candle Posted March 31, 2010 Share Posted March 31, 2010 Hi all I need to annouce that new version of VBXE package is avaivable on project page the package was split into separate parts due to its size a must have is VBXE cores part that include actual cores and utility programs optional but recommended are programmer's manual, and examples installation guide is the same as it was in previous package and only vital for new users, or those of You who didn't have the time to install the board yet cheers candle & electron Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 1, 2010 Share Posted April 1, 2010 Many thanks: heading off to install this now. With the core finalized, maybe I'll make some progress with the VBXE stuff I'm working on. Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 1, 2010 Share Posted April 1, 2010 I'll probably be giving it a run later tonight. Jon - can you update as per your progress later? I'll also check out the GPRIOR bugfix. Quote Link to comment Share on other sites More sharing options...
Syfo-Dyas Posted April 1, 2010 Share Posted April 1, 2010 I about crapped. At first I thought you were announcing a second run of the board itself. Quote Link to comment Share on other sites More sharing options...
candle Posted April 1, 2010 Author Share Posted April 1, 2010 today it's not verry apriopriate day to do so Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 1, 2010 Share Posted April 1, 2010 Jon - can you update as per your progress later? Sources for VBXE version of The Last Word have been in stasis since uncertainty about text mode colour attributes. One of my priorities is to minimize VBXE handling code so that ordinary versions of LW can automatically use VBXE 80 column mode. I also have a lot of sources Draco sent regarding VBXE screen handlers which I need to look at. Most of this work is focused on getting the de facto VBXE compatible text editor written ASAP. I too am very interested in creating an A8 based software development environment. I already have the fast MA65 SpartaDOS assembler which I can patch up to be at least ATASM compatible. Assembling and testing software in-situ is no problem for small projects, and I'm keen to get back into it. Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 1, 2010 Share Posted April 1, 2010 (edited) Err... I just meant "how did your install go?" Anyhow... I've updated, seems OK. Flashed in V2FX122R & set as bootable and V2G102R. Edited April 1, 2010 by Rybags Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 1, 2010 Share Posted April 1, 2010 Err... I just meant "how did your install go?" LOL - sorry, it was unclear, since I have so much "progress" to make with this and that. Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 1, 2010 Share Posted April 1, 2010 Cool. I tried a quick/dirty test program to verify the PRIOR fix. No idea what I did with the original one that I used to point out the bug in the first place. I've discovered another quirk on my system though... if I type too hard it makes the screen jump slightly. Might have to open up over the weekend and make sure nothings jiggling loose. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 1, 2010 Share Posted April 1, 2010 I've discovered another quirk on my system though... if I type too hard it makes the screen jump slightly. Might have to open up over the weekend and make sure nothings jiggling loose. I have the same problem very occasionally. The (insulated) keyboard backplate on my 130XE is butted up against the pin headers on the VBXE board. Quote Link to comment Share on other sites More sharing options...
jvas Posted April 11, 2010 Share Posted April 11, 2010 Hi, I've just "flashed" my VBXE with the new core, and it works great! Thanks!!!! Cheers, Jozsi Quote Link to comment Share on other sites More sharing options...
