+Stephen Posted May 2, 2010 Share Posted May 2, 2010 I have what I believe is the latest version of Inertia MOD player (4.5). It seems to be hardcoded to look for a Covox at $D600. I cannot run mine there since I will be running a VBXE2. I have the Covox mapped to $D280. Is there an easy way to modify the program to work with the Covox mapped to $D280? I know NeoTracker lets you specify before it build the executable. Quote Link to comment Share on other sites More sharing options...
candle Posted May 2, 2010 Share Posted May 2, 2010 you may put simplestereo board in vbxe mode it will bypass covox address decoder and let you control it directly from VBXE board, so d600-d603 will be available for your needs Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 2, 2010 Share Posted May 2, 2010 Hello Stephen IIRC version 4.5 isn't the latest version. There is a version with a lower version number that's newer or at least better. greetings Mathy Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 2, 2010 Author Share Posted May 2, 2010 you may put simplestereo board in vbxe mode it will bypass covox address decoder and let you control it directly from VBXE board, so d600-d603 will be available for your needs Cool - the VBXE will soon be in the machine. I already have ANTIC socketed so it should be a relatively quick install. Quote Link to comment Share on other sites More sharing options...
