rpgfaker Posted May 2, 2010 Share Posted May 2, 2010 I try launching DASM from windows vista but it turns off. I also have a copy of DASM included with bB and VbB but it don't launch on its own either without the IDE. Am I launching the program wrong or missing something? Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted May 2, 2010 Share Posted May 2, 2010 You have to use the command prompt. Read this for further information. Quote Link to comment Share on other sites More sharing options...
rpgfaker Posted May 2, 2010 Author Share Posted May 2, 2010 (edited) ah thanks didn't know it was a command line. Does this look right? Should I include a folder in dasm for my projects and for my output? Edited May 2, 2010 by rpgfaker Quote Link to comment Share on other sites More sharing options...
rpgfaker Posted May 2, 2010 Author Share Posted May 2, 2010 Ah nevermind I got it going, compiled adventure into a bin and tested it on my psp, works like a charm. Quote Link to comment Share on other sites More sharing options...
rpgfaker Posted May 2, 2010 Author Share Posted May 2, 2010 I thought I'd mention one other thing when I was using distella. The adventure.bin (the commented source from Minidig) I made from dasm wouldn't disassemble in distella. I got an error that it couldn't locate the file. So I tried a different source using the .bin from AA and it disassembled and recompiled it fine. So why didn't it like the commented source version? Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted May 2, 2010 Share Posted May 2, 2010 Nukey Shay has a good commented 8k Adventure assembly code around here some place. I highly recommend it if you want to hack Adventure. Quote Link to comment Share on other sites More sharing options...
rpgfaker Posted May 2, 2010 Author Share Posted May 2, 2010 Nukey Shay has a good commented 8k Adventure assembly code around here some place. I highly recommend it if you want to hack Adventure. Thanks but I was using Adventure to see if dasm and distella were working right. Seems that if I remove all the comments from the source it can be assembled and disassembled. But distella seems to be picky about what can be disassembled, even some 4k bins give me an error where it can't locate the file. Haven't quite figured out it's deal. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 1, 2010 Share Posted June 1, 2010 It could be that your filename has additional extentions that aren't showing up (i.e. filename.ext.ext or filename[1].ext instead of just filename.ext. Look at the filenames using your browser, and uncheck any option that tells it to "hide filename extentions for known file types". Also, text files saved as word documents are incompatable. Be sure it's stored as text only. Quote Link to comment Share on other sites More sharing options...
