19Echo Posted March 11, 2010 Share Posted March 11, 2010 Okay, since i've been away from my atari for so long, im trying to figure out all the jargon again. what i'm trying to do is this: booted from my hard drive (800xl) with mydos. loaded up ape for windows and loaded up an atr file on disk 2 what is the command to copy the contents or disk from disk 2 to disk 1? (This is what happens when you dont love your atari for so long) Quote Link to comment Share on other sites More sharing options...
Mirage Posted March 11, 2010 Share Posted March 11, 2010 This should give you most of your answers: http://www.atarimax.com/ape/docs/DiskImageFAQ/index.html Specifically, scroll down to the section "How do I convert a REAL diskette into a disk image?" You need the APE_WARP.ATR image, then load the MyCopier program. From there, it's pretty self-explanatory. If you have a protected disk, skip that, and use ProSystem to copy it to a .PRO image. Quote Link to comment Share on other sites More sharing options...
danwinslow Posted March 11, 2010 Share Posted March 11, 2010 Okay, since i've been away from my atari for so long, im trying to figure out all the jargon again. what i'm trying to do is this: booted from my hard drive (800xl) with mydos. loaded up ape for windows and loaded up an atr file on disk 2 what is the command to copy the contents or disk from disk 2 to disk 1? (This is what happens when you dont love your atari for so long) copy d2:*.* d1: Quote Link to comment Share on other sites More sharing options...
+Stephen Posted March 11, 2010 Share Posted March 11, 2010 Okay, since i've been away from my atari for so long, im trying to figure out all the jargon again. what i'm trying to do is this: booted from my hard drive (800xl) with mydos. loaded up ape for windows and loaded up an atr file on disk 2 what is the command to copy the contents or disk from disk 2 to disk 1? (This is what happens when you dont love your atari for so long) copy d2:*.* d1: Takes a real dos to do it that way From the menu DOSes you will want to use the C command, then at the prompt, do "D2:*.*,D1:*.*". Note, there are no spaces, and you will not use the quotes. Quote Link to comment Share on other sites More sharing options...
danwinslow Posted March 11, 2010 Share Posted March 11, 2010 Okay, since i've been away from my atari for so long, im trying to figure out all the jargon again. what i'm trying to do is this: booted from my hard drive (800xl) with mydos. loaded up ape for windows and loaded up an atr file on disk 2 what is the command to copy the contents or disk from disk 2 to disk 1? (This is what happens when you dont love your atari for so long) copy d2:*.* d1: Takes a real dos to do it that way From the menu DOSes you will want to use the C command, then at the prompt, do "D2:*.*,D1:*.*". Note, there are no spaces, and you will not use the quotes. Ah, true, missed that part. I never use a non-cli dos. Quote Link to comment Share on other sites More sharing options...
