voiddweller Posted November 12, 2002 Share Posted November 12, 2002 The support bearing is rusted solid and un-repairable. So, I ordered a new one from Best Electronics. However, it doesn't come with the center pin to support it. How do I get the old pin out (without damaging the pin) and put it in the new bearing? Thanks! - VD P.S. BTW - Bradley said he is in the process of starting production on the Gold-dot 5200 fire-buttons (a few months away) and is considering gold-dot keypads. Quote Link to comment Share on other sites More sharing options...
voiddweller Posted November 13, 2002 Author Share Posted November 13, 2002 Anyone??? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 13, 2002 Share Posted November 13, 2002 Mine isn't rusted so I've never tried it. I suppose a few carefull blows with a hammer would do it. Maybe spray some WD40 on it first to loosen it up. Mitch http://atari7800.atari.org Quote Link to comment Share on other sites More sharing options...
voiddweller Posted November 13, 2002 Author Share Posted November 13, 2002 Thanks! How much force do you think that pin can take? - VD Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 13, 2002 Share Posted November 13, 2002 I don't really know. Go fairly easy on it though. Now that I think about it, you may be able to find a pin at a hardware store. I know they have some metal pins available. Good luck Mitch http://atari7800.atari.org Quote Link to comment Share on other sites More sharing options...
voiddweller Posted November 18, 2002 Author Share Posted November 18, 2002 I received the new bearing from Best-Software. I put the old one in a vise and gently (well...at first it was gently) tapped out the pin with the flat end of a screw of the same diameter. I put some wood in the vise and gently tapped the pin back in while the bearing was jammed in the wood, preventing damage to the surface. The operation was a success and I am fully enjoying Centipede and Missile Command again!!! - VD Quote Link to comment Share on other sites More sharing options...
