+orpheuswaking Posted July 23, 2010 Share Posted July 23, 2010 Was going to play my 1040 STe tonight and the Floppy wont read any disks. I swapped in the internals from my SF314 and I was back in action... But obviously that's not going to work long term... Anyone got a spare 1040 STe internal floppy going spare? (maybe some of you that have pulled them for the HCX) Quote Link to comment Share on other sites More sharing options...
madmax2069 Posted July 23, 2010 Share Posted July 23, 2010 (edited) Did you try cleaning the heads or are they a total loss (if you already tried), or is it a different issue. Because 9 times out of 10 its just dirty heads that causes the drive not to read, or the heads becoming misaligned after a while of use. another issue could be a slow spindle speed causing it not to read. Edited July 23, 2010 by madmax2069 Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted July 23, 2010 Author Share Posted July 23, 2010 Not sure how to fix misalignment or speed issues... But I cleaned the heads already. Quote Link to comment Share on other sites More sharing options...
krupkaj Posted July 23, 2010 Share Posted July 23, 2010 Alison has on her pages info how to modify SONY MPF-920, so it can work with ST http://www.logicsays.com/atari/ Quote Link to comment Share on other sites More sharing options...
amiman99 Posted July 24, 2010 Share Posted July 24, 2010 I was able to use in Atari STF a HP - Epson SMD-340 Flexible disk drive and it works fine. Its only around $15 on EBAY eBay Auction -- Item Number: 260637569785 not my auction, also you can go to your local used PC hardware store and look at their Floppy drive bin and maybe get it for $2 Here is the info below.... SMD-340/SMD-349 (3.5", 1.44MB) THE JUMPER BLOCK IS LOCATED ON THE REAR OF THE DRIVE BETWEEN THE POWER CONNECTOR AND THE DATA CONNECTOR. ____________________________________________________________________ | | | | | |---------| ------------------------- ------------------- | | | o o o o | | 9|10|11|12|13|14|15|16| | ooooooooooooooooo | | | |---------| | 1| 2| 3| 4| 5| 6| 7| 8| | oxooooooooooooooo | | | ------------------------- ------------------- | |____________________________________________________________________| ^ ^ ^ | | | (POWER (JUMPER (DATA CONNECTOR) BLOCK) CONNECTOR) DRIVE SELECT ------------------------------------------------------------------ JUMPER BETWEEN 14 & 15 | DRIVE SELECTED BY DS0 JUMPER BETWEEN 15 & 16 | DRIVE SELECTED BY DS1 (DEFAULT) JUMPER BETWEEN 6 & 7 | DRIVE SELECTED BY DS2 JUMPER BETWEEN 7 & 8 | DRIVE SELECTED BY DS3 ------------------------------------------------------------------ Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted July 24, 2010 Share Posted July 24, 2010 I was able to use in Atari STF a HP - Epson SMD-340 Flexible disk drive and it works fine. I also have used Epson SMD-340s and they've worked out great. Only issue I had is PASTI imager capability, but that isn't going to be an issue for most folks. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted July 24, 2010 Author Share Posted July 24, 2010 I was able to use in Atari STF a HP - Epson SMD-340 Flexible disk drive and it works fine. I also have used Epson SMD-340s and they've worked out great. Only issue I had is PASTI imager capability, but that isn't going to be an issue for most folks. Well actually PASTI is one of the main reasons I wanted to get it working, I have some games that I said I would image for Atarimania. However I do have a working sf314 external for the B drive and that apears to work ok for now. I think I'll grab one of the drives you mentioned (also there is a guy in the UK who has some on Ebay premodded)... Although I am planning on getting the HCx flopy emulator so I may not even want to replace the drive after all... Any thoughts on that? Quote Link to comment Share on other sites More sharing options...
