Atari2600VCS Posted June 19, 2010 Share Posted June 19, 2010 Hi all, Freeway is my all time favorite game, but it doesn't last long enough. Could someone make Freeway with a longer timer? Maybe three times longer than the normal time? Or could someone tell me what the address is and I could change it? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 19, 2010 Share Posted June 19, 2010 (edited) LDA $88 ;3 (red color/screensaver) LDY $E6 ;3 Check game state BNE LF05D ;2 branch if game over LDY $E9 ;3 load timer (high) CPY #$20 ;2 = 32? BCC LF055 ;2 branch if less INC $E6 ;5 bump game state (game over) LF055: CPY #$1E ;2 timer (high) = 30? BCC LF05D ;2 branch if less LDA $81 ;3 use framecounter for color AND $87 ;3 adjust for color/B&W LF05D: STA COLUP0 ;3 store to both sprites STA COLUP1 ;3 .. To triple the amount of time, change the #$20 at $F050 to be #$60. However, this does not change the amount of time before the scores begin to flash. You can change that at $F056 (you'd alter the #$1E to #$5E at $F056 in this case to make the score flash about 5 seconds from game end). Long_Freeway.bin Edited June 19, 2010 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
Atari2600VCS Posted June 19, 2010 Author Share Posted June 19, 2010 LDA $88 ;3 (red color/screensaver) LDY $E6 ;3 Check game state BNE LF05D ;2 branch if game over LDY $E9 ;3 load timer (high) CPY #$20 ;2 = 32? BCC LF055 ;2 branch if less INC $E6 ;5 bump game state (game over) LF055: CPY #$1E ;2 timer (high) = 30? BCC LF05D ;2 branch if less LDA $81 ;3 use framecounter for color AND $87 ;3 adjust for color/B&W LF05D: STA COLUP0 ;3 store to both sprites STA COLUP1 ;3 .. To triple the amount of time, change the #$20 at $F050 to be #$60. However, this does not change the amount of time before the scores begin to flash. You can change that at $F056 (you'd alter the #$1E to #$5E at $F056 in this case to make the score flash about 5 seconds from game end). Thank you Nukey Shay, that's awesome, you're the best! I can now run like a chicken in a marathon. . Quote Link to comment Share on other sites More sharing options...
