bfollett Posted April 18, 2010 Share Posted April 18, 2010 I just tried booting Alternate Reality - The dungeon using Altirra and it skipped the whole Alien space craft abduction sequence and went straight to the menu to create or load characters? The disk image I have works fine in atari800win. I'm not sure If I have some setting wrong in Altirra or if has a bug. Anyway, I'll attach the disk 1 image I have for Alternate Reality the Dungeon, if someone else want to try it. Thanks Bob Quote Link to comment Share on other sites More sharing options...
bfollett Posted April 18, 2010 Author Share Posted April 18, 2010 Oops, helps to attach the file correctly Alternate Reality The Dungeon (s1).atr Quote Link to comment Share on other sites More sharing options...
eeun Posted April 18, 2010 Share Posted April 18, 2010 (edited) Your image loads into the city abduction sequence when I test it (using both Atari800win and Altirra). Did you press any keys on the Heist intro screen that might have caused it to skip the intro? I didn't touch anything and let it boot on its own. Edited April 18, 2010 by eeun Quote Link to comment Share on other sites More sharing options...
bfollett Posted April 19, 2010 Author Share Posted April 19, 2010 Your image loads into the city abduction sequence when I test it (using both Atari800win and Altirra). Did you press any keys on the Heist intro screen that might have caused it to skip the intro? I didn't touch anything and let it boot on its own. No, I'm not pressing any keys in either emulator. It boots into the heist then -city abduction scene on atari800win, and skips both when I run altirra. What version of altirra are you using? I'm using version 1.5 Thanks, Bob Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 19, 2010 Share Posted April 19, 2010 Are you using one of the built-in kernels (HLE/LLE), or atarixl.rom? It looks like there is a bug in the HLE kernel ROM that is causing this, but it works fine with the real Atari kernel ROM. It's recommended that you always use a real kernel ROM with Altirra if you have one available. Quote Link to comment Share on other sites More sharing options...
bfollett Posted April 19, 2010 Author Share Posted April 19, 2010 Are you using one of the built-in kernels (HLE/LLE), or atarixl.rom? It looks like there is a bug in the HLE kernel ROM that is causing this, but it works fine with the real Atari kernel ROM. It's recommended that you always use a real kernel ROM with Altirra if you have one available. Ahhh that must be it. I'd forgetting that I had trouble getting altirra to see the original rom images when I first installed it. I guess I'll have to revisit that issue instead. Thanks for the help, Bob Quote Link to comment Share on other sites More sharing options...
eeun Posted April 19, 2010 Share Posted April 19, 2010 (edited) Huh... I was using the LLE Kernel. First time I'd used Altirra, so I copied my roms into its directory after a quick glance at the readme and didn't realize it had its own built-ins. I didn't change any of the default settings before opening and booting the Alt. Reality disk image. The Altirra version is 1.0, freshly downloaded. I'd suggest trashing Altirra's preferences, but I can't seem to figure out just where the program stores them. Edited April 19, 2010 by eeun Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 20, 2010 Share Posted April 20, 2010 Huh... I was using the LLE Kernel. First time I'd used Altirra, so I copied my roms into its directory after a quick glance at the readme and didn't realize it had its own built-ins. I didn't change any of the default settings before opening and booting the Alt. Reality disk image. The Altirra version is 1.0, freshly downloaded. I'd suggest trashing Altirra's preferences, but I can't seem to figure out just where the program stores them. Err, 1.0?? The latest released version is 1.5. Altirra stores preferences in the Registry, under HKEY_CURRENT_USER\Software\VirtualDub.org\Altirra. By the way, I figured out the real problem: OPTION is being held down too long. By default, Altirra holds down OPTION to disable BASIC, and with the built-in kernels and with SIO patch enabled, the intro boots in less than five frames. Quote Link to comment Share on other sites More sharing options...
