Sleepy Posted May 3, 2010 Share Posted May 3, 2010 I´m going to use an ATARI-ST-monitorsocket for my VBXE. Are there any established standard-pinouts for the use with an XL/XE already? I think ground, red/blue/green & composite video should be the same as used with an ST, H- & V-Sync also. Sound (stereo) could be at 1 & 5 (ST uses it as audio in & out). Thanks, Sleepy Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 3, 2010 Share Posted May 3, 2010 (edited) VBXE doesn't supply Sync, you take it off the mainboard. And it's Composite Sync, no seperate H/VSync, so you'd just route it to HSync on your output jack. AFAIK, only a few have taken the ST port route... only really useful if you're going to use an ST monitor, although using a DIN has the advantage that you replace the factory one and don't need to modify your case. Edited May 3, 2010 by Rybags Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 3, 2010 Share Posted May 3, 2010 I fitted an ST jack (to SCART) in tandem with the DIN 5 legacy socket. Looks good, and leaves plenty of spare pins in case you want to wire up stereo sound and such like. Quote Link to comment Share on other sites More sharing options...
pps Posted May 3, 2010 Share Posted May 3, 2010 (edited) I fitted an ST jack (to SCART) in tandem with the DIN 5 legacy socket. Looks good, and leaves plenty of spare pins in case you want to wire up stereo sound and such like. I plan to use the ST connector, too. The advantage is that you can easily use a standard ST to TV (SCART) connector cable and you don´t need to cut the back of the computer for a new hole. Edited May 3, 2010 by pps Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 3, 2010 Share Posted May 3, 2010 (edited) <wrong thread> Edited May 3, 2010 by Rybags Quote Link to comment Share on other sites More sharing options...
