Superchip ram usage
Pioneer4x4
I am working on a game that so far requires the superchip ram. If I can get it to not require it, great but I doubt it. If it does require the extra ram, what options do I have for putting in in hardware other than a harmony cart?
Basically, what carts use superchip that I can cannabalize for the cause? I want to make at least 2 prototypes, even if it all falls through. I have a good eprom burner, so I should be OK if I can hack up some old carts.
I found this list with a bit of googling. The only ones I have extras of are Dig Dug and Jr. Pac-Man. Any crime hacking up a Dig Dug?
Defender 2 / Stargate
Chrystal Castles
Dark Chambers
Desert Falcon
Dig Dug
Jr. Pac Man
KLAX
Millipede
Off the Wall
Radar Lock
Save Mary
Secret Quest
Shooting Arcade
Sprintmaster
Super Football
Chrystal Castles
Dark Chambers
Desert Falcon
Dig Dug
Jr. Pac Man
KLAX
Millipede
Off the Wall
Radar Lock
Save Mary
Secret Quest
Shooting Arcade
Sprintmaster
Super Football
It looks like you listed all of them, at least the "old" ones (i.e., non-homebrews).
If you don't want to use the Harmony/Melody cart, you could always try CBS RAM+ carts, or MNetwork carts with extra RAM. You might have to modify batari Basic, though, or get someone else to. I did a modification of the older 0.35 version of batari Basic to add E7 MNetwork bankswitching to it, although I haven't upgraded it to version 1.0 yet. But with the Harmony/Melody you should be able to use any of them.
Michael
Michael
Do you know which ones those are? I think the CBS are labelled on them with the RAM+
I didn't know MNetwork made them also.
Michael
The following is adapted from the document on game sizes by Kevin Horton (http://kevtris.org/files/sizes.txt):
Atari Superchip (a.k.a. the F8SC, F6SC, and F4SC methods)
8K (F8SC) = 7680 bytes of ROM and 128 bytes of extra RAM
16K (F6SC) = 15360 bytes of ROM and 128 bytes of extra RAM
32K (F4SC) = 30720 bytes of ROM and 128 bytes of extra RAM
Memory map:
$F000-$F07F = write addresses for the 128 bytes of extra RAM (always present)
$F080-$F0FF = read addresses for the 128 bytes of extra RAM (always present)
$F100-$FFFF = 3840 bytes of ROM, which is selected from two (F8SC), four (F6SC), or eight (F4SC) 4K ROM banks
Bankswitching hotspots:
$FFF4 = select the 1st 4K ROM bank in F4SC
$FFF5 = select the 2nd 4K ROM bank in F4SC
$FFF6 = select the 1st 4K ROM bank in F6SC, or the 3rd 4K ROM bank in F4SC
$FFF7 = select the 2nd 4K ROM bank in F6SC, or the 4th 4K ROM bank in F4SC
$FFF8 = select the 1st 4K ROM bank in F8SC, or the 3rd 4K ROM bank in F6SC, or the 5th 4K ROM bank in F4SC
$FFF9 = select the 2nd 4K ROM bank in F8SC, or the 4th 4K ROM bank in F6SC, or the 6th 4K ROM bank in F4SC
$FFFA = select the 7th 4K ROM bank in F4SC
$FFFB = select the 8th 4K ROM bank in F4SC
Games:
Dig Dug
Crystal Castles
Millipede
Stargate
Defender II
Jr. Pac-Man
Desert Falcon
Dark Chambers
Super Football
Sprintmaster
Fatal Run
Off the Wall
Shooting Arcade
Secret Quest
Radar Lock
Save Mary!
KLAX
CBS RAM+ (a.k.a. the FA method)
12K = 10752 bytes of ROM and 256 bytes of extra RAM
Memory map:
$F000-$F0FF = write addresses for the 256 bytes of extra RAM (always present)
$F100-$F1FF = read addresses for the 256 bytes of extra RAM (always present)
$F200-$FFFF = 3584 bytes of ROM, which is selected from three 4K ROM banks
$FFFA = select the 3rd 4K ROM bank
Games:
None listed?
M-Network (a.k.a. the E7 method)
16K = 15360 bytes of ROM and 2048 bytes of extra RAM
Memory map:
$F000-$F7FF = 2048 bytes of ROM (if one of the 2K ROM banks is selected), which is selected from seven 2K ROM banks
$F000-$F3FF = write addresses for 1024 bytes of the extra RAM (if the 1K RAM bank is selected)
$F400-$F7FF = read addresses for 1024 bytes of the extra RAM (if the 1K RAM bank is selected)
$F800-$F9FF = write addresses for 256 bytes of the extra RAM (always present), which is selected from four 256-byte RAM banks
$FA00-$FBFF = read addresses for 256 bytes of the extra RAM (always present), which is selected from four 256-byte RAM banks
$FC00-$FFFF = 1024 bytes of ROM (always present)
$FFE0 = select the 1st 2K ROM bank
$FFE1 = select the 2nd 2K ROM bank
$FFE2 = select the 3rd 2K ROM bank
$FFE3 = select the 4th 2K ROM bank
$FFE4 = select the 5th 2K ROM bank
$FFE5 = select the 6th 2K ROM bank
$FFE6 = select the 7th 2K ROM bank
$FFE7 = select the 2K RAM bank
$FFE8 = select the 1st 256-byte RAM bank
$FFE9 = select the 2nd 256-byte RAM bank
$FFEA = select the 3rd 256-byte RAM bank
$FFEB = select the 4th 256-byte RAM bank
Games:
Burgertime
Although not mentioned in Kevin Horton's document, there are other bankswitching methods that can have extra RAM:
4A50 (64K ROM and 32K RAM) - from supercat (not in production yet, but the Stella emulator can run 4A50 cart images)
CV (2K ROM and 1K RAM) - from Commavid (not a bankswitching method per se, since there are no banks to switch)
EFSC (64K ROM and ? RAM) - developed for the unfnished Home Runner game
3F (512K ROM and ? RAM) - an expansion of the Tigervision format?
Michael
CPUWIZ made Superchip (AKA SARA) boards. You can't easily hack up an old PCB, you would also have to add the bankswitching hardware (which is handled inside the mask ROM of the old games). I suppose you could wire up a 4K EPROM and have 4K with the superchip though. E7 or CBS would be harder to make a cartridge of without the Harmony/Melody.
Edited by Wickeycolumbus
Thanks, I guess I need to look at those boards. As for 4K with superchip Batari Basic will not allow 4K with superchip will it?
I'm not sure about bB, but I don't believe any emulators support 4K with superchip. You'd have to double up the ROM and use the F8SC setting for emulator testing.
I once went through Stella testing every bankswitched rom from Superchip roms. This is what I found:
8k
Defender II - NTSC, PAL (aka Stargate) note Defender II and Stargate have different roms...
Stargate - NTSC, PAL (aka Defender II)
Elevator Action - NTSC prototype
16k
Crack'ed - NTSC prototype
Crystal Castles - NTSC, PAL
Dark Chambers - NTSC, PAL
Desert Falcon - NTSC, PAL
Dig Dug - NTSC, PAL
Jr. Pac-Man - NTSC, PAL
Klax - NTSC prototype, PAL released
Millipede - NTSC, PAL
Off the Wall - NTSC, PAL
Radar Lock - NTSC, PAL
Save Mary! - NTSC, PAL (both late prototypes are superchip)
Secret Quest - NTSC, PAL
Shooting Arcade - NTSC, PAL (both are prototypes)
Sprint Master - NTSC, PAL
Super Football - NTSC, PAL
32k
Fatal Run - NTSC prototype, PAL released
Do you want to do your own soldering and harvest your own Superchips from old games? If so, you can ask CPUWIZ if he will sell you some boards. Otherwise, Albert can build your Superchip games with Melody boards.
I want to make sure it works first, I'm fine with soldering and should be OK burning a rom. I guess I'll have to wait until I get that far. What I'm working on will require 2 Ataris and I only have 1 Harmony, and 2 Superchargers. If I could make it work in 4k with no extra ram, I'm set.
