Mark_Coleco Posted March 18, 2010 Share Posted March 18, 2010 Hi, I used Ben Hecks A/V mod and it works perfect, took my 15 mins to do the soldering and less than 8 bucks for parts. I needed to do this to bypass the RF daughter board cause my snd wasnt working correctly. Anyhow I know Ben's hack doesn't account for the Atari Module sound when its connected. I was wondering Does anyone know where to place the leads of the audio so the Atari Module sound works aswell? I had this information before but I misplaced it. Quote Link to comment Share on other sites More sharing options...
+5-11under Posted March 18, 2010 Share Posted March 18, 2010 It's available inside the RF box, in the "column" of pads lined up front to back. I'm not 100% sure, but I think it's the second pin from the back (I connect other signals via pins 4 and 6, if I recall correctly). Otherwise you could do the same way I and probably others have done it - trial and error. Thanks, 5-1under Quote Link to comment Share on other sites More sharing options...
Mark_Coleco Posted March 18, 2010 Author Share Posted March 18, 2010 Thanks. From what I researched the 2nd pin down is the audio. Not sure if it will work for me cause my sound out of the RF jack is screwed up, hence why I bypassed it with the Ben Heck A/V mod. I think there's some place on the board I can get the audio from, before it hits the rf board...not sure I kinda remember seeing it some where. Its my only option to do it this way, unless I learn how to fix my RF jack problem. Quote Link to comment Share on other sites More sharing options...
Mark_Coleco Posted March 19, 2010 Author Share Posted March 19, 2010 Does anyone have Radio Shack part numbers for: 47uf capacitor and 75 ohm resistor ? I can't seem to locate them, someone suggested I use those with Ben Hecks A/V mod. Quote Link to comment Share on other sites More sharing options...
