful because they don't save keystrokes, e.g. CLOA. FOR CLOAD Cheers Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted February 27, 2010 Share Posted February 27, 2010 PRINT PR. ? GET GE. Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted February 27, 2010 Share Posted February 27, 2010 Also, a useful explanation here. Quote Link to comment Share on other sites More sharing options...
dwhyte Posted February 27, 2010 Share Posted February 27, 2010 PRINT PR. ? GET GE. I've never understood the reasoning behind GE. It's not as if it's saving any characters or anything when you type it. Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 27, 2010 Share Posted February 27, 2010 PRINT PR. ? GET GE. That's the best one- ?. It saves a bunch of keystrokes and is also common on other platforms and doesn't get expanded by BASIC. Sometimes you abbreviate stuff like DR. (DRAWTO) and others on a single line and then you can't edit the line because BASIC has expanded the keywords beyond its limit. GE. rather than GET I guess helps if you have to write your programs if you don't have a method to save them. It saves handwriting time. Then you can OCR it back in and run a spell-check to get your program back into BASIC. Quote Link to comment Share on other sites More sharing options...
ZylonBane Posted February 27, 2010 Share Posted February 27, 2010 I've never understood the reasoning behind GE. It's not as if it's saving any characters or anything when you type it. There is no "reasoning" behind it. All the keyword abbreviations are derived automatically by the parser. Try reading the link KrZerotki posted. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 27, 2010 Share Posted February 27, 2010 They aren't specifically coded. It works that way because GET is the first keyword that begins with the letters "GE" in the list of keywords. GOTO is the first "G" keyword, and REM is the first keyword out of all of them. PRINT is a special case, it's stored in the list both as "PRINT" and "?". By hacking the list, you can create your own one and two-stroke keywords...making it possible to enter lines that show up using 4 to 6 40-character lines when LISTed (essentially making lines impossible to edit - but still viewable - when reloading into an unhacked BASIC). Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 27, 2010 Share Posted February 27, 2010 They aren't specifically coded. It works that way because GET is the first keyword that begins with the letters "GE" in the list of keywords. GOTO is the first "G" keyword, and REM is the first keyword out of all of them. PRINT is a special case, it's stored in the list both as "PRINT" and "?". By hacking the list, you can create your own one and two-stroke keywords...making it possible to enter lines that show up using 4 to 6 40-character lines when LISTed (essentially making lines impossible to edit - but still viewable - when reloading into an unhacked BASIC). That's true. You can actually customize your own two-stroke keywords and still distribute the code since BASIC will expand the keywords back anyway. I suppose if you like to type and want more keystrokes, you can keep toggling the ATARI LOGO key since BASIC doesn't mind if the commands (not the args) are entered in inverse. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 27, 2010 Share Posted February 27, 2010 One of my favorite hacks (when I was into text-heavy programs) had all uppercase letters in reserved words changed to lowercase, so I didn't need to keep toggling that thing on and off or holding shift when writing a program. This was easy to hack...since the list is simple to find in a hex editor, and you only need to set bit 5 in the bytes to flip upper to lower. You can reorganize the list if you want as well (i.e. to place commands that you most often use near the top), so long as you set the last letter as inverse (high bit used as delimiter) and the two-byte address that follows the inverse character remains unchanged for that keyword. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted February 27, 2010 Share Posted February 27, 2010 POKE POK. PUT PU. READ REA. RUN RU. STOP STO. Quote Link to comment Share on other sites More sharing options...
atariksi Posted February 28, 2010 Share Posted February 28, 2010 It would be nice hack if someone wrote some time-slicer via VBI to run two BASIC programs at the same time. Perhaps, use the memory bank switching and swap in/out the ZP locations relevant to BASIC programs. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted February 28, 2010 Share Posted February 28, 2010 CTH_FASTBASIC does this with Atari Basic. Just a couple of poke's and you can swap CTH_FASTBASIC out and enter Atari Basic and return to CTH_Fast.... Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted March 2, 2010 Share Posted March 2, 2010 Quote Link to comment Share on other sites More sharing options...
