gharmon Posted July 12, 2010 Share Posted July 12, 2010 I took possession of a SH205 Megafile 20 today. I have a 1040STF computer. Are there any experienced SH205 users listening? Will this 1040 talk to this drive? I do need to get a connecting cable and hopefully it is straight pin to pin connections. I'd also like to find any documentation on the drive as there are DIP switches in the unit. Also, this is one BIG drive assembly. Any help, suggestions, recommendations are appreciated. Thanks, gary Quote Link to comment Share on other sites More sharing options...
Chandler Posted July 13, 2010 Share Posted July 13, 2010 I took possession of a SH205 Megafile 20 today. I have a 1040STF computer. Are there any experienced SH205 users listening? Will this 1040 talk to this drive? I do need to get a connecting cable and hopefully it is straight pin to pin connections. I'd also like to find any documentation on the drive as there are DIP switches in the unit. Also, this is one BIG drive assembly. Any help, suggestions, recommendations are appreciated. Thanks, gary i have a few spare new DMA cables to connect your SH205 to 1040 £10 for the cable plus shipping to USA (i'm in the UK) i'll also include the atari hard drive software on a floppy for free if you want the cable PM me C Quote Link to comment Share on other sites More sharing options...
gharmon Posted July 20, 2010 Author Share Posted July 20, 2010 OK....I got the 19 pin cable and book disk. The hard drive spins up and the yellow light talks to me but the screen tells me 'ERROR - Machine not STE". It's actually a 1040STFM. There are other notices that flash by during the boot up. Is it telling me the hard drive won;t with this computer? Thanks, gary Quote Link to comment Share on other sites More sharing options...
atarian63 Posted July 21, 2010 Share Posted July 21, 2010 OK....I got the 19 pin cable and book disk. The hard drive spins up and the yellow light talks to me but the screen tells me 'ERROR - Machine not STE". It's actually a 1040STFM. There are other notices that flash by during the boot up. Is it telling me the hard drive won;t with this computer? Thanks, gary We ran our retail store with one of these back in the day,I think we used a boot flooy in the st at first then had it bootable. As for the drive it is an MFM Seagate ST 225 5.25" hard drive. These can still be had on ebay or buy an ST251 40mb MFM,should work as well. You will need software to prep it. dont forget to enter the bad sector map and offset from the top of the drive. Cant recall but I think software will as for it. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted July 21, 2010 Share Posted July 21, 2010 OK....I got the 19 pin cable and book disk. The hard drive spins up and the yellow light talks to me but the screen tells me 'ERROR - Machine not STE". It's actually a 1040STFM. There are other notices that flash by during the boot up. Is it telling me the hard drive won;t with this computer? Thanks, gary Hmm, is it actually finishing the bootup process? In other words, are you winding up at the TOS desktop? If so, then it might just be some offending ACCs or AUTO folder apps. You can always disable the ACCs and AUTO folder apps and start adding them back only one at a time until you find the ones that are mis- behaving. Quote Link to comment Share on other sites More sharing options...
gharmon Posted July 26, 2010 Author Share Posted July 26, 2010 Since I'm geeting the message "NOT STE", does that mean this hard drive wants to see a STE box instead of the 1040ST? Perhaps some of the jumpers in the hard drive can be changed to work with the 1040ST?? Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted July 26, 2010 Share Posted July 26, 2010 I'm guessing it's a boot issue, that there is something in the boot record designating a STe... Try HDRiver and see if it will let you reconfig the drive via software Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted July 27, 2010 Share Posted July 27, 2010 Since I'm geeting the message "NOT STE", does that mean this hard drive wants to see a STE box instead of the 1040ST? Perhaps some of the jumpers in the hard drive can be changed to work with the 1040ST?? Try these options. Bypass accessories and auto programs on boot, press Ctrl Hold CTRL and then power on the ST. This will bypass anything in the AUTO folder, hopefully bypassing the STE program. This option should also maintain use of the hard drive. You can then open the AUTO folder and disable the offending program. Bypass the harddrive on boot, press Alt Holding ALT at bootup will bypass the hard drive all together. Once at the desktop, you can run the hard drive driver from the floppy you got to gain access to the hard drive. You will have to add the icons to your desktop after running the driver. Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted August 6, 2011 Share Posted August 6, 2011 I took possession of a SH205 Megafile 20 today. I have a 1040STF computer. Are there any experienced SH205 users listening? Will this 1040 talk to this drive? I do need to get a connecting cable and hopefully it is straight pin to pin connections. I'd also like to find any documentation on the drive as there are DIP switches in the unit. Also, this is one BIG drive assembly. Any help, suggestions, recommendations are appreciated. Thanks, gary Yes, I just got one a few days ago, and I even have an extra cable for it, it is all yours, no cost, if you happen to have the bboot disk for yours we can swap ... anyways the cable is yours free either way and if you do not have the software I can send you a copy when I get mine. I also have the manual for mine , I can photocopy it for you if necessary... rcamp48 (rcamp48@rogers.com) Russ Campbell Quote Link to comment Share on other sites More sharing options...
tjlazer Posted August 7, 2011 Share Posted August 7, 2011 sounds like one of the accessories is running and requires an STE, like STE fix or something. Rename the .ACC file to .ACX and reboot. Quote Link to comment Share on other sites More sharing options...
