Havok69 Posted April 5, 2010 Share Posted April 5, 2010 Looking to get back into the 8 bit scene and I definitely want a SIO2PC. The site documentation is a bit confusing however. Can I use it to access cartridge images, or do I also need to pick up a Flash Multi-Cart? and while on the subject of the multi-cart, besides more storage space, why would I choose the 8 over the 1mbit version? Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 5, 2010 Share Posted April 5, 2010 SIO2PC/APE is only good for emulating a disk drive, and otherwise doesn't change your setup from default. Many cartridges have been converted to executables anyway, so it's not a total loss there. A multi Flashcart will run some cartridges, practically all the 8K ones should work without problem, and many others will likely be hacked so as to work on it. 1 mbit = 128K so obviously the 8 mbit cart will hold a lot more images, and the cost isn't all that much more. Quote Link to comment Share on other sites More sharing options...
atariksi Posted April 6, 2010 Share Posted April 6, 2010 SIO2PC/APE is only good for emulating a disk drive, and otherwise doesn't change your setup from default. Many cartridges have been converted to executables anyway, so it's not a total loss there. A multi Flashcart will run some cartridges, practically all the 8K ones should work without problem, and many others will likely be hacked so as to work on it. 1 mbit = 128K so obviously the 8 mbit cart will hold a lot more images, and the cost isn't all that much more. What about the USB cartridge-- how many mbits is that one? Quote Link to comment Share on other sites More sharing options...
atariksi Posted April 6, 2010 Share Posted April 6, 2010 Looking to get back into the 8 bit scene and I definitely want a SIO2PC. The site documentation is a bit confusing however. Can I use it to access cartridge images, or do I also need to pick up a Flash Multi-Cart? and while on the subject of the multi-cart, besides more storage space, why would I choose the 8 over the 1mbit version? I tried uploading ROMs using a simple upload to RAM, but it doesn't work for most ROM images as they are copy-protected so they expect a READ-ONLY memory. There was some thread on this forum a few months ago. Some ROMs do work by uploading to same location in RAM $8000 or $A000. Quote Link to comment Share on other sites More sharing options...
